Oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 1F350, this thread has received 2 replies and been viewed 396 times.
post #1 of 3 (permalink) Old 12-10-2007, 07:48 PM Thread Starter
Oasis
Hello, new to the forum, please run an Oasis VIN #1FTSW31P44EA24038. Thanks!
1F350 is offline
post #2 of 3 (permalink) Old 01-05-2008, 02:30 AM
OASIS RESULT:
1FTSW31P44EA24038
01/04/2008
22:30:29
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
3F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/20/2003 BUILD DATE
08/04/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/26/2007
DEALER: Frontier Ford
WARRANTY CLAIM NUMBER: 028334 ODOMETER: 058076M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527EARM NOZZLE ASY-FUEL INJE 001 070504A 42 DOES NOT OPERATE PROPERLY
3C3Z 9229AA GASKET CARB FUEL INL 001 6005F
000 6005F13
000 6005F1
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F21
000 6005F6
000 6005F8
000 6005F22
000 6005F9
000 6005F45
000 9527AT
000 VERIFY60
DIESEL DIAG, PINPOINT TEST PCM FICM PER TSB 070504. REPLACED FUEL INJECTOR # 5 AND O-RING ON INJECTOR #2. WPI
11/26/2007
WARRANTY CLAIM NUMBER: 026652 ODOMETER: 057585M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 072109A 55 PLUGGED/RESTRICTED
REPLACED EGR VALVE WPI
11/26/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6701A CRANKSHAFT REAR SEAL 001 6007A
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6007A38
3C3Z 6731AA ELEMENT ASY OIL FILT 001 VERIFY60
XO 15W40DSD 015
3C3Z 6734AA GASKET-ENG OIL PAN D 001
5C3Z 6710AA GASKET SET-OIL PAN 002
3C3Z 6020CA GASKET CYL TIMING GE 001
W300024 004
3C3Z 6710BA GASKET SET-OIL PAN 001
3C3Z 6710CA GASKET SET-OIL PAN 001
TA 25 003
3C3Z 9229B GASKET CARB FUEL INL 001
3C3Z 9C064DA FUEL FILTER "O"RING 001
VC 7B 003
XT 5DM 001
RESEALED BED PLATE AND ENGINE COVERS WPI
11/06/2007
WARRANTY CLAIM NUMBER: 025617 ODOMETER: 056364M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229B GASKET CARB FUEL INL 001 6007D D1 POROSITY
TA 25 001 12650D60
12K073 TRNSDC ASY-C/SHT PSN 000
REPLACED CAM SENSOR ORINGS WPI
11/06/2007
LABOR OP
CONDITION CODE
CONDITION DESC
W302725 001 071601A 42 DOES NOT OPERATE PROPERLY
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 MT072109
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001 12650D84
3C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001
REPLACED TURBO AND EGR VALVE , ALSO REPROGRAMMED PCM WPI
01/04/2007
WARRANTY CLAIM NUMBER: 006816 ODOMETER: 041308M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 003 6007D D8 FAILED GASKET/SEAL
3C3Z 9229B GASKET CARB FUEL INL 001 12650D57
3C3Z 9C064DA FUEL FILTER "O"RING 001 MT6C315
3C3Z 6C315AA SENSOR CRANK TIMING 001
WPI R&R CRANK SENSOR AND O-RINGS, EXTRA TIME TO REMOVE CRUMBLED SENSOR AND CLEAN TREADS.
01/04/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P455AB SE E/G/R VLV 001 061906A 55 PLUGGED/RESTRICTED
9F452 TRANSDCR-EGR BACK PR 000
WPI CLEAN EGR VALVE AND REPLACE GASKET
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P44EA24038
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
post #3 of 3 (permalink) Old 01-07-2008, 06:21 PM Thread Starter
Thank you for running the Oasis, is there a report that shows all activity since new? I need to compare to my records what Ford shows I am trying to get an extended warranty due to all the problems I have had.
1F350 is offline
