oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oldwestcowboy, this thread has received 4 replies and been viewed 672 times.
post #1 of 5 (permalink) Old 01-10-2008, 03:04 PM Thread Starter
oasis
howdy,
new here.
looking at a 2004 f350 43000mi
would like oasis report.
thanks
1FTSX31P84ED75497
oldwestcowboy is offline
post #2 of 5 (permalink) Old 01-11-2008, 06:08 PM
OASIS RESULT:
1FTSX31P84ED75497
01/11/2008
14:08:07
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/22/2004 BUILD DATE
06/14/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/27/2007
DEALER: Mike Castrucci Ford Lincoln Me
WARRANTY CLAIM NUMBER: 018355 ODOMETER: 039772M
LABOR OP
CONDITION CODE
CONDITION DESC
MISC FOR REPAIRS NOT COVE 000 82 FREIGHT/POSTAGE/MAINTENANCE
REIMBURSEMENT FOR RENTAL AND DEDUCTIBLE ON PREVIOUS REPAIR 17246
06/25/2007
WARRANTY CLAIM NUMBER: 017246 ODOMETER: 039118M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6006BARM ENGINE ASSY/BARE 001 6005F 42 DOES NOT OPERATE PROPERLY
XO 15W405QSD 003 6005F1
3C3Z 6731AA ELEMENT ASY OIL FILT 001 6005F1X1
VC 7B 003 6005F2
4C3Z 9P456AF COOLER - EGR 001 6005F6
3C3Z 8575AA THERMOSTAT 001 6005F8
4C3Z 9D930AA WIRING ASY-FUEL CHG 001 6005F9
5C3Z 6K854CA PIPE (TURBO INLET LO 001 6005F18
W300006 002 6005F20
W300051 006 6005F45
W300013 004 6007A
4C2Z 12A690BA WIRING ASY EC SENSOR 001 6007AZW
4C3Z 12B637CA WIRING ENG CNTRL SNS 001 6007A28
3C3Z 9P455AB SE E/G/R VLV 001 6007A34
3C3Z 6N640AA GASKET TURBO TO MANI 001 6007E
388898S 001 6007A7TA
XT 2QDX MOTORCRAFT BATTERY 001 4602AA
000 MT6051AR
DIESAL PERFORMANCE TEST COMPRESSION TEST #3 CYLINDER 30PSI, #6 280 PSI, REMO VED RIGHT CYLINDER HEAD FOUND BLOCK PISTON HEAD DAMAGE, REMOVED LEFT HEAD WA RPED AND VALVE #6 STICKING, REPLACED THE LONG BLOCK ENGINE REFILLED AND ROAD TESTED ALL O K
| On-line 1878
END OF OASIS REPORT FOR 1FTSX31P84ED75497
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
post #3 of 5 (permalink) Old 01-13-2008, 04:43 PM Thread Starter
thanks for the fast reply.
based on this report...
should i buy or run away.
it has 43000mi. and looks like a new truck.
thanks
post #4 of 5 (permalink) Old 01-14-2008, 01:20 AM
That is your call and good luck with it. You win some and loose some from my experience on used vehicles also on new vehicles. It had a long block just installed back in June of 07'.
Here is the complete warranty history from day 1 of this truck.
Standard Claims List For Model Year 2004
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 3 2E06 030008 4C3Z 9A543 AARM D02 42 2198
AWS Claim Key: 1734302 Trx Code: 2 Labor Hrs: 9.1
Dlr Cd-Sub Cd: 02066 - * Name: CHAMPION FORD OF ALEXANDRIA Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2004 Doc #:117608A
Cust Comments: CUST STATES MOMENTS AFTER FILLING UP THE TANK, THE TRUCK COMPLETELY DIED AND WILL NOT RESTART. PLEASE CHECK AND ADVISE
Tech Comments: 2198 ISNP VEH FOR NO START CRANKED ENGINE TRUCK STAR TED RIGHT UP AND RAN FINE FOR 2 3 SECONDS THEN STALLED AND WOULDNT START BACK PERFORMED PRECHECKS PASS CHECKED OIL PASS CHECKED FOR INTAKE EXHAUST RESTRICTION PASS CHECKED FUEL SAMPLE PASS CHECKED FUEL PRESS PASS CHECKED FOR INLET RESTRICTION PASS USED WDS TO CHECK KOEO PASS CMDTC PASS KOEOINJECTOR TEST PASS MONITORED
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 3 5V09 120307 4C3Z 2A451 BA C19 42 2857
AWS Claim Key: 2247893 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 02066 - * Name: CHAMPION FORD OF ALEXANDRIA Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2004 Doc #:118308A
Cust Comments: CUST STATES THAT THE AC ONLY BLOWS OUT OF THE DEFROST
Tech Comments: 2857 DIAGNOS AND REPLACE VACUUM PUMP FOR VACUUM SUPPLY. INTERMITTENTLY INOPERATIVE AND NOISEY
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 7 3T09 070603 4C3Z 7B051 FA P67 42 7028
AWS Claim Key: 3607465 Trx Code: 1 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2005 Doc #:309971A
Cust Comments: ORDER TRANSFER CASE SHIFT PARTS PER DIAGNOSIS ON RO#309959
Tech Comments: 7028 WAR REPLACED ROD PER HOT LINE AND NEUTRLIZE SHIFTER BRA , .
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 7 7M01 150101 * 18C858 * A17 42 7028
AWS Claim Key: 3557876 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2005 Doc #:309971B
Cust Comments: ORDER RADIO PER DIAGNOSIS ON RO#309959
Tech Comments: 7028 REPLACED RADIO
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 7 6R01 012001 3C3Z 28611B09 AAB S25 42 7028
AWS Claim Key: 3607466 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2005 Doc #:309971C
Cust Comments: ORDER DRIVERS SEAT BELT RETRACTOR ASSY.PER DIAGNOSIS ON RO#309959
Tech Comments: RELPACE SEAT BELT
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 7 7M01 150101 3C2T 19B132 AC A07 42 7028
AWS Claim Key: 4168099 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2005 Doc #:10296000
Tech Comments: REQUESTING DEALER'S P/A CODE 02058
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 9 5R01 110401 * 3514 * L16 42 9228
AWS Claim Key: 4406767 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:313841B
Cust Comments: CHECK FOR ONE TIME INGITION TUMBLER WOULD NOT TURN TOOK OVER ONE HOUR TO UNLOCK, CUSTOMER LUBED TUMBLER THEN IT CAME LOOSE BUT STEERING WHEEL DOES NOT LOCK WHEN IN PARK
Tech Comments: 9228 BINDING COLUM LINKAGE WARRANT R&I IGN CYL STEERING COLUM COVER CK OPP OF COLUM LOCK HAD TO REMOVE STEERING WHEEL CLOCK SPRING AND MULTIFUNCTION SWITCH DISS ASSEMBLE UPPER HALF OF COLUM FILE BURR OUT OF T TRACK FOR IGN SWITCH LINKAGE SO KEY WOULD RETURN FULLY TO OFF POSITION
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 9 3A03 * * * * * * 9247
AWS Claim Key: 4414881 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 06339 - * Name: MONTGOMERY FORD Ph: 513-8910500 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2005 Doc #:066999A
Cust Comments: OPEN RECALL 04B24
Tech Comments: 9247 04B24N 6.4 REMOVED AND INSTALLED TRANSMISSION. REPLACED REVERSE PLANITARY PER RECALL.
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 20 * * * * * * * 20226
AWS Claim Key: 8405245 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:333401A
Cust Comments: CERTAIN 6.0L EXHAUST PRESSURE SENSOR REPLACEMENT
Tech Comments: 20226 05E15 05E15G 1.3 PERFORMED RECALL 05E15
AWS Claim Key: 8405246 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:333401D
Cust Comments: PERFORM ROAD TEST RECALL
Tech Comments: 20230 59B01 59B01A .3 PERFORMED RECALL 59B01 OK AT THIS TIME
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 20 1H03 030008 5C3Z 9F452 AA D13 42 20473
AWS Claim Key: 8459494 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:06-FEB-2006 Doc #:333789A
Cust Comments: LOOKED AT VEHICLE LAST WEEK FOR STALLING, WE DID RECALLS, VEHICLE STALLED AGAIN ON SAT
Tech Comments: 20475 CK FOR ENGINE STALLS AT TIMES INSPECT,PERFORMED PERFORMANCE PERFORMANCE DIAGNOSTICS.DTCS PO299,PO404.REMOVED EGR VALVE,FOUND EXCESSIVE CARBON BUILDUP.CLEANED CARBON FROM INTAKE PASSAGES.INSTALLED NEW VALVE.R&R ICP CONNECTOR.CLEARED CODES.ROAD TEST,ENGINE IS NOT STALLING AT THIS TIME.
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 22 2G01 03XXXX 4C3Z 12B599 AARM D21 42 22936
AWS Claim Key: 9134259 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 02058 - * Name: BEECHMONT FORD INC Ph: 513-7526611 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2006 Doc #:337075A
Cust Comments: CUSTOMER STATES THAT ENGINE STALLS WILL DRIVING HAPPENS HOT AND COLD;MAY HAPPEN WHILE MAINTAINING SPEED OR EVEN TAKING OFF FROM A STOP
Tech Comments: 22965 CK FOR ENGINE STALLS INTERMITANTLY INSPECT,PERFORMED PERFORMANCE DIAGNOSTICS. CAM AND CRANK SENSOR CODES.REMOVED AIR BOX AND FICM TO INSPECT FOR ANY CHAFED WIRES.FOUND NO WIRES CHAFFED.INSTALLED A NEW FICM.PERFORMED PROGRAMMABLE MODUAL INSTALLATION.ROAD TEST. AND RE EVALUATE OK,STALLING ISSUE SEEMS TO BE RESOLVED NOW. 22936
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 23 6L04 170501 3L3Z 11661 AA L29 01 24235
AWS Claim Key: 9291874 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02066 - * Name: CHAMPION FORD OF ALEXANDRIA Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2006 Doc #:132808A
Cust Comments: CUST STATES THAT THE HEADLIGHT KNOB STEM IS BROKEN
Tech Comments: 24235 REPLACE HEADLIGHT KNOB BROKEN AND CRACKED
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 31 1D05 031003 * 6584 * L65 68 32796
AWS Claim Key: 10950196 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07463 - * Name: MIKE CASTRUCCI FORD LINCOLN MERCURY OF ALEXANDRIA, Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2007 Doc #:01184001
Cust Comments: CUST STATES THAT THERE IS A LEAK COMING FROM TRANSMISSIOM AREA, NOTICES DRIPS ON GARAGE FLOOR.
Tech Comments: TECH CHECKED AND PERFORMED ENGINE OIL LEAK DIAGNOSIS, BLACK LAMP TESTED, TIGHTENED LOOSE VALVE COVER BOLTS ON LEFT SIDE.
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 37 1A03 030008 4C3Z 6006 BARM N11 42 39118
AWS Claim Key: 11872172 Trx Code: E72 Labor Hrs: 27.2
Dlr Cd-Sub Cd: 07463 - * Name: MIKE CASTRUCCI FORD LINCOLN MERCURY OF ALEXANDRIA, Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:25-JUN-2007 Doc #:01724601
Cust Comments: CUST STATES WHILE DRIVING HEARD A NOISE AS IF RUNNING OVER R UMBLE STRIPS COMING FROM TURBO AREA THEN COMPLETE LOSS OF PO WER, BLUE SMOKE STARTED COME OUT OF EXHAUST, PLEASE CHECK AND ADVI
Tech Comments: DIESAL PERFORMANCE TEST COMPRESSION TEST #3 CYLINDER 30PSI, #6 280 PSI, REMOVED RIGHT CYLINDER HEAD FOUND BLOCK PISTON HEAD DAMAGE, REMOVED LEFT HEAD WARPED AND VALVE #6 STICKING, REPLACED THE LONG BLOCK ENGINE REFILLED AND ROADTESTED ALL O K
1FTSX31P84ED75497 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 14-JUN-2004 22-JUN-2004 147004 USA 38 6Y20 000001 * MISC * A98 82 39772
AWS Claim Key: 11927508 Trx Code: P98 Labor Hrs: 0
Dlr Cd-Sub Cd: 07463 - * Name: MIKE CASTRUCCI FORD LINCOLN MERCURY OF ALEXANDRIA, Ph: 859-4489400 St:KY Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2007 Doc #:01835501
Cust Comments: P98 RENTAL AND DEDUCTIBLE REIMBURSEMENT
Tech Comments: REIMBURSEMENT FOR RENTAL AND DEDUCTIBLE ON PREVIOUS REPAIR 17246
post #5 of 5 (permalink) Old 01-14-2008, 12:10 PM Thread Starter
thanks for the info
with a new engine, maybe it will work out.
you are right, new or used its always a gamble
thanks again
