Oasis report & Build sheet, if possible. Thanks in advance! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by parasail, this thread has received 1 replies and been viewed 975 times.
post #1 of 2 (permalink) Old 11-12-2007, 02:58 PM Thread Starter
1fmsu45p23eb95547
parasail is offline
post #2 of 2 (permalink) Old 11-17-2007, 02:43 AM
Standard Claims List For Model Year 2003
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 3 2E01 * * * * * * 5670
AWS Claim Key: 997009 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2003 Doc #:04503052
Cust Comments: RECALL 03B05 INJECTION CONTROL PRESSURE (ICP) SENSOR REPLACEMENT
Tech Comments: AS PER CAMPAIGN RPLC ICP SENSER PER RECALL, RT 8 MLS AFTER RECALLS
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 3 2G05 * * * * * * 5670
AWS Claim Key: 997010 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2003 Doc #:04503053
Cust Comments: RECALL 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: AS PER CAMPAIGN REPROGRAM MULTIPLE MODULES PER RECALL,RT 8 MLS AFTER RECALLS DONE
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 3 * * * * * * * 5670
AWS Claim Key: 997011 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2003 Doc #:04503054
Cust Comments: RECALL 57B98 FREE MOTORCRAFT OIL FILTER CHANGE
Tech Comments: AS PER CAMPAIGN CHANGE OIIL & FLTR PER RECALL
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 3 7K12 010503 2C7Z 10D898 AA G32 42 5670
AWS Claim Key: 1168760 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2003 Doc #:04678853
Cust Comments: INSTALL SOP COMPASS ASSY, NOT LIGHTING UP
Tech Comments: COMPASS LIGHT INOP CHECK MODULE. FOUND LCD BURNT OUT. REPLACED MODULE AND RE CAL
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 4 2G05 031405 * RECALEM * D13 42 5733
AWS Claim Key: 1168761 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2003 Doc #:04678851
Cust Comments: CHECK ROLLING IDLE ON START UP
Tech Comments: DID A DIESEL PERF DIAG KOEO KOER TESTING NO CODES CK QASIS AND GOT A NEW UPDATE PROGRAMM AND REPROGRAMM PCM ROAD TEST 15 RETESTED PASS NO OPER FOR DIAG
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 6 7W15 131301 1C7Z 15K866 AA G29 42 11809
AWS Claim Key: 1689921 Trx Code: 1 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2003 Doc #:05353451
Cust Comments: CHECK BACK UP SENSOR GOES OFF CONSTANTLY INSTALL SOP USE SPO 03149048
Tech Comments: INSTALL SOP MODULE.SYSTEM NOT OPERATING.WDS TEST.CODE 1742.PERFORM PINPOINT TEST.FOUND SOUNDER UNPLUGGED.REFASTEN SOUNDER CONNECTOR. SYSTEM NOT OPERATING PROPERLY.MONITOR PIDS.FOUND LEFT INNER SENSOR OUT OF RANGE.REPLACE SENSOR.RETEST SYSTEM OPERATING TO SPECS
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 12 * * * * * * * 33073
AWS Claim Key: 4043658 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2004 Doc #:07561752
Cust Comments: RECALL 03E03 POWERTRAIN CONTROL MODULE & FUEL INJ CONTROL MODULE RE CALIBRATION
Tech Comments: RECALL REPROGRAMM WITH NEW UPDATES ROAD TEST
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 15 5K06 * * * * * * 39276
AWS Claim Key: 5074711 Trx Code: 04B14 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:08412151
Cust Comments: RECALL 04B14 FIRESTONE STEELTEX
Tech Comments: FIRESTONE RECALL 5 NEW (N#M3W8BU111403 X4,M3W8BU114103)(O#VNW81XO4602 X5)
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 15 6J06 011405 3C7Z 7843170 AB L07 41 39276
AWS Claim Key: 5074712 Trx Code: P05 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:08412152
Cust Comments: CHECK VEH FOR REAR DOOR LOCK FOR THE HATCH INOP P05
Tech Comments: STICKING REPLACE REAR DOR LOCK ACTUATOR AND STICKY LATCH CONTROL ASSY
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 15 7C01 170503 2C7Z 14018 AA L19 42 39276
AWS Claim Key: 5137031 Trx Code: E81 Labor Hrs: 1
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:08412153
Cust Comments: CHECK VEH FOR DOOR AJAR LIGHT AND DOME LIGHTS ON AT ALL TIMES P05
Tech Comments: STICKING CHECK ILLUMINATION SYSTEM NO CODES PINPOINT TO STICKY LATCH SWITCH
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 15 7H12 120308 2C3Z 19980 AA C07 42 39276
AWS Claim Key: 5074713 Trx Code: P05 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:08412154
Cust Comments: CHECK VEH FOR HEATER CONTROL INTERMIT INOP DID NOT LIGHT UP OR ANYTHING P05
Tech Comments: INOP PINPOINT AND REPLACE INTERMITENT AC CONTROLS
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 26 * * * * * * * 71176
AWS Claim Key: 9942122 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:02933851
Cust Comments: RECALL NO 04S15 BATTERY CABLE
Tech Comments: AS PER RECALL INSP RAD STRAP & THEN REMOVED & REPLACED GROUND BOLT PER RECALL
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 31 6Y05 000001 * SERVICE * A96 82 79611
AWS Claim Key: 11568280 Trx Code: 0969S Labor Hrs: 0
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:02-AUG-2005 Doc #:04773651
Cust Comments: USED ENGINE MAINT DSL 7500 MILES
Tech Comments: OIL CHANGE TOP OFF ALL FLUIDS
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 34 6J14 011404 6L3Z 25218A43 AA L17 28 87899
AWS Claim Key: 12193278 Trx Code: 0736D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2005 Doc #:13853101
Cust Comments: CUSTOMER STATES THAT POWER DOOR LOCK ON DRIVERS DOOR SOES NOT WORK
Tech Comments: DIAG CONCERN & VERIFY DIAG & PINPOINT CK SWITCHES DIAG CONCERN R & I TRIM & LATCH REPL ACCUATOR & RETESTED OK
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 34 7M01 150101 * 18806 * A16 42 87899
AWS Claim Key: 12193279 Trx Code: 0736D Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2005 Doc #:13853102
Cust Comments: CUSTOMER STATES THAT CD PLAYER IN RADIO DOES NOT WORK. RADIO WORKS FINE
Tech Comments: REMOVED RADIO THEN REINSTALLED RADIO.
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 35 6Y05 000001 * SERVICE * A96 82 91039
AWS Claim Key: 12691015 Trx Code: 0969S Labor Hrs: 0
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2005 Doc #:14222501
Cust Comments: CUSTOMER STATES THAT PERFORM 87.5K MAINT
Tech Comments: 90 K SERVICE, L.O.F., TIRE ROTATION, FUEL FILTER
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 35 7M01 150101 * 18806 * A18 42 91039
AWS Claim Key: 12592075 Trx Code: SPW Labor Hrs: 1.5
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:28-NOV-2005 Doc #:14222502
Cust Comments: CUSTOMER STATES THAT SOUND FROM DVD PLAYER DOES NOT WORK. PICTURE IS FINE
Tech Comments: DIAG CONCERN & VERIFY NO SOUND FROM DVD PLAYER IN REAR DIAG CK SYS PINPOINT SWITCHES WORKING RADIO NOT REMOVE RADIO & REPL & RETSETED OK DVD WORKING
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 35 7M01 150101 3C7T 18C815 AA A07 42 91039
AWS Claim Key: 13760848 Trx Code: 0736D Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2005 Doc #:32168500
Tech Comments: REQUESTING DEALER'S P/A CODE 05536
1FMSU45P23EB95547 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 07-JAN-2003 21-JAN-2003 171169 USA 47 * * * * * * * 117999
AWS Claim Key: 14582848 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2006 Doc #:17079301
Cust Comments: VOLUNTARY EMISSION RECALL 06E17 CERTAIN 2003 2004 MODEL YEAR F 250 350 450 550 AND EXCURSION VEHICLES EQUIPPED WITH
Tech Comments: RECALL DONE
AWS Claim Key: 14582847 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20354 - * Name: GALPIN FORD, INC. Ph: 928-4453673 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2006 Doc #:17079302
Cust Comments: 59B01 ONE TIME CUSTOMER ASSURANCE TEST DRIVE (RECALL 05S34)
Tech Comments: TEST DRIVE
OASIS RESULT:
1FMSU45P23EB95547
11/16/2007
22:42:21
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
3L11ON0A
WARNING MESSAGES
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/21/2003 BUILD DATE
01/07/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0969 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: MARTIN VALENZUELA
OPTIONS:
EXPIRATION DATE: 03/30/2007
DISTANCE: 102,120
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07869
ESP CONTRACT START DATE: 03/30/2005
0736 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OPTIONS:
DISTANCE: 95,120
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FMSU45P23EB95547
STEVEASHCRAFT is offline
