I would like an OASIS report please? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mustang50, this thread has received 1 replies and been viewed 611 times.
post #1 of 2 (permalink) Old 12-18-2007, 02:06 AM Thread Starter
1FTSW21P75EA16558
Thank you very much in advance!
Mustang50 is offline
post #2 of 2 (permalink) Old 01-05-2008, 02:10 AM
OASIS RESULT:
1FTSW21P75EA16558
01/04/2008
22:09:54
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/31/2004 BUILD DATE
08/17/2004 SALE MILEAGE
00012
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/02/2007
DEALER: Tenvoorde Ford, Inc.
WARRANTY CLAIM NUMBER: 275269 ODOMETER: 084905M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F13
95874S101 002 6005F2
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 6005F14
000 6005F18
000 6005F8
000 6005F6
000 6005F22
000 9527AT
000 062203A
000 MT9527AR
000 OSL
84000 VERIFY CONCERN ENGINE CRANK NO START PERFORM PRELIMINARY INSPECT OIL LEVEL OK. FUEL OK. FUEL PRESSURE 50 PSI OK. PERFORM PINPOINT TEST P CHECK ICP PRESSURE WITH SCAN TOOL 30 PSI IPR 84%. PERFORM EEC TEST P0272-CYLINDER CONTRIBUTION-BALANCE CYL #4 P0284-CYL # 8 CONT BALANCE REMOVE LEFT BANK V ALVE COVER AND INSTALL HIGH PRESSURE OIL RAIL AIR PRESSURE TEST BEFORE
01/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 8005D 42 DOES NOT OPERATE PROPERLY
3C3Z 6766BA CAP ASY OIL FILLER 001 9456A
4C3Z 9P456AF COOLER - EGR 001 12650D30
F6TZ 9160AA GSKT- FUEL FLTR BOWL 002 MT062514
W301558 001
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
VC 7B 003
3C3Z 6840AA GASKET-OIL FILLER AD 001
84000 PERFORM COOLING SYSTEM PRESSURE TEST FOUND NO EXTERNAL LEAKS REMOVE E GR VALVE AND INSPECT INTAKE FOUND EVIDENCE OF COOLANT. REC. REPLACE EGR CO OLER AND EGR VALVE. REC. HAVE INTAKE CLEANED. 3 AS PER TSB 6-25-14. DRAIN C OOLANT AND REMOVE RAD FAN SHROUD AND FAN ASSEMBLY. REMOVE FICM REMOVE TURB O REMOVE OIL FILTER AND SECONDARY FUEL HOUSEING. REMOVE INTAKE REMOVE AND RE
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P75EA16558
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
