Report, please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by LJRF250, this thread has received 1 replies and been viewed 496 times.
post #1 of 2 (permalink) Old 10-30-2007, 04:32 PM Thread Starter
Report, please
1ftnw21p23ed66738
Thanks!:Thumbup:
LJRF250 is offline
post #2 of 2 (permalink) Old 11-04-2007, 11:17 PM
OASIS RESULT:
1FTNW21P23ED66738
11/04/2007
19:17:18
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/11/2003 BUILD DATE
06/17/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0764 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: CHRISTINE OR HUDSON
OPTIONS:
EXPIRATION DATE: 10/11/2005
DISTANCE: 36,000
RENTAL: 28 UP TO 3 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07759
ESP CONTRACT START DATE: 10/11/2003
WARRANTY REPAIR HISTORY
09/25/2007
DEALER: Capitol Expressway Ford
WARRANTY CLAIM NUMBER: 085561 ODOMETER: 048004M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D1 POROSITY
5C3Z 12224A 3 WAY VACUUM CONNECT 001 12650D
000 12650D45
000 12650DX1
000 9838A
INSPECT WITH BLACK LIGHT MOTOR FOUND LEAK REAR OF MOTOR ALSO PULL DTC P02285 RAN PINPOINT TEST PULL ICP CONNECTOR. REMOVE AND REPLACE ICP SENSOR CHANGE CONNECTOR AND RECHECK WHEN DONE OK AT THIS TIME
09/11/2007
WARRANTY CLAIM NUMBER: 084524 ODOMETER: 047338M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001 6007D D1 POROSITY
OSP 002 9438A
6K682 TURBO CHG-EXH DRIVE 000
INSPECT FOR OIL LEAK SIGNS AT OIL TURBO 2 POSSI BLE REAR MAIN SEAL RESEAL T URBO AND INSTALL DYE AND RECHECK REMOVED TURBO AND INSTALL TUBE TO MOTOR A DD OIL DYE AND RECHECK CLEAN OFF ALL EXC ESSIVE OIL FROM BLOCK,ROADTEST AND RECHECK WITH BLACK LIGHT
01/08/2007
DEALER: Crown Ford
WARRANTY CLAIM NUMBER: 298780 ODOMETER: 039932M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9N622A IND ASY ENG A/C REST 001 9438A 42 DOES NOT OPERATE PROPERLY
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001 9438A2
3C3Z 6N640AA GASKET TURBO TO MANI 001 061906A
W300013 002 062203A
W300051 004 12650D82
W301640 002 12650D81
3C3Z 6K854DA PIPE (TURBO INLET LO 001
3C3Z 9P455AB SE E/G/R VLV 001
INSPECTED VEH AND ROADTESTED SMOKE ON START UP AND HAS LACK POWER AT TIMES,P ERFORMED TSB 06-22-03 PERFORMED EGR TEST FAILED PERFORMED TSB 06-19-06 EGR C LEANING AND RETEST FOUND DTC P0401 AND P132B,
| On-line 1878
END OF OASIS REPORT FOR 1FTNW21P23ED66738
STEVEASHCRAFT is offline
