2006 F-350 king ranch cc 4x4 oasis check - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by whitestroker, this thread has received 1 replies and been viewed 1055 times.
post #1 of 2 (permalink) Old 10-23-2007, 09:06 PM Thread Starter
vin: 1FTWW33P56EC69030
THANKS.
whitestroker is offline
post #2 of 2 (permalink) Old 11-04-2007, 11:09 PM
OASIS RESULT:
1FTWW33P56EC69030
11/04/2007
19:09:16
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/22/2006 BUILD DATE
01/26/2006 SALE MILEAGE
00003
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 POWERTRAIN WARRANTY
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: VALUED CUSTOMER
OPTIONS:
EXPIRATION DATE: 08/22/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 08/22/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
09/13/2007
DEALER: Don Gasgarth's Charlotte Count
WARRANTY CLAIM NUMBER: 453719 ODOMETER: 037058M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9G805B KIT-CVR PMP FUEL 001 6007D 01 BROKEN/CRACKED
W300013 004 9543A
W300051 004
CLEAN AREA. ADD DYE ROAD TEST. INSP. FOUND LEAK FROM HIGH PRESSURE OIL PUMP COVER. DRAIN COOLANT. REMOVE TURBO AIR BOX CAC TUBES. TEAR DOWN TOP OF ENGIN E. REMOVE INTAKE MANIFOLD FOR ACCESS. FOUND OIL PUMP COVER CRACKED. R.R COVE R CLEAN AREA. REASSEMBLE ENGINE. ROAD TEST. INSP. NO LEAKS.
05/30/2007
WARRANTY CLAIM NUMBER: 447633 ODOMETER: 027000M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001 061706A 42 DOES NOT OPERATE PROPERLY
W300051 004
W300013 004
1 IDS DIAG PO2285-299-404-401-405 PID MONITOR IDS NO HIGH PRESSURE OIL, P ER TSB 06-17-06 R.R PUMP FITTING ROAD TEST LACKS POWER
05/30/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 062302B 42 DOES NOT OPERATE PROPERLY
5C3Z 9G805B KIT-CVR PMP FUEL 001 061906C
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 9527AT
PERFORMED TSB 061906, REMOVED EGR VALVE, CLEAN AND RETEST, FAILED POSITION T EST, REPLACED VALVE. ALSO PERFORMED TSB 062302 REMOVED TURBO CLEAN AND REI NSTALL. ROAD TEST, TRUCK STALLED. IDS DIAG, NO ICP, AIR TEST SYSTEM, REMOVE BOTH ROCKER COVERS INSPECT FOUND LEAK FROM #8 INJECTOR, R AND R INJECTOR, CL EARED CODES AND RETESTED, NORMAL.
11/27/2006
DEALER: Brandon Ford
WARRANTY CLAIM NUMBER: 087373 ODOMETER: 010432M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 061706A 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001
5C3Z 9C854A BLK-FUL DSTR 001
W301727 OIL PUMP FITTING 001
5C3Z 9G804B O-RING KIT 001
VC 7B 003
6C3Z 6C640AA CONNECTION A/C DUCT 001
9B246 KIT-FUEL SYSTEM SERV 000
REPLACED PUMP, NOZZLE, BRACKET
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P56EC69030
STEVEASHCRAFT is offline
