Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_fast_and_furious, this thread has received 6 replies and been viewed 614 times.
post #1 of 7 (permalink) Old 04-29-2008, 03:32 AM Thread Starter
Oasis Please
vin 1FTNW21P54EC09156
Thanks
imported_fast_and_furious is offline
post #2 of 7 (permalink) Old 05-01-2008, 02:19 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 7 (permalink) Old 05-01-2008, 10:45 PM Thread Starter
Thanks
post #4 of 7 (permalink) Old 05-02-2008, 02:08 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
i dont know what happened... I tried 3 times last night and it would never post it..???? :shrug:
post #5 of 7 (permalink) Old 05-02-2008, 02:11 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FTNW21P54EC09156
05/01/2008
22:24:10
FCXWS446
// for our friends in vrep var strVehDesc = "2004 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES< td> BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/31/2004 BUILD DATE
01/16/2004 SALE MILEAGE
00100 OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
04/15/2008
DEALER: Holman Ford Lincoln Mercury -
WARRANTY CLAIM NUMBER: 229783 ODOMETER: 076044M PART NUMBER PART DESCRIPTION
QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC 4C3Z 9P456AF COOLER - EGR 001 9456A D8 FAILED GASKET/SEAL VC 7B 003 8005D OSP 001 MT9424
76052 VARIFIED CONCERN PERFORM NVH DIAG PINPOINTED NOISE TO RT SIDE OF INTAK E MANIFOLD BOLTS FOR EGR COOLER TO INTAKE MANIFOLD LOOSE RETORQUE MANIFOLD BOLTS NOISE STILL SLIGHTLY PRESENT R&R TURBO DISASEMBLE & INSPECT R&R OIL FILTER HOUSING R&R INTAKE MANIFOLD TO INSPECT EXHAUST LEAK FOUND FOUND EXHAU ST GASKET BETWEEN EGR COOLER & INTAKE MANIFOLD PARTIALY WORN AWAY ALSO FOUN
post #6 of 7 (permalink) Old 05-02-2008, 02:24 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 3 2G05 031405 * RECAL * D13 04 5208 AWS Claim Key: 1703579 Trx Code: 2 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 01330 - * Name: JOHN KENNEDY FORD-LINCOLN-MERCURY, INC. Ph: 610-4957172 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:17533901 Cust Comments: CUS STS ENG IS RUNNING ROUGH AND THEN WHEN IN PARK THE ENG WOULD LUNGE FORWARD Tech Comments: TECH CHECKED ECM PER SHEET ATTACHED..UPDATED ECM 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 3 7H06 120305 * FREON * C02 42 5208 AWS Claim Key: 1703578 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01330 - * Name: JOHN KENNEDY FORD-LINCOLN-MERCURY, INC. Ph: 610-4957172 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:17533902 Cust Comments: CUS STS THE AC IS BLOWING WARM AIR Tech Comments: CHECK AC PRESSURES LOW 28 HIGH 130 CK FOR LEAKS NONE FOUND ADDED FREON AND DYE 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 10 2G05 031405 * RECAL * D13 04 21352 AWS Claim Key: 4334511 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01273 - * Name: FRED BEANS FORD OF BOYERTOWN, INC. Ph: 610-3672081 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2005 Doc #:28429201 Cust Comments: CUSTOMER STATES THAT THE TRUCK SEEMS TO STALL OUT AT TIMES Tech Comments: CHECK STALLING VERIFIED CUSTOMER CONCERN. FOUND UPDATE FOR THE PCM. UPDATED THE PCM AND OK AT THIS TIME. 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 12 2H02 030008 5C3Z 6F089 A D10 28 26308 AWS Claim Key: 5432551 Trx Code: S07 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 01273 - * Name: FRED BEANS FORD OF BOYERTOWN, INC. Ph: 610-3672081 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:24-MAY-2005 Doc #:28771301 Cust Comments: CUSTOMER STATES THAT THE TRUCK BUCKS AND SMOKES AT HIGHWAY SPEEDS. ALSO IDLES ROUGH. Tech Comments: CHECK BUCKING ROAD TEST VEHICLE WITH CUSTOMER,TEST ON WDS KOEO,KOER, P2263,P0404,RUN DIAGNOSTICS ON POWERSTROKE CENTRAL,TEST OUT TURBO WITH MAGNET TEST, ROAD TEST WHILE MONITORING TEST VGT AS PER DIAG, REPLACE VGT SOLENOID, AND INSTALL UPDATED EBP SENSOR, UPDATE PCM WITH LATEST CALIBRATION RUN DIAG FOR P0404, REPLACE EGR VALVE AND CLEAN OUT ALL EGR PORTS IN INTAKE MANIFOLD 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 2H01 * * * * * * 33030 AWS Claim Key: 6912562 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915001 Cust Comments: RECALL 05B29 Tech Comments: RECALL 05B29 B REPLACE CAC DUCT 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 * * * * * * * 33030 AWS Claim Key: 6912561 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915002 Cust Comments: RECALL 05S34 Tech Comments: RECALL 05S34F INSPECT FICM HARNESS CHAFING INSTALL REPAIR KIT REPLACED ICP CONN. 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 7H06 NANANA 1F1Z 19E889 AB C02 01 33030 AWS Claim Key: 6912560 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915003 Cust Comments: CUST STATES ON HOT DAYS A C BLOWS WARM Tech Comments: LEAKING O RING PERFORMED DIAG TRACED TO EVAC SYSTEN AND ADD DYE RECHAGED AN TEST FOR LEAKS. O RING AT COMPRESSOR LEAKING REPLACED AND RETEST OK 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 1H03 030008 4C3Z 9F452 A D21 42 33030 AWS Claim Key: 6912559 Trx Code: S07 Labor Hrs: 6
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915005 Cust Comments: CUST STATES RPMS FLUCTUATE AND STALLS AT STOPS Tech Comments: EGR VALVE ENGINE STALLS IDLE FLUCTUATES KOEO KOER P0401 404 2269 PERF. DIAG LOW IDLE STAB, PASS CRANK PSI OK EXH REST OK BOOST PSI FAILS 9PSI FUEL CONT OK INTAKE REST OK FUEL PSI OK FUEL INLET REST OK EGR POS FAIL FUEL ERIATION OK IPR OK PINPOINT TEST FOR EGR FAILURE FOUND TOP OF EGR VALVE BROKEN AND WATER 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 * * * * * * * 33030 AWS Claim Key: 6912558 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915006 Cust Comments: RECALL 05E15 Tech Comments: RECALL 05E15G REPLACED EP SENSOR EP CONNECTOR AND RECAL CONTROL MODULES 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 16 * * * * * * * 33030 AWS Claim Key: 6912557 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2005 Doc #:20915007 Cust Comments: RECALL 59B01 Tech Comments: RECALL 59B01A CUST OMER ASSURANCE DRIVE TEST 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 18 7S02 180101 5C3Z 14A411 A D42 X2 35960 AWS Claim Key: 7587794 Trx Code: E83 Labor Hrs: 6
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:21169501 Cust Comments: CUST STATES WHEN ACCEL ENGINE WAS BOGGING OUT WAS BLOWING A LOT OF SMOKE ALSO Tech Comments: FAULTY EGR VALVE CONNECTOR AS PER SSM 18846 BLOWS SMOKE VERIFIED CONCERN BOGGS DOWN DIESEL PERF. DIAG KOEO P0404,P1335 KOER LOW IDLE,ICP TEST, CRANK PSI TEST EXHAUST RESTR. TEST PASS. BOOST PSI LOW BOOST. FUEL CONTAM. INTAKE RESTR. PASS FUEL PUMP PSI 55 PSI PASS. FUEL INLET RES PASS EGR POS. FAILED. FUEL AER, IPR TEST PASS. OIL AER. PASS VGT TEST PASS. CHECKED WIRING AT EGR VALVE FOUND FAULTY 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 18 7H06 NANANA 1F1Z 19E889 AB C01 01 35960 AWS Claim Key: 7587793 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:21169503 Cust Comments: CUST STATES A C BLOWS WARM Tech Comments: LEAKING O RING PERFORMED DIAG TRACED TO A C DIAG CKED FOR LEAKS EVAC SYSTEM FOUND O RING AT COMPRESSOR LEAKING. REPLACED O RING AND RECHARGED SYSTEM; RETEST OK 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 19 1H03 030804 4C3Z 9P456 AC L87 30 38130 AWS Claim Key: 8024018 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 01350 - * Name: NORRISTOWN AUTOMOBILE COMPANY, INC. Ph: 610-5395400 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:08-DEC-2005 Doc #:21350601 Cust Comments: CUSTOMER STATES: THE ANTIFREEZE LEVEL IS LOW AND THE VEHICLE SMELLS LIKE THERE IS A LEAK. THERE IS ALSO WHITE SMOKE FROM THE TAILPIPE. Tech Comments: EGR COOLER VERIFIED WHITE SMOKE FROM EXHAUST PRESSURE COOLANT SYSTEM REMOVED EGR VALVE AND CK FOR COOLANT IN INTAKE. COOLANT IS PRESENT, REINSTALLED EGR VALVE. R R FAN SHROUD TURBO INTAKE AND LEAKING EGR COOLER. REPLACED EGR COOLER AND RETEST OK 1FTNW21P54EC09156 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-JAN-2004 31-MAY-2004 116421 USA 48 1H03 030804 4C3Z 9P456 AF D50 D8 76044 AWS Claim Key: 12595535 Trx Code: E72 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 02848 - * Name: HOLMAN FORD LINCOLN MERCURY - TURNERSVILLE Ph: *-* St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:15-APR-2008 Doc #:229783A Cust Comments: CUST STS THE TURBO IS MAKING A LOUD WHINING SOUND ON ACCELLERATION Tech Comments: 76052 VARIFIED CONCERN PERFORM NVH DIAG PINPOINTED NOISE TO RT SIDE OF INTAKE MANIFOLD BOLTS FOR EGR COOLER TO INTAKE MANIFOLD LOOSE RETORQUE MANIFOLD BOLTS NOISE STILL SLIGHTLY PRESENT R&R TURBO DISASEMBLE & INSPECT R&R OIL FILTER HOUSING R&R INTAKE MANIFOLD TO INSPECT EXHAUST LEAK FOUND FOUND EXHAUST GASKET BETWEEN EGR COOLER & INTAKE MANIFOLD PARTIALY WORN AWAY ALSO
post #7 of 7 (permalink) Old 05-02-2008, 04:35 PM Thread Starter
Thanks hhrecovery now what do you guys think aobut this oasis? Buddy of mine just bought this truck so hopfully he didnt get a bad one.
thanks
