OASIS Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 05Powerstroker, this thread has received 1 replies and been viewed 517 times.
post #1 of 2 (permalink) Old 12-04-2007, 05:33 PM Thread Starter
OASIS Report Please
Sorry, I started this in the wrong thread.
Can you please pull a report for VIN: 1FTSW21PX5EC53612. 2005 Harley F-250, 49,500 miles.
Thanks so much.
05Powerstroker is offline
post #2 of 2 (permalink) Old 12-10-2007, 11:47 AM
OASIS RESULT:
1FTSW21PX5EC53612
12/10/2007
07:46:20
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/24/2005 BUILD DATE
02/25/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/16/2007
DEALER: County Line Ford
WARRANTY CLAIM NUMBER: 241871 ODOMETER: 049128M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6007D 42 DOES NOT OPERATE PROPERLY
000 6646AH
49128 6C640 6007D 6646AH 90 PERFOMRED OIL LEAK DIAG FOUND HOT SIDE CAC TUBE LEAKING REPALCED TUBE ROAD TESTED OK
11/16/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
49128 9E527 070504A 70 REPROGRAMED PER TSB 07-05- 4
04/10/2007
DEALER: Bird-Kultgen Inc
WARRANTY CLAIM NUMBER: 332435 ODOMETER: 034100M
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
DONE AS PER RECALL
04/10/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001 061706A 42 DOES NOT OPERATE PROPERLY
EEC TEST, AIR CHECK HIGH PSI OIL SYSTEM. REPLACED STC BRACKE T KIT AS PER TS B 06-17-06
04/10/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F838A SENSR ASY F/I TIMING 001 9332AL 55 PLUGGED/RESTRICTED
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 9838A
3C3Z 6731AA ELEMENT ASY OIL FILT 001 9424A
OSP 002
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
OSP 024
VC 7B 002
CHECK AND FOUND BAD ICP SENSOR, REMOVED AND REPLACED VALVE C OVERS, NEW INTA KE GSKTS, NEW STAND PIPE OIL RAIL.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21PX5EC53612
imported_cb44473 is offline
