oasis report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by getusummm, this thread has received 2 replies and been viewed 450 times.
post #1 of 3 (permalink) Old 12-02-2007, 03:00 PM Thread Starter
oasis report
Hi all, new member here. I just purchased an 03 f350 drw 4x4. When looking over the vehicle, I had concerns with the color of the outgas bottle. Tech says everything was fine. Appears somewhat oily and appears to have overflowed quite a few times. Asked for reports at dealer, but they were "unable" to do them at the time. Well I just got back from Florida after purchasing a 28' boat. One the way back I noticed a big lack of power and going up hills there would be a strong coolant smell in the cab. From what I have read, this could be from head gaskets or hopefully egr cooler. I did replace outgas cap to no avail. Level in bottle is a little below the min mark and didnt really change much. The temp gauge shows in the middle.
Vin # is 1FTWW33P83ED65911
Any help would be appriciated
Patrick
getusummm is offline
post #2 of 3 (permalink) Old 12-02-2007, 06:57 PM
OASIS RESULT:
1FTWW33P83ED65911
12/02/2007
14:56:30
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/08/2003 BUILD DATE
06/22/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
06/29/2007
DEALER: Bolton Ford, L.L.C.
WARRANTY CLAIM NUMBER: 059058 ODOMETER: 110350M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 061906C 41 STICKS/BINDS/GRABS
3C3Z 9P455AB SE E/G/R VLV 001
PM 3 001
VALVE STICKING TSB 06-19-6 EEC TEST P0401 P0402 P0404 P1335 MONITER PIDS EGR VA LVE STICKING OPEN REMOVE AND CLEAN VALVE REINSTALL AND RETEST, VALVE STILL F AILED, REPLACE VALVE AS PER TSB 06-19-6 CLEAR CODES RETEST OK TEST DRIVE OK
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P83ED65911
imported_cb44473 is offline
post #3 of 3 (permalink) Old 12-26-2007, 08:13 AM Thread Starter
Thanks for the report. Sorry for taking so long to reply. Computer went down and I just got around to replacing it. If I am reading this correctly, it appears that none of the recalls have been performed on this truck. Is that correct? Also now the truck is sitting in my shop. It started pouring white smoke and is low on coolant. Any chance of getting help from Ford on this one even though it is out of warranty?
Thanks again, Patrick
