Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AndrewCJohnston, this thread has received 1 replies and been viewed 650 times.
post #1 of 2 (permalink) Old 05-01-2008, 02:54 AM Thread Starter
Oasis Report Please
Thank you for the last Oasis report, but I did not get that excursion...it sold one day before I called. Arrrrh!!!! However, I found another one! So this should be my last request for an Oasis report as the dealer accepted my offer. As long as the Oasis is fairly clean...its all mine!!!
VIN: 1FMSU45P65EB69570
Thanks a million!!!!
Andrew
AndrewCJohnston is offline
post #2 of 2 (permalink) Old 05-02-2008, 02:20 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FMSU45P65EB69570
05/01/2008
22:19:50
FCXWS446
// for our friends in vrep var strVehDesc = "2005 EXCURSION"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION< td> BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/26/2005 BUILD DATE
12/16/2004 SALE MILEAGE
00016 OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 1 7D05 170104 5C3Z 15200 BA L29 49 687 AWS Claim Key: 492651 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:18184301 Cust Comments: CUSTOMER STATES THE DRIVERS SIDE DRIVING LIGHT HAS WATER IN IT AND BULB IS DISCOLERED Tech Comments: CONFIRM CUSTOMERS CONCERN AND REMOVE ND REPLACE FOG LAMP ASSEMBLY 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 3 6L11 011202 * 78045A36 * B95 33 1679 AWS Claim Key: 940964 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2005 Doc #:18736601 Cust Comments: CUSTOMER STATES THE CENTER CONSOLE RATTLES SEESM TO HAVE ONE BUMPER MISSING Tech Comments: CHECK AND CONFIRM RATTLE INSTALL RUBBER BUMPERS FOR CENTER C ONSOLE REROAD TEST OK 1 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 12 * * * * * * * 9126 AWS Claim Key: 3666306 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:20618201 Cust Comments: CS: PERFORM RECALL 05E15 Tech Comments: 1 PERFORMED AS OUTLINED 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 12 2E05 100106 6C3Z 9B249 A D42 42 9126 AWS Claim Key: 3666305 Trx Code: 1 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:20618202 Cust Comments: CS: VEHICLE FELT LIKE IT WAS GOING TO STALL OUT THE OTHER DA Y Tech Comments: ROADTESTED VEHICLE DID NOT DUPLICATE OR VERIFY STALLING CONCERN INSTALLED WDS AND PERFORM DIESEL DIAG RETRIEVED CODE P1139 P2269 PERFORMED DIAG AND DRAINED FUEL FOUND NO WATER IN FUEL CHECKE R&R HEATER ASSY AND WIRING ASSY AND RECHECK OK AT THIS TIME 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 12 * * * * * * * 9126 AWS Claim Key: 3666304 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:20618205 Cust Comments: PERFORM RECALL 59B01 Tech Comments: RECALL RECALL COMPLETE 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 12 * * * * * * * 9126 AWS Claim Key: 3666303 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:20618206 Cust Comments: PERFORM RECALL 05B32 Tech Comments: RECALL RECALL COMPLETED 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 20 2H01 030407 4C3Z 6K682 ARM D42 42 15167 AWS Claim Key: 6054059 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2006 Doc #:22236801 Cust Comments: CUSTOMER STATES CK ENGINE LIGHT COMES ON WHILE DRIVING CK AND ADVISE Tech Comments: VERIFIED CUSTOMER CONCERN VERIFIED LACK OF POWER INSTALLED WDS AND FOUND CODE P0299 CHECKED OASIS AND FOUND TSB 06 18 3 PERFORMED PINPOINT TEST DATA LOGGER PIDS VQT COMMAND AT 85% MGP WORKING FOUN REMOVED TURBO CHARGE DIASSEMBLED CLEANED TURBO REINSTALLED TURBO RECHECK FOUND WITH VGT COMMAND AT 85% REMOVED TURBO AND ISNTALLED NEW TURBO RECHECK OK 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 23 2H01 030407 4C3Z 6K682 CBRM L65 42 17465 AWS Claim Key: 6852067 Trx Code: E91 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2007 Doc #:22835901 Cust Comments: CS: CK FOR LEAK AT THE TOP OF THE ENGINE INSTALLED DYE Tech Comments: USED BLACKLIGHT TO PINPOINT LEAK FOUND LEAK FROM REAR TOP OF ENGINE REMOVED TURBO WHERE VGT PLUG IS COCKED IN TURBO LEAKING FROM O RING AND FOUND PLUG CHIPPED R&R TURBO ASSY CLEANED AND RECHECKED OK 1FMSU45P65EB69570 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 16-DEC-2004 26-FEB-2005 113155 USA 23 1H03 030008 5C3Z 9F452 AA D42 42 17726 AWS Claim Key: 6874115 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04113 - * Name: ROUTE 23 AUTO MALL, LLC Ph: 973-8380800 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2007 Doc #:22856801 Cust Comments: CUSTOMER STATES CK ENGINE LIGHT COMES ON WHILE DRIVING CK AND ADVISE Tech Comments: VERIFIED CK ENGINE ON EGR VALUE FAILED CHECKED TSB 06 19 6 CLEANED VALUE REPLACED EGR VALVE AND RETESTED AND REPROGRAMMED THE PCM AND ROADTESTED FINE AT THIS TIME
2003 F250 "Pulling Truck"
hhrecovery is offline
