OASIS Check - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RockStar, this thread has received 1 replies and been viewed 534 times.
post #1 of 2 (permalink) Old 12-02-2007, 03:58 AM Thread Starter
RockStar's Avatar
Send a message via MSN to RockStar
OASIS Check
Truck was in the shop for 2.5 MONTHS! Just wanted to see what they did since the Tech was an
VIN: 1FTSX31P54ED51044
Thanks
RockStar is offline
post #2 of 2 (permalink) Old 12-02-2007, 06:59 PM
OASIS RESULT:
1FTSX31P54ED51044
12/02/2007
14:58:14
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/08/2004 BUILD DATE
05/22/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
09/28/2007
DEALER: Stanley Ford, Inc.
WARRANTY CLAIM NUMBER: 602620 ODOMETER: 022942M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6051EA GASKET CYL HEAD 002 6051AT 14 SURFACE ROUGH/UNEVEN
4C3Z 9P456AF COOLER - EGR 001 6051A10
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001 6051A20
3C3Z 6049CARM CYLINDER HEAD 002 12650D
3C3Z 6731AA ELEMENT ASY OIL FILT 001 12650DX1
XO 10W30QSD 015
VC 7B 004
YN 19 037
TURBO NOISEY AND LOOSING COOLANT KOEO P0299 P0478 INSPECTED TURBO BEARINGS V ERY LOOSE IN TURBO REPLACED TEST DROVE BLOWING COOLANT OUT OF DEGAS BOTTLE B ODLY REMOVED CYCLINDER HEADS AND INSPECTED WARPED BADLY INSTALLED 2 NEW HEAD S AND GASKETS AS NEEDED CHANGED OIL AND FILTER REFILLED COOLANT SYSTEM AND T EST DROVE OK
06/08/2007
WARRANTY CLAIM NUMBER: 600850 ODOMETER: 021609M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 3A131AD KIT SPINDLE CON ROD 001 3001A1T 42 DOES NOT OPERATE PROPERLY
4C3Z 3049DB JOINT ASY-FRT SUSP L 002 3049AT
5C3Z 3050AB KIT-FRT SUSP LWR SPD 002 3130AA
F81Z 4228BA WASHER-DIFF SIDE GR 001
CHECK OUT FRONT END LOOSE FOND UPPER AND LOWER BALL JOINTS LOOSE AND RIGHT O UTER TIE ROD END LOOSE R&R UPPER AND LOWER BALL JOINTS BOTH SIDES R&R RIGHT OUTER TIE ROD END LONG CHECK ALIGNMENT ALIGNED FRONT END CHANGED CAMBER BOTH SIDES SET TOE CENTER STEERING WHEEL ROAD TEST OK
| On-line 1878
END OF OASIS REPORT FOR 1FTSX31P54ED51044
imported_cb44473 is offline
