Oasis report request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by superfuzz, this thread has received 2 replies and been viewed 607 times.
post #1 of 3 (permalink) Old 12-09-2007, 10:54 PM Thread Starter
I am looking to buy an Excursion. Would you please check:
1FMSU45P63ED13681
thanks very much!!
superfuzz is offline
post #2 of 3 (permalink) Old 12-10-2007, 11:42 AM
OASIS RESULT:
1FMSU45P63ED13681
12/10/2007
07:41:37
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/07/2003 BUILD DATE
04/23/2003 SALE MILEAGE
00241
03E04
NON-CALIFORNIA CERTIFIED VEHICLES WITH CALIFORNIA VEHICLE EMISSION CONTROL INFOR MATION
EXTENDED COVERAGES
0710 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: CRAIG REED
OPTIONS: $100,DED.
EXPIRATION DATE: 08/07/2007
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 03829
ESP CONTRACT START DATE: 08/07/2003
WARRANTY REPAIR HISTORY
07/23/2007
DEALER: Bird-Kultgen Inc
WARRANTY CLAIM NUMBER: 336819 ODOMETER: 056870M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9B249A HEADER-FUEL FILTER 001 6005F 42 DOES NOT OPERATE PROPERLY
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 6005F1
4C3Z 9J460A SENSOR ASY EGR PR VL 001 6005F8
000 6005F9
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F19
000 6005F20
000 6005F21
000 6005F22
000 9249A
000 12650D9
REPLACE EBP SENSOR AND WATER SEPERATOR
07/23/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6F089 ACTUATOR ASSY 000 062302A 42 DOES NOT OPERATE PROPERLY
3C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
CHECK AND REPLACE TURBOCHARGER ASSEMBLY
12/15/2006
DEALER: Thornhill Ford-Mercury
WARRANTY CLAIM NUMBER: 079812 ODOMETER: 051808M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433AA GASKET SET-MANIFOLD 001 8005D 42 DOES NOT OPERATE PROPERLY
000 9424A
PERFORMED COOLANT DIAG FOUND ORANGE HOSE AT EGR COOLER LEKAING REPLACED INT AKE GASKETS AND ORANGE HOSE RETESTED LEAK IS GONE
12/15/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
000 6005F11
000 6005F12
000 6005F13
000 6005F14
000 6005F18
000 6005F20
000 6005F21
000 6005F22
000 6005F23
000 6005F25
000 VERIFY60
PERFORMED DIESEL DIAG FUEL AND OIL IN SPECS VGT DIAG REPLACED VGT SOLENOID RETESTED ALL OK
12/02/2006
WARRANTY CLAIM NUMBER: 079573 ODOMETER: 051371M
LABOR OP
CONDITION CODE
CONDITION DESC
W300046 001 6007D 42 DOES NOT OPERATE PROPERLY
3C3Z 6C315AA SENSOR CRANK TIMING 001 MTW300046
000 12650D57
000 VERIFY60
PERFORMED OIL LEAK DIAG REPLACED LOW PRESSURE OIL REGULATOR ORING AND LEAKIN G CRANK SENSOR RETESTED OIL LEAK IS GONE
imported_cb44473 is offline
post #3 of 3 (permalink) Old 12-10-2007, 09:52 PM Thread Starter
Thanks. If I read this right, it looks like its had a lot of problems with the turbo?
