Request For Oasis Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Boaz, this thread has received 1 replies and been viewed 470 times.
post #1 of 2 (permalink) Old 12-26-2007, 11:03 PM Thread Starter
Boaz's Avatar
I am looking at an F-450 on the dealer lot VIN 1FTXW42R58EA52058.
ANy info willbe helpful. Thank You
Boaz is offline
post #2 of 2 (permalink) Old 01-05-2008, 02:51 AM
1FTXW42R58EA52058
01/04/2008
22:50:04
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-450 CREW CAB 4X2 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/21/2007 BUILD DATE
03/18/2007 SALE MILEAGE
00092
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/07/2007
DEALER: Joe Myers Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 570400 ODOMETER: 005040M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9A332B HOSE ASY (FUEL HIGH 001 MT9A332 D1 POROSITY
8C3Z 9A332A HOSE ASY (FUEL HIGH 001
5040 FUEL LEAK DIAG FOUND FUEL LINE LEAKING AT THE PUMP R&R CAB TO GET DO T HE RIGHT HAND LINE REPLACED LINES AND RETESTED ALL IS PASSED NO LEAKS ALL IS OK NOW
11/01/2007
WARRANTY CLAIM NUMBER: 569878 ODOMETER: 004981M
LABOR OP
CONDITION CODE
CONDITION DESC
F2UZ 14526P FUSE-ELECTRICAL CIRC 001 MT12651D2 42 DOES NOT OPERATE PROPERLY
000 14526A
4981 FUSE (14526) 28 WF VERIFIED TOW-HAUL BUTTON CONCERN.PERFORMED BODY -CH ASSIS-ELECTRICAL CONCERN.REPLACED FUSE 35 10 AMP IN SMART JUNCTION BOX.VERI FIED PROPER OPERATION.
11/01/2007
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 4R602HK DRV/SHFT & CPL ASY 001 071603A D9 OUT OF BALANCE
4981 DRIVESHAFT (4R602) D9 LABOR OP 071603A WF VERIFIED CONCERN FROM DRIVEL INE.REPLACED DRIVE SHAFT PER TSB 07-16-3.
10/31/2007
DEALER: Bird-Kultgen Inc
WARRANTY CLAIM NUMBER: 341442 ODOMETER: 004737M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 6753A GASKET OIL LEVEL IND 001 6007D D8 FAILED GASKET/SEAL
OSP 001 6754A
OIL EVERYWHERE, ALSO ON TAILGATE, CUSTOMER WASHED OFF. REPLACED ENGINE DI P STICK TUBE O-RING
08/20/2007
WARRANTY CLAIM NUMBER: 562809 ODOMETER: 002132M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9A332A HOSE ASY (FUEL HIGH 001 MT9A332 42 DOES NOT OPERATE PROPERLY
2132 FUEL LEAK DIAG FOUND FUEL LEAKING FROM FUEL LINE THAT RUN FROM PUMP TO RH HEAD REPLACED AND RETESTED ALL SEEMS OK NOW
08/20/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E931 GSKT A/CLNR INTAKE 000 2219D 42 DOES NOT OPERATE PROPERLY
000 2219D13
2135 WF08 9E731 42 M-TIME .3 TO REPAIR CONNECTOR PINS AT SENSOR. ROAD TESTE D VEHICLE FOR A ABS LIGHT COMING ON VERIFIED ABS LIGHT STAYS ON. CK CODES, CODES C175 AND 1237, REAR SPEED SENSOR FUALT. PIN POINT TEST, FOUND ABS CO NNECTOR C 455 PINS NOT SEATED TO SENSOR, SECURED PINS ONE AND 2 IN CONNECTO R. CLEARED CODE AND ROAD TESTED OK
| On-line 1878
END OF OASIS REPORT FOR 1FTXW42R58EA52058
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
