Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 1 replies and been viewed 469 times.
post #1 of 2 (permalink) Old 10-28-2007, 03:38 AM Thread Starter
bootcamp's Avatar
Oasis Report Please
Oasis Report Please On The Following
1ftww33p16ed77712 Thanks
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 2 (permalink) Old 11-04-2007, 11:20 PM
OASIS RESULT:
1FTWW33P16ED77712
11/04/2007
19:20:34
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/21/2006 BUILD DATE
04/23/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 P'TRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: LEDFORD GILLESPIE
OPTIONS:
EXPIRATION DATE: 07/21/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 07/21/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
07/09/2007
DEALER: Hixson Autoplex
WARRANTY CLAIM NUMBER: 298670 ODOMETER: 022982M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6079A GASKET SET-VALVE GRI 001 6007A 42 DOES NOT OPERATE PROPERLY
5C3Z 6K682CARM TURBO CHG-EXH DRIVE 001 MT6051A
W300013 004 12650D
W300051 004 12650DX1
388898S 002 12650D45
1W1Z 19E889DC O RING - A/C COMP 002 12650D81
1W1Z 19E889BB O RING - A/C COMP 002
VC 7B 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
PERFORMED EECF TESTS PID MONITOR AND PINPOINT TEST FOUND TURBO OVERBOOST CAU SED HEAD GASKET FASILURE REMOVED ENGINE REPLACED HEAD GASKETS REPALCED TUR BO RETEST VERIFED REAIR
06/06/2007
WARRANTY CLAIM NUMBER: 296681 ODOMETER: 020780M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642AA COOLER CRANKCASE OI 001 6642A 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001 12650D
4C3Z 9F838A SENSR ASY F/I TIMING 001 12650DX1
VC 7B 002 12650D81
3C3Z 6731AA ELEMENT ASY OIL FILT 001 12650D45
XO 15W40QSD 015
PERFROME EEC TESTS PID MONITOR AND PINPOINT TEST FOUND OIL C COOLER RESTRICT ED DAMAGED EGR COOLER ICP BIASED REPALCED ICP SENSOR REPALCED OIL COOLER A ND EGR COOLER RETEST VERIFIED REPAIR
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P16ED77712
STEVEASHCRAFT is offline
