OASIS Request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Morpheus cycles, this thread has received 1 replies and been viewed 673 times.
post #1 of 2 (permalink) Old 04-27-2008, 02:31 PM Thread Starter
Morpheus cycles's Avatar
OASIS Request
I would like one for the F550 Vin 1FDAW57P85EC70151
Thanks
Jay
11 GMC 3500 4x4 SLT Crew Cab
Dually club #78
Singles #19 Yeah I drive a Jeep too.
86 CJ7 Rebuilt from the frame up as a rockcrawler
Morpheus cycles is offline
post #2 of 2 (permalink) Old 04-27-2008, 09:33 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FDAW57P85EC70151
04/27/2008
17:32:22
FCXWS446
// for our friends in vrep var strVehDesc = "2005 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES< td> BODY STYLE
F-550 CC CHASIS 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
48 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/14/2005 BUILD DATE
03/23/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
09/17/2007
DEALER: Bison Truck Center, Inc.
WARRANTY CLAIM NUMBER: 040215 ODOMETER: 050799M PART NUMBER PART DESCRIPTION
QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC 5C3Z 9C968CA FUEL PRESSURE REG 001 6005E 42 DOES NOT OPERATE PROPERLY W302725 001 6005E2 W705589S 006 6005E4 000 6005E45 000 6584AT 000 9968B 000 VERIFY60
PERFORM NO START DIAGNOSTICS. CHECKED PCM FOR DTCS, HAD P2291 IN CM. CHEK IC P WHILE CRANKING, 298 PSI, SENSON CHECKED GOOD. CHECKED BASE OIL FLOW AS PER SSM 19417, GOOD. AIR TEST HIGH PRESSURE SYSTEM & COMMAND IPR CLOSED, LEAK T HE SAME. REMOVE BOTH ROCKER COVERS TO LOCATE LEAK. FOUND IPR SCREEN & O RING CAME OFF, INTACT IN PUMP, NO DAMAGE. REPLACE IPR, REASSEMBLE & RECHECK.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FDAW57P85EC70151 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 23-MAR-2005 14-JUL-2005 144015 USA 7 5K04 040402 * TIRE * B65 42 13359 AWS Claim Key: 3838221 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 00510 - * Name: MCCARTHY FORD Ph: 716-6522500 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2006 Doc #:09516001 Cust Comments: CHECK FRONT END, TIRES CUPPED AND PRE MATURE WEAR Tech Comments: FRONT TIRES CUPPED, UNEVEN WEAR CUSTOMER HAD FRONT END ALIGNMENT CHECKED, MOUNT AND BALANCE TWO FRONT TIRES, 1FDAW57P85EC70151 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 23-MAR-2005 14-JUL-2005 144015 USA 7 * * * * * * * 13652 AWS Claim Key: 3475980 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00572 - * Name: EMERLING FORD MERCURY INC Ph: 716-5924949 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2006 Doc #:04678440 Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT Tech Comments: PROGRAM 05B35 INSTALL DE GAS BOTTLE FILL LEVEL LABEL PER PROGRAM 05B32 1FDAW57P85EC70151 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 23-MAR-2005 14-JUL-2005 144015 USA 7 * * * * * * * 13652 AWS Claim Key: 3475981 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00572 - * Name: EMERLING FORD MERCURY INC Ph: 716-5924949 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2006 Doc #:04678441 Cust Comments: 05B35 ENGINE CONTROL MODULES RECALIBRATION Tech Comments: NOTIFICATION PROGRAM 05B35 05B35 PROGRAM PERFORMED CALIBRATED ENGINE CONTROL MODULES 1FDAW57P85EC70151 T/F7 F T/BC T/EB T/E A1 T/BE T/YB 23-MAR-2005 14-JUL-2005 144015 USA 27 2E03 0304XX 5C3Z 9C968 CA D02 42 50799 AWS Claim Key: 8615476 Trx Code: E72 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 00635 - * Name: BISON TRUCK CENTER, INC. Ph: 716-6840010 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2007 Doc #:04021551 Cust Comments: CRANK NO START TOW IN Tech Comments: PERFORM NO START DIAGNOSTICS. CHECKED PCM FOR DTCS, HAD P2291 IN CM. CHEK ICP WHILE CRANKING, 298 PSI, SENSON CHECKED GOOD. CHECKED BASE OIL FLOW AS PER SSM 19417, GOOD. AIR TEST HIGH PRESSURE SYSTEM & COMMAND IPR CLOSED, LEAK THE SAME. REMOVE BOTH ROCKER COVERS TO LOCATE LEAK. FOUND IPR SCREEN & O RING CAME OFF, INTACT IN PUMP, NO DAMAGE. REPLACE IPR, REASSEMBLE & RECHECK.
2003 F250 "Pulling Truck"
hhrecovery is offline
