Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AndrewCJohnston, this thread has received 1 replies and been viewed 646 times.
post #1 of 2 (permalink) Old 04-29-2008, 03:53 AM Thread Starter
Oasis Report Please
Hi, I am about to purchase a 2005 Excursion with the 6L. Could someone please run an Oasis report for me?
VIN: 1FMSU45P05EA74518
Thank you in advance!!
Andrew
AndrewCJohnston is offline
post #2 of 2 (permalink) Old 05-01-2008, 02:22 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FMSU45P05EA74518
04/30/2008
22:21:53
FCXWS447
// for our friends in vrep var strVehDesc = "2005 EXCURSION"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION< td> BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/09/2004 BUILD DATE
09/21/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 11 5G05 040001 * FRONT * H24 W6 8344 AWS Claim Key: 1643239 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:04799153 Cust Comments: STEERING IS OFFCENTER. Tech Comments: ROADS TEST VERIFY COMPLAINT CHECK ALIGHNMENT SET CASTER CAMBER TOE ONE SIDE.ROAD TEST OK AT THIS TIME.SEE SHEET FOR DETAILS. 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 11 5K04 040402 * ALBAL * N25 D9 8344 AWS Claim Key: 1643240 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:04799154 Cust Comments: CUSTOMER STATES THAT HE FEELS A VIBRATION 69 MPH AND ABOVE. Tech Comments: .ROAD TEST VERIFY COMPLAINT MEASURE RIM RUN OUT..004 ALL RIMS INDEX 3 TIRES 2 FRONT AND 1 REAR BALLANCE 1 REAR TIRE.ROAD TEST OK AT THIS TIME. 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 17 * * * * * * * 17979 AWS Claim Key: 3863741 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2006 Doc #:06982540 Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A Tech Comments: RECALL PERFORM 05E15M AS STATED 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 17 * * * * * * * 17979 AWS Claim Key: 3863742 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2006 Doc #:06982541 Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO Tech Comments: RECALL PERFORM 59B01 ROAD TEST 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 17 * * * * * * * 17979 AWS Claim Key: 3863743 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-MAR-2006 Doc #:06982542 Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT Tech Comments: INSTALL DEGAS BOTTLE LABEL PER RECALL 05B32 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 18 2H01 031202 * 6K769 * L65 42 18894 AWS Claim Key: 4197347 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:07255653 Cust Comments: INTAKE TUBE IS LEAKING OIL Tech Comments: VERIFY CONCERN REMOVE LEFT SIDE INTERCOOLER INTAKE TUBE CLEAN AND RETORQUE VERIFY REPAIR 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 28 1H03 030008 5C3Z 9F452 AA E29 55 24971 AWS Claim Key: 6886607 Trx Code: S07 Labor Hrs: 8.3
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:208852B Cust Comments: ROADSIDE TOW IN CHECK ENGINE LIGHT IS ON; NO OTHER INFO GIVEN Tech Comments: 24981 . 1 15, , .0404 . 06 19 06. , . , . 1FMSU45P05EA74518 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 21-SEP-2004 09-OCT-2004 124014 USA 28 7H08 120403 5C7Z 19980 AB C20 42 24971 AWS Claim Key: 6886608 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:208852D Cust Comments: CUST STATES ELECTRONIC AIR TEMP CONTROL HEAD SHUTS OFF INTERMITENTLY; Tech Comments: 24971 . . , .
2003 F250 "Pulling Truck"
hhrecovery is offline
