oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by B mullins, this thread has received 2 replies and been viewed 448 times.
post #1 of 3 (permalink) Old 05-01-2008, 11:17 AM Thread Starter
oasis report please
My vin # is 1FTNW21P04ED05888
Thanks in advance
Bryon
B mullins is offline
post #2 of 3 (permalink) Old 05-02-2008, 02:17 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FTNW21P04ED05888
05/01/2008
22:15:03
FCXWS446
// for our friends in vrep var strVehDesc = "2004 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES< td> BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/30/2004 BUILD DATE
04/02/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY Standard Claims List For Model Year 2004
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 6 7P01 110501 4C3Z 13K359 AAA A85 42 7300 AWS Claim Key: 4183463 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:00739501 Cust Comments: BRAKE TURN & HAZARD LIGHTS NOT WORKING Tech Comments: STEERING COLUMN SWITCH ASSEMBLIES DIAGNOSIS AND R&I NEW MULTI FUNCTINSWITCH ASSEMBLY 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 6 3A03 * * * * * * 7602 AWS Claim Key: 4322677 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:00747301 Cust Comments: RECALL04B24 Tech Comments: R&I INPSECT AND REPLACE REAR PLANET ONLY AND REPLACED TORQUE CONVERTER NUTS AND ADDED FLUID AND TEST DRIVE 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 6 3A11 070100 * 7000 * L72 D8 7657 AWS Claim Key: 4393045 Trx Code: 2 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:19-MAR-2005 Doc #:00750901 Cust Comments: CHECK FOR FLUID LEAK AT BACK OF OIL PAN Tech Comments: R&I TRANSMISSION AND MOUNT ON BENCH AND FILL WITH FLUID AND TEST DRIVE 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 6 3A06 070101 3C3Z 7A248 AA L72 D8 7657 AWS Claim Key: 4393046 Trx Code: 2 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:19-MAR-2005 Doc #:00750902 Cust Comments: AUTOMATIC TRASMISSION SEAL FRONT PUMP OR CONVERTOR REPLACE Tech Comments: REPLACED PUMP GASKET PUMP O RING SEAL AND REPLACED PUMP TO CONVERTOR SEAL 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 11 * * * * * * * 15684 AWS Claim Key: 6328453 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2005 Doc #:00876901 Cust Comments: RECALL 05S34 Tech Comments: INSPECT FICM WIRE HARNESS FOR PART NUMBER CHAFING INSTALL FICM REPAIR KIT AND INSTALL ICP CONNECTOR KIT 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 11 2G04 031401 * 12A650 * D36 42 15684 AWS Claim Key: 6328454 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2005 Doc #:00876902 Cust Comments: ENGINE SURGES AND BUNS ROUGH AT TIMES Tech Comments: REPTROGRAM PROCESSOR AFTER CHECKING FOR CODES 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 13 * * * * * * * 18525 AWS Claim Key: 7180812 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:00929101 Cust Comments: RECALL 05E15 Tech Comments: REPLACE EP SENSOR EP CONNECTOR AND RECAL CONTROL MODULES 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 13 * * * * * * * 18525 AWS Claim Key: 7180813 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07219 - * Name: ARNIE'S FORD-MERCURY, INC. Ph: 402-3753780 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:00929102 Cust Comments: RECALL 59B01 Tech Comments: CUSTOMER ASSURANCE TEST DRIVE 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 21 1H03 030008 4C3Z 9F452 A D41 42 22972 AWS Claim Key: 9646900 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 09927 - * Name: GREGG YOUNG FORD, INC. Ph: 402-3722497 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2006 Doc #:13006201 Cust Comments: ENGINE SURGES AT STEADY SPEEDS. Tech Comments: WDS AND OTHER TESTS FOUND EGR VALVE THAT WAS STICKING OPEN. REPLACED VALVE RETEST OK NOW. 1FTNW21P04ED05888 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 02-APR-2004 30-SEP-2004 158427 USA 23 2H01 030008 4C3Z 6K682 BA D42 42 23838 AWS Claim Key: 9961204 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 09927 - * Name: GREGG YOUNG FORD, INC. Ph: 402-3722497 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2006 Doc #:13017901 Cust Comments: CUSTOMER STATES LOW ON POWER. Tech Comments: TESTS FOUND LOW BOOST AT TIMES.TESTED VGT AND TURBO, FOUND THAT TURBO WOULD STICK THEN HAD LOW BOOST. CLEANED VGT,NO CHANGE. REPLACED TURBO.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 3 (permalink) Old 05-02-2008, 02:36 AM Thread Starter
Thanks HH. It looks like i bought a problem child. Wow.. they have already replaced the turbo on it. Explains why it had on 24k when I bought it.
