OASIS Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Zurler, this thread has received 2 replies and been viewed 531 times.
post #1 of 3 (permalink) Old 10-20-2007, 06:43 PM Thread Starter
I am seeking an Oasis Report for the following VIN.
1FTSW21P25EB90151
2005 F-250
Thanks in advance for your help.
Zurler is offline
post #2 of 3 (permalink) Old 10-23-2007, 01:15 AM
Send a message via AIM to Powersmoker113
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 5 2J88 000615 * NPF * D50 42 9112
AWS Claim Key: 1540874 Trx Code: 2 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09091 - * Name: PERFORMANCE FORD Ph: 903-3894186 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2005 Doc #:01486701
Cust Comments: CUST STS WHEN PUTTING THE TRUCK IN REVERSE, THE ENGINE RACED UP AND TRIED TO MOVE. CUST PUT ON THE BRAKE AND THE ENGINE L UGGED. CUSTOMER KILLED THE ENGINE AND RESTARTED IT AND EVERY THING
Tech Comments: COULD NOT VERIFY CONCERN. WDS TESTS CODE P0606. CLEARED AND RETEST AFTER TEST DRIVE NO CODES. COULD NOT DUPLICATE CONCER N AT THIS TIME
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 7 7D01 170101 5C3Z 13008 AA L29 01 13194
AWS Claim Key: 2015481 Trx Code: E83 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 09091 - * Name: PERFORMANCE FORD Ph: 903-3894186 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2005 Doc #:01557101
Cust Comments: CUST STS THE HEADLAMPS AND THE FOG LAMPS HAVE CRACKS
Tech Comments: CRACKED VERIFIED CONCERN BOTH HEADLAMPS AND FOG LAMPS HAVE CRACKS IN LENSES. PER HOTLINE CHECK FOR AFTERMARKET BULBS AND FEEL FOR CRACKS ON THE OUTSIDE (ROCK CHIPS). NONE FOUND. REPLACE ALL HEADLAMP AND FOG LAMP ASSEMBLIES AS PER HOTLINE
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 8 6N04 010802 5C3Z 16720 VA B66 D4 14725
AWS Claim Key: 2311438 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04502 - * Name: THOMPSON COUNTRY FORD-MERCURY, LTD. Ph: 936-8252225 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-OCT-2005 Doc #:0017981
Cust Comments: PAINT PEELING ON SIDE EMBLEMS
Tech Comments: REPLACED BOTH SIDE EMBLEMS
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 21 2E03 030402 4C3Z 9E527 AA D42 55 42232
AWS Claim Key: 6463571 Trx Code: S07 Labor Hrs: 7.3
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:16544602
Cust Comments: CUST STATES ROUGH RUNNING WHEN 1ST CRANKED AFTER SITTING A L ONG WHILE NOTICED EXCESSIVE BLUE SMOKE AT SAME POINT
Tech Comments: ENGINE PERFORMANCE DIAG TEST KOEO TEST INJECTOR ELECTRICAL TEST KOER TEST LOW IDLE STABILITY TEST BOOST PRESSURE TEST CHECKED FOR FUEL CONTAMINATION CHECKED INTAKE RESTRICTION CHECK FUEL PUMP PRES NECESSARY TO REPLACE 2 3 4 AND 8 INJECTORS AND RETEST
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 21 * * * * * * * 42232
AWS Claim Key: 6463570 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:16544604
Cust Comments: CUST STATES 05E15
Tech Comments: PERFORMED RECALL REPLACED EP SENSOR AND RECALIBRATED CONTROL MODULE
AWS Claim Key: 6463569 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:16544605
Cust Comments: CUST STATES PERFORM RECALL 59B01
Tech Comments: PERFORMED RECALL INSTALLED DEGAS BOTTLE LABEL
AWS Claim Key: 6463568 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03013 - * Name: HENSON FORD, INC. Ph: 936-3489610 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:16544606
Tech Comments: RECALL PERFORMED TEST DROVE OK
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 27 2E04 03XXXX 4C3Z 9B246 A D21 42 54484
AWS Claim Key: 7741577 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 07635 - * Name: TEAM FORD MERCURY OF NAVASOTA Ph: 936-8252225 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2007 Doc #:0120971
Cust Comments: VEHICLE DIED WHILE DRIVING AND WILL NOT RESTART
Tech Comments: RAN HARD START/NO START DIAGNOSIS, DEAD HEAD BOTH CYLINDER HEADS, REPLACED HIGH PRESSURE OIL PUMP FITTING AND BRACKET, RETEST, ROAD TEST
1FTSW21P25EB90151 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 04-JAN-2005 18-MAR-2005 152706 USA 32 1H03 030008 5C3Z 9F452 AA E42 42 73403
AWS Claim Key: 8736017 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07635 - * Name: TEAM FORD MERCURY OF NAVASOTA Ph: 936-8252225 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2007 Doc #:01523301
Cust Comments: CHECK ENGINE LIGHT IS ON
Tech Comments: RAN ENGINE PERFORMANCE DIAGNOSIS, RAN EGR SYSTEM TEST, REPLACED EGR VALVE, RETEST, ROAD TEST
2000 PSD F250 Regular Cab. 221k miles, bb Garrett, Swamps Gen3, A1000 Pump, Complete fuel system, Mac Cold Air Intake, 230cc stage 3 single shots, big ol nozzles, Transmission Built from Twisted Diesel Performance, DPtuner, , 4 inch exhaust, 6 inch silverline Tip, Zoo-dad mod, t/c lockup switch, HX crossover line,Intake heater delete,3.73 w/ reworked limited slip, 4 inch hanger kit, 33x12.5 BFG m/ts , 16.5X12 C2's, 04 headlights, 05 grill.
Powersmoker113 is offline
post #3 of 3 (permalink) Old 10-23-2007, 01:35 PM Thread Starter
Thanks
Zurler is offline
