Oasis Report PLEASE!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jconway, this thread has received 1 replies and been viewed 598 times.
post #1 of 2 (permalink) Old 12-19-2007, 08:44 PM Thread Starter
Exclamation Oasis Report PLEASE!!
Could someone PLEASE run an Oasis report on my 2006 F250 PSD. I am having some rear main seal issues, and need to see this! Please help me out.
Vin# 1FTSW21P66ED24418
jconway is offline
post #2 of 2 (permalink) Old 01-05-2008, 02:13 AM
OASIS RESULT:
1FTSW21P66ED24418
01/04/2008
22:13:21
FCXWS446
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/21/2006 BUILD DATE
03/16/2006 SALE MILEAGE
00039
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
12/29/2007
DEALER: Wilson Motors
WARRANTY CLAIM NUMBER: 088040 ODOMETER: 034773M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 002 10654CA 42 DOES NOT OPERATE PROPERLY
000 10654C1T
TESTED AND REPLACED BOTH BATTERIES
08/08/2007
DEALER: Payton-Wright Ford Sales, Inc.
WARRANTY CLAIM NUMBER: 491089 ODOMETER: 029341M
LABOR OP
CONDITION CODE
CONDITION DESC
RECALEM ECC PROCESSOR RECAL 000 061311A 04 SOFTWARE REVISION/FLASH MODULE
29341 TSB# 06-13-11 061311A .7 CHECKED AND VERIFIED CONCERN. PERFORMED DIES EL DIAG. CODE P0460 PRESENT. PERFORMED PINPOINT TESTS AND PERFORMED TSB# 0 6-13-11. REPROGRAMMED PCM, TCM, FICM FOR TSB. RETESTED. ALL SYSTEMS PASS. V EHICLE OPERATING NORMAL AFTER REPAIRS.
08/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
XT 6QSP 003 7000E D8 FAILED GASKET/SEAL
OSP 001
7A160 TUBE-REAR OIL PUMP I 000
29342 7A160 COND CODE D8 TK 1982 6.0L TORQSHIFT 1-LEAK DIAGNOSIS AUTOMATIC T RANSMISSION TOPPED UP FLUDI LEVEL TP INSPECT FOR LEAK SOURCE FOUND LEAK AT TRANSMISSION FILL TUBE NOTED ON INSPECTION OF TUBE LEAK CAUSED BY CONTACT W ITH AFTERMARKET EXHAUST DOWN PIPE AND CLAMP AND NO ROOM FOR FILL TUBE CORR ECT ROUTING REQUESTED CUSTOMER CORRECT EXHAUST ISSUE IN ORDER TO REPAIR CON
08/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 002 6020A D8 FAILED GASKET/SEAL
8C3Z 12K073A TRNSDC ASY-C/SHT PSN 001 12650D60
3C3Z 6020CA GASKET CYL TIMING GE 001 6007D
29341 FRONT COVER GASKET (6020) CAM SENSOR (12K073) CHECKED AND VERIFIED CO NCERN. ADDED OIL DYE AND PERFORMED OIL LEAK DIAG. FOUND OILLEAKING AT CAM S ENSOR (INTENALLY) AND LOWER LEFT CORNER OF FRONT COVER. REPLACED CAM SENSOR AND FRONT COVER GASKET. RETESTED AND TEST DROVE. NO FURTHER OIL LEAKS PRES ENT AFTER REPAIRS.
08/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
4C4Z 8592AA CONNECTION-CYL HD WA 001 8005D 42 DOES NOT OPERATE PROPERLY
VC 7B 003 9456A
29341 EGR COOLER HOSE (8592) CHECKED AND VERIFIED CONCERN. PERFORMED COOLANT PRESSURE TEST. FOUND COOLANT LEAKING AT EGR COOLER HOSE CONNECTION. REMOV ED AND REPLACED EGR COOLER HOSE AND ADDED COOLANT. RETESTED AND TEST DROVE. NO FURTHER COOLANT LEAKS PRESENT AFTER REPAIRS.
08/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9C968CA FUEL PRESSURE REG 001 9968B 42 DOES NOT OPERATE PROPERLY
000 6005E
000 6005E6
000 6005E7
000 6005E8
000 6005E2
000 6005E3
000 6005E4
29341 IPR (9C968) CHECKED AND VERIFIED CONCERN. PERFORMED HARD START DIAG. CODE P2291 PRESENT. PERFORMED PINPOINT TESTS AND FOUND IPR STICKING AT TIM ES. REMOVED AND REPLACED IPR. RETESTED AND TEST DROVE. VEHICLE OPERATING NO RMALLY AFTER REPAIRS
04/11/2007
DEALER: Texan Ford
WARRANTY CLAIM NUMBER: 390612 ODOMETER: 022358M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6007D D8 FAILED GASKET/SEAL
OSP 002 6646AH
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P66ED24418
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
