Full Oasis Please: 1ftww31p16eb86410 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bushpilot, this thread has received 1 replies and been viewed 532 times.
post #1 of 2 (permalink) Old 11-08-2007, 10:30 PM Thread Starter
bushpilot's Avatar
Don R.
Truck Audio,
bushpilot is offline
post #2 of 2 (permalink) Old 11-17-2007, 02:36 AM
Standard Claims List For Model Year 2006
1FTWW31P16EB86410 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2005 28-NOV-2005 158417 USA 17 1A02 030102 * 6051 * D02 42 28348
AWS Claim Key: 3599300 Trx Code: E84 Labor Hrs: 20.1
Dlr Cd-Sub Cd: 03095 - * Name: BRENENGEN FORD MERCURY, INC. Ph: 608-2696716 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2007 Doc #:032620A
Cust Comments: CHECK VEHICLE HAS OVERHEATED TWICE WHILE PULLING TRAILER LOW ON COOLANT WILL OVERHEAT PER GAUGE THEN TEMP DROPS BACK INTO
Tech Comments: ON COOLANT WILL OVERHEAT PER GAUGE THEN TEMP DROPS BACK INTO NORMAL RANGE TEST DIAG AS HEADGASKETS LEAKING, REPLACED GASKETS
OASIS RESULT:
1FTWW31P16EB86410
11/16/2007
22:35:03
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/28/2005 BUILD DATE
11/03/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/09/2007
DEALER: Brenengen Ford Mercury, Inc.
WARRANTY CLAIM NUMBER: 032620 ODOMETER: 028348M
LABOR OP
CONDITION CODE
CONDITION DESC
6051 GASKET CYL HEAD 000 6005F 42 DOES NOT OPERATE PROPERLY
W300050 001 6005F1
W300013 001 6005F1X1
6C3Z 3D746A COOLER ASSY P/S OIL 001 6005F2
4C3Z 9P456AF COOLER - EGR 001 6005F6
3C3Z 6A642AA COOLER CRANKCASE OI 001 6005F8
3C3Z 9433BE GASKET SET-MANIFOLD 001 6005F9
5C3Z 6079D GASKET SET-VALVE GRI 001 6005F11
3C3Z 6065AA BOLT CYL HEAD 020 6005F12
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F14
XO 15W40QSD 015 6005F18
VC 7B 002 6005F19
XT 2QDX MOTORCRAFT BATTERY 002 6005F25
3C3Z 6734AA GASKET-ENG OIL PAN D 001 6005F39
3C3Z 9N184CA WATER-FUEL SEP ELEM 001 6005F45
000 6051AT
000 6051A10
000 6051A11
ON COOLANT - WILL OVERHEAT PER GAUGE THEN TEMP DROPS BACK INTO NORMAL RANGE TEST DIAG AS HEADGASKETS LEAKING, REPLACED GASKETS
| On-line 1878
END OF OASIS REPORT FOR 1FTWW31P16EB86410
STEVEASHCRAFT is offline
