Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by misterhom, this thread has received 1 replies and been viewed 622 times.
post #1 of 2 (permalink) Old 01-11-2008, 02:31 AM Thread Starter
Send a message via Yahoo to misterhom
Oasis Please
Hi all new to this site.Love it so far!!Need an Oasis report.
VIN 1FTWX31P95EB70192 Thanks in advance!!
misterhom is offline
post #2 of 2 (permalink) Old 01-11-2008, 06:10 PM
OASIS RESULT:
1FTWX31P95EB70192
01/11/2008
14:09:41
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/14/2005 BUILD DATE
12/18/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/03/2007
DEALER: Route 23 Auto Mall, LLC
WARRANTY CLAIM NUMBER: 247515 ODOMETER: 029527M
LABOR OP
CONDITION CODE
CONDITION DESC
4C2Z 12A690AB WIRING ASY EC SENSOR 001 6007D 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001 6642A
3C3Z 6C755AA KIT-TUB OIL FLTR 001 MT12A690
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
W302725 001
3C3Z 6619CA GASKET (OIL PUMP) 001
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
3C3Z 6C683AA FLTER-ENG OIL 001
3C3Z 6A642AA COOLER CRANKCASE OI 001
INSPECT & VERIFY SMALL OIL LEAK ALSO FOUND COOLANT BOTTLE HAS OIL IN IT. ADD DYE CLEAN & CHECK FOUND PASS SIDE GLOW PLUG HARNESS LEAKING. REPLACE HARNES S & CONTINUE TO DIAG REMOVE EGR VALVE & P REPLACE EGR & OIL COOLER BACK FLUS H ENGINE SEVERAL TIMES ROPAD TEST CHECK FOR LEAKS OK NOW
11/03/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 061706A 42 DOES NOT OPERATE PROPERLY
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001 072109A
ROAD TEST SEVERAL TIMES VERIFIED NO START CONCERN FOLLOW DIESEL DIAG SHEET E EC TEST CODES PO404 PO401 P2290 FOLLOW TSB 07-21-09 DIAG & REPLACE FAULTY EG R VALVE CHECK OPERATION OK FOR P2290 CODE VE TSB 06-17-6 FOUND HP OIL PUMP F ITTING LEAKING WHEN AIR CHECK ING INSTALL STC BRACKET KIT PER TSB REASSEMBLE & CHECK OPERATION OK. CLEAR CODES ROAD TEST OK
07/10/2007
WARRANTY CLAIM NUMBER: 239883 ODOMETER: 027757M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 061906C 42 DOES NOT OPERATE PROPERLY
3C3Z 9P455AB SE E/G/R VLV 001 062209A
VERIFIED CONCERN EEC TEST CODES PO404 P2139 FOLLOW DIESEL DIAG SHEET REMOVE EGR VALVE & FOUND CORRODED WITH CARBON CLEAN & RESTEST PER TSB 06-19-06 FA ILED. REPLACE EGR VALVE REFLASH PCM PER TSB 06-22-09 CLEAR CODES ROAD TEST O K
07/10/2007
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701A CRANKSHAFT REAR SEAL 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6D083AA GASKET-RR COVER 001 6083A
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6600A
3C3Z 6C751A KIT-VLV OIL PRESS RE 001
3C3Z 6616BA PLATE ASY OIL PUMP 001
W300024 004
XT 6QSP 001
VERIFIY OIL LEAK. CLEAN & ADD DYE CHECK FOR LEAK FOUND LEAKING FROM FRONT SE AL, PRESURE REGULATOR & REAR COVER SEAL LEAKING. REMOVE TRANS R&R REAR MAIN & REAR COVER SEALS R&R FRONT CRANK SEAL & OIL PRESURE REGULATOR THEN FOUND GOROTOR PUMP LEAKING REPLACE. RE ASSEMBLE ROAD TEST OK
03/08/2007
WARRANTY CLAIM NUMBER: 231984 ODOMETER: 024975M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6C751AA KIT-VLV OIL PRESS RE 001 MT6C751 42 DOES NOT OPERATE PROPERLY
VERIFIED FOUND OIL PRESSURE REGULATOR VALVE LEAKING. REPLACED VALUE ASSEM BLY AND ALSO FOUND BRAKE HYDRO BOOST UNIT LEAKING WHERE IT BOLTS TOGETHER, R EPLACED HYDRO BOOST UNIT CLEANED ALL OIL FROM ENGINE AND ROADTESTED RECHECKE D FOR LEAKS TESTED FINE AT THIS TIME
03/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 070504A 42 DOES NOT OPERATE PROPERLY
VERIFIED TRUCK RUNS ROUGH ON COLD STARTUP REPROGRAMMED FICM AS PER TSB 07 -5-4 RETESTED FINE AT THIS TIME
03/08/2007
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2005AA BOOSTER ASY-POWER BR 001 2005AA 42 DOES NOT OPERATE PROPERLY
F7AZ 3F823BA 003
N803256S 001
N803257S 001
REPLACED LEAKING BRAKE BOOSTER
| On-line 1878
END OF OASIS REPORT FOR 1FTWX31P95EB70192
2006 F250 XLT 6.0 CC Shortbed auto with Leer cap and fire engine red. Stock everything but running a
SCT Xcal2 tuned by Innovative Diesel. :smoke
Gillagorilla is offline
