OASIS Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sdrowmodnar, this thread has received 1 replies and been viewed 433 times.
post #1 of 2 (permalink) Old 12-19-2007, 12:21 AM Thread Starter
OASIS Please
1FTSX21P25EC34873
Thanks in advance.
sdrowmodnar is offline
post #2 of 2 (permalink) Old 01-05-2008, 02:11 AM
OASIS RESULT:
1FTSX21P25EC34873
01/04/2008
22:10:56
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/01/2005 BUILD DATE
02/16/2005 SALE MILEAGE
00005
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
2112 - EXPIRED
STANDARD DEDUCTIBLE: 0 CAD
OWNER NAME: CLAUDE CARRIER
OPTIONS:
EXPIRATION DATE: 10/01/2007
DISTANCE: 41,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 CAD
CONTRACT SOLD BY: CAN B2495
ESP CONTRACT START DATE: 10/01/2005
WARRANTY REPAIR HISTORY
10/10/2007
DEALER: Beaudry & Lapointe Ltee
WARRANTY CLAIM NUMBER: 061006 ODOMETER: 063298K
LABOR OP
CONDITION CODE
CONDITION DESC
W302725 001 6051AT 42 DOES NOT OPERATE PROPERLY
3C3Z 9P455AB SE E/G/R VLV 001 6051A20
4C3Z 9P456AF COOLER - EGR 001
3C3Z 9J469AA SEAL EGR TUBE 001
CXO 15W40LSD12 015
3C3Z 6731AA ELEMENT ASY OIL FILT 001
CXC 209 004
FAIT TEST ET REMPLACER VALVE EGR
05/28/2007
WARRANTY CLAIM NUMBER: 058912 ODOMETER: 055382K
LABOR OP
CONDITION CODE
CONDITION DESC
F37Z 13550AA LAMP ASSY REAR LICEN 001 13465A 42 DOES NOT OPERATE PROPERLY
LS 18 001
C2AZ 13466C SMALL BULBS 001
REMPLACER 1 LENS,FILLAGE ET GLOBE COTE GAUCHE
05/28/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 3050AB KIT-FRT SUSP LWR SPD 001 3049ATA 42 DOES NOT OPERATE PROPERLY
5C3Z 3049AB JOINT ASY-FRT SUSP L 001
W525288S437 001
W525288S437 001
5C3Z 3254AA OIL SEAL-FRONT AXLE 001
5C3Z 4A322AA SEAL FRT WHL HUB 001
REMPLACER 2 BALL JOINT COTE DROITE,BALL JOINT HAUT 3.4MM LOOSE ET BALL JOIN T BAS 3.1MM LOOSE ET LES SEAL SE BRISE LORS DE LA DEPOSE DONC REMPLACE
01/23/2007
WARRANTY CLAIM NUMBER: 057030 ODOMETER: 048698K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6766BA CAP ASY OIL FILLER 001 9968B 42 DOES NOT OPERATE PROPERLY
3C3Z 14A099AA SHIELD WIRING 001 MT9968
5C3Z 9C968CA FUEL PRESSURE REG 001
CVC 7A 004
REMPLACER REGULATEUR DE PRESSION D'HUILE FAIT T EST,TEMPS DE PUNCH 2.6 MT= TEMPS POUR PROBLEME INTERMITTENT
| On-line 1878
END OF OASIS REPORT FOR 1FTSX21P25EC34873
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
