OASIS Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jbofsd, this thread has received 9 replies and been viewed 782 times.
post #1 of 10 (permalink) Old 05-01-2008, 02:39 PM Thread Starter
OASIS Report Please
Can you please pull an Oasis on my truck
VIN# - 1FTSW31P93EC19857
Thank you very much.
Bill
Jbofsd is offline
post #2 of 10 (permalink) Old 05-02-2008, 02:13 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
1FTSW31P93EC19857
05/01/2008
22:12:39
FCXWS446
// for our friends in vrep var strVehDesc = "2003 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES< td> BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
CUDL - THIS VEHICLE HAS AN OPEN CUDL CONTACT
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04 GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/19/2003 BUILD DATE
02/02/2003 SALE MILEAGE
00013 OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND EXTENDED COVERAGES
0759 - USA 2002 NEW 72/75,000 PREMIUMCARE W/ROADSIDE ASSIST.
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: SALVATORE COCO
OPTIONS:
EXPIRATION DATE: 02/19/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 05513
ESP CONTRACT START DATE: 02/19/2003
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
THE ROAD HAZARD TIRE COVERAGE BENEFIT EXTENDED TO ELIGIBLE FORD MOTOR
COMPANY VEHICLES IS ONLY IN EFFECT DURING THE TERM OF THE NEW VEHICLE
LIMITED WARRANTY. WARRANTY REPAIR HISTORY
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 10 (permalink) Old 05-02-2008, 02:14 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 5 7S05 140103 * 14301 * A85 07 5952 AWS Claim Key: 1596649 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:44391002 Cust Comments: CUSTOMER STATES ONE OF THE BATTERY CABLES IS SITTING ON AIR INTAKE CAUSING WIRE TO MELT. CK & ADVISE.... Tech Comments: REROUTE WIRE TO ALTERNATOR AWAY FROM INTAKE TUBE 1 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 5 2E01 * * * * * * 5952 AWS Claim Key: 1596648 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:44391003 Cust Comments: PERFORM RECALL 03B05 FOR INJECTOR CONTROL PRESSURE SENSOR... (CUST HAS BEEN INFORMED PER CHRIS FLOYD TO BRING BOTH Tech Comments: REPLACE ICP SENSOR REPLACE ICP SENSOR PER RECALL 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 5 2G05 * * * * * * 5952 AWS Claim Key: 1596647 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:44391004 Cust Comments: PERFOR RECALL 03B06 COLD CALIBRATION Tech Comments: REPROGRAM PCM REPROGRAM PCM PRE RECALL 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 5 * * * * * * * 5952 AWS Claim Key: 1596646 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:44391005 Cust Comments: PERFORM OIL CHANGE UNDER RECALL 57B98 Tech Comments: LOF CHANGED DIESEL ENGINE OIL AND FILTER. ..... 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 5 2E06 030008 3C3Z 9E527 AE E29 42 5952 AWS Claim Key: 1614617 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:19-JUN-2003 Doc #:44391008 Cust Comments: ENGINE LIGHT CAME ON, NOT ON AT THIS TIME, CHECK AND ADVISE Tech Comments: ROAD TEST TO VERIFY CONCERN RETRIVE CODES PO273 CYL 5 BALANC E,CLEAR CODE AND RUN INJECTOR ELECTRICAL TEST PO273 CYL 5 REMOVE OIL RAIL AND REPLACE #5 INJECTOR.REASSEMBLE RECHARED A C AND ROAD TEST TO VERIFY REPAIR. 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 21 1H03 030008 3C3Z 9J460 AA E29 42 24484 AWS Claim Key: 8296802 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2004 Doc #:51618301 Cust Comments: DIAG DIESEL ENG NOIS Tech Comments: DE P2263 PERFORM 2263 ENHANCED PERFORMANCE TEST REPERFORMANCE DIAGNOSTIC 1 15 KOEO PASS CONTINUOS COFLUTTER NOISE IS NORMAL SSM 18155TECH 116MOVE AND REPLACE EBP ROAD TEST RETEST SYSTEM PASS 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 21 * * * * * * * 24484 AWS Claim Key: 8276873 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2004 Doc #:51618302 Cust Comments: DIESEL RECALL Tech Comments: PERFORM RECALL 03E03 REPROGRAM TCM PCM AND FICM 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 21 * * * * * * * 24484 AWS Claim Key: 8276874 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2004 Doc #:51618303 Cust Comments: PERFORM RECALL Tech Comments: PERFORM RECALL 04S15 REPLACE NEGITIVE BATTERY TERMINAL 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 27 1D01 03XXXX 3C3Z 6701 AA L65 D1 28969 AWS Claim Key: 11010341 Trx Code: E84 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2005 Doc #:53481901 Cust Comments: DIESEL LINE DEPARTMENT.... Tech Comments: OIL LEAK DIAGNOSIS WITH OIL DYE AND BLACK LIGHT FOUND REAR MAIN SEAL LEAKING REMOVE TRANSFER CASE AND TRANSMISSION AND FLEX PLATE REMOVE AND REPLACEREAR MAIN SEAL REASSEMBLE ENGINE AND ROAD TEST CHECK FOR LEAKS NO LEAKS FOUND TECH 116 CONDITION CODE D1 BA 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 37 5S01 030008 3C3Z 9G270 AA E68 D1 34544 AWS Claim Key: 13171098 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-FEB-2006 Doc #:56419002 Cust Comments: DIESEL LINE DEPARTMENT: CUST STATES VEHICLE IS Tech Comments: DIAGNOSIS FUEL LEAK FOUND FUEL FILTER CAP LEAKINGREMOVE AND REPLACE FUEL FILTER CAP ROAD TEST OK TECH 116 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 42 * * * * * * * 38085 AWS Claim Key: 14160229 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2006 Doc #:57853903 Cust Comments: 06E17 ENGINE CONTROL MODULE CALIBRATION Tech Comments: REPROGRAMED ALL MODULES 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 42 * * * * * * * 38085 AWS Claim Key: 14139988 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUL-2006 Doc #:57853904 Cust Comments: 59B01 ROAD TEST Tech Comments: ROAD TEST OK 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 45 2H01 031202 3C3Z 6K775 AA D41 D1 38734 AWS Claim Key: 14529138 Trx Code: E72 Labor Hrs: 9.8
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2006 Doc #:58760803 Cust Comments: DIESEL LINE DEPARTMENT Tech Comments: CHECKED FOR CODES FOUND P2263.,. USED SMOKE MACHINE TO PINPOINT POSSIBLE LEAK, FOUND LEAK COMING FROM INTERCOOLER, NEEDS INTERCOOLER. REMOVED FRONT END OF VEHICLE AND CAC TUBES AND REPLACED INTERCOOLER AND REASSEMBLED. ROAD TESTED VEHICLE FOUND VEHICLE OV 1FTSW31P93EC19857 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-FEB-2003 19-FEB-2003 171105 USA 50 2E06 030008 3C3Z 9F838 EA D21 42 42408 AWS Claim Key: 15047787 Trx Code: E72 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 05513 - * Name: CITRUS FORD Ph: 909-3900930 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-MAR-2007 Doc #:60391102 Cust Comments: DIESEL LINE DEPARTMENT: CUST STATES VEHICLE WILL Tech Comments: PREFORMED DIESEL DIAG 6.0L. FOUND KOEO AND KOER P2290, AND P2285. CHECKED OIL FOLLOWED POINPOINT TEST Q2. FOUND FAULTY ICP SENSOR. REPLACED ICP SENSOR REMOVED TRANS SHEILD. CLEARED CODES, RETESTED, PSS. TECH 515
post #4 of 10 (permalink) Old 05-02-2008, 10:32 PM Thread Starter
Can someone clear this up....I am renting this vehicle from the Owner listed on the Oasis....The truck would still be covered under the ESP..
Thank you,
Jbofsd is offline
post #5 of 10 (permalink) Old 05-03-2008, 02:22 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
doesn't look like anything major ever wrong... what more are you wanting cleared up??
post #6 of 10 (permalink) Old 05-03-2008, 12:08 PM Thread Starter
I just had to take it in to have 2 injectors and a glow plug module replaced. And had to pay for it.. when it looks like it should have been covered.
Jbofsd is offline
post #7 of 10 (permalink) Old 05-04-2008, 01:24 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
You are past your 3y/36k mile and 5y/100k mile factory warranty
post #8 of 10 (permalink) Old 05-04-2008, 02:23 AM Thread Starter
What about the ESP that says 6yr/75,000 mile warranty...and expires 2/2009. That is the Extended Service Plan.....correct...and should cover the injectors?
Jbofsd is offline
post #9 of 10 (permalink) Old 05-05-2008, 02:32 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
you are correct, I believe they should have covered it... You need to talk to the dealer that did it and make sure they realized that you had the Extended coverage..
post #10 of 10 (permalink) Old 05-05-2008, 10:14 PM Thread Starter
This site was so helpful. I just had to take current registration in to prove the current owner is the guy listed on the Oasis Report. Then once I buy the truck pay $50 and have the ESP transfered until February...what a deal...Thank you all for your help....
Jbofsd is offline
