OASIS Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mire431, this thread has received 1 replies and been viewed 366 times.
post #1 of 2 (permalink) Old 10-24-2007, 06:55 PM Thread Starter
OASIS Please
1ftnw21p34eb51127
mire431 is offline
post #2 of 2 (permalink) Old 11-04-2007, 11:23 PM
OASIS RESULT:
1FTNW21P34EB51127
11/04/2007
19:22:44
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/17/2004 BUILD DATE
11/21/2003 SALE MILEAGE
00479
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
10/08/2007
DEALER: Hub City Ford, Inc.
WARRANTY CLAIM NUMBER: 117823 ODOMETER: 101078M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 061906C 55 PLUGGED/RESTRICTED
CONTAMINATED CC#55 061906C 2.3 VERIFED CONCERN RAN EEC TEST GOT CODE P1335 REMOVED AND CLEANED EGR VALVE DIDNT WORK REPLACED EGR VALVE PER TSB 06-19-6 CLEARED CODE RERAN EEC TEST NO CODES ROADTESTED VERIFED REPAIR
06/04/2007
WARRANTY CLAIM NUMBER: 109259 ODOMETER: 095648M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6079D GASKET SET-VALVE GRI 001 6005F1 D8 FAILED GASKET/SEAL
VC 7B 003 6005F6
W302725 001 6005F18
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F39
XO 15W40QSD 015 6051AT
3C3Z 9C968AA FUEL PRESSURE REG 001 6731A
000 9968B
000 8005D
000 12650D47
000 6005F8
000 6005F22
000 6005F12
000 6005F
000 6005F13
000 6005F2
000 VERIFY60
HEAD GASKETS BLOWN AND IPR STICKING VERIFED CUST CONCERN TEST DROVE RUN K OEO AND KOER TEST CHECKED FUEL PRESSURE AND EGR VAVLE BOTH OK PRESSURE TEST COOLING SYSTEM OK REMOVED EGR VAVLE DRY AND CLEAN IN INTAKE RUN POWER BALANC E AND RUN RELITIVE COMPRESSION BOTH PASS CHECKED FOR BLOW BY PASS TEST DROVE AGAIN AND CHECKED FOR EXH IN COOLANT FAILED REMOVED INTAKE TURBO, FAN AND F
04/26/2007
DEALER: Superior Ford, Inc.
WARRANTY CLAIM NUMBER: 018615 ODOMETER: 094280M
LABOR OP
CONDITION CODE
CONDITION DESC
9F452 TRANSDCR-EGR BACK PR 000
PM 6 001
RAN EEC TEST FOUND CODES P0404 AND JP1335, TESTED AND FOUND EGR VALVE STUCK JOPEN, CLEANED VALVE, STILL NOT PASSING ALL EGR TEST, REPALCED EGR VALVE PER TSB 06-19-06
10/10/2006
DEALER: Hollingsworth Richards Ford
WARRANTY CLAIM NUMBER: 438299 ODOMETER: 087810M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 6642A
VC 7B 003 12650D30
OSP 001 MT062102
3C3Z 9P455AB SE E/G/R VLV 001
SEE TSB 06-21-2 PRESSURE TESTED COOLANT SYSTEM REMOVED EGR VALVE INTAKE FULL OF COOLANT INSTALLED GAUGE INLINE WITH EGR COOLER TEST DROVE MONITERING PID S ECT EOT ECT 205 EOT 24 REPLACED ENGINE OIL COOLER AND EGR COOLER CLEANED E GR VALVE AND REPLACED O-RINGS RETESTED NO FURTHER PROBLEMS AT THIS TI
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21P34EB51127
STEVEASHCRAFT is offline
