OASIS Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by billys90, this thread has received 3 replies and been viewed 656 times.
post #1 of 4 (permalink) Old 04-30-2008, 09:21 PM Thread Starter
OASIS Report Please
2003 F350 VIN 1FTSW31PX3EC26350
Thanks, Billy
billys90 is offline
post #2 of 4 (permalink) Old 05-05-2008, 12:09 AM Thread Starter
Can anybody help me on getting an Oasis report? Thanks in advance.
billys90 is offline
post #3 of 4 (permalink) Old 05-05-2008, 02:36 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FTSW31PX3EC26350
05/04/2008
22:36:24
FCXWS446
// for our friends in vrep var strVehDesc = "2003 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES< td> BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/12/2003 BUILD DATE
02/04/2003 SALE MILEAGE
00004 OUTSTANDING FIELD SERVICE ACTIONS
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 5 2G05 * * * * * * 2705 AWS Claim Key: 1802733 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00994 - * Name: CROSSROADS FORD LINCOLN MERCURY OF MORGANTON, INC Ph: 828-5844600 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2003 Doc #:203728A Cust Comments: WHEN TAKING OFF HAS NO POWER AT TIMES Tech Comments: COMPLETE RECALL 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 5 2B01 030008 3C3Z 12K073 AA D36 42 2705 AWS Claim Key: 1832667 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 00994 - * Name: CROSSROADS FORD LINCOLN MERCURY OF MORGANTON, INC Ph: 828-5844600 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2003 Doc #:203728B Cust Comments: WHILE DRIVING STAEDY SPEED JUMPS AND JEIRKS Tech Comments: DIESEL DIAGNOSTICS, PIN POINT, WIGGLE TST WIRES WHILE MONITORING DATALOGGER.. SHORT TO POWER, GROUND, OPENS OK.. RMOVE CMP SENSOR FOUND TIP LOSE . REPLACE AND RETEST, ROAD TEST 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 12 2E06 030008 3C3Z 9E527 AE D13 42 8573 AWS Claim Key: 4780711 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 00994 - * Name: CROSSROADS FORD LINCOLN MERCURY OF MORGANTON, INC Ph: 828-5844600 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2004 Doc #:212819A Cust Comments: CHECK ROUGH IDLE Tech Comments: PERFORMANCE DIAGNOSTICS, PIN POINT, REMOVE PASS VALVE COVER, REPLACE NUM 7 INJECTOR, RETEST REPROGRAM 3 MODULES 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 19 2G01 * * * * * * 12224 AWS Claim Key: 7938699 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01065 - * Name: LARRY SCHRONCE FORD, INC. Ph: 828-6322002 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2004 Doc #:07517601 Cust Comments: SAFTEY RECALL 03L12 Tech Comments: PERFORM RECALL 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 19 1A03 030100 * 6006 * D50 42 12224 AWS Claim Key: 7938700 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01065 - * Name: LARRY SCHRONCE FORD, INC. Ph: 828-6322002 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2004 Doc #:07517602 Cust Comments: CHECK FOR LACK OF POWER AT TIMES POOR FUEL MILAGE Tech Comments: WDS TEST UPDAR PCM TCM 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 19 * * * * * * * 12224 AWS Claim Key: 7938701 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01065 - * Name: LARRY SCHRONCE FORD, INC. Ph: 828-6322002 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:30-SEP-2004 Doc #:07517603 Cust Comments: SAFTEY RECALL 04S15 Tech Comments: PERFORM RECALL 1FTSW31PX3EC26350 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 04-FEB-2003 12-MAR-2003 121705 USA 31 2H01 030008 3C3Z 6K682 AARM D50 42 19798 AWS Claim Key: 12132141 Trx Code: S07 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 01065 - * Name: LARRY SCHRONCE FORD, INC. Ph: 828-6322002 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:08194201 Cust Comments: CHECK FOR NO POWER AT TIMES Tech Comments: SCAN NO CODES UPDATE PCM TCM MOINTOR TURBO P105 VG PTC RPM MANUALLY CONTROL TURBO AT TIDLE SHOWING 85 PERCENT REPLACE SOLENOID ROAD TEST NO POWER WDS UNABLE TO UPDATE FICM REPROGRAM FICM ROAD TEST NO POWER OVERBOOST EGR VALVE POPPING OPEN
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 4 (permalink) Old 05-05-2008, 03:10 AM Thread Starter
Thank you hhrecovery
billys90 is offline
