Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rwhite, this thread has received 2 replies and been viewed 463 times.
post #1 of 3 (permalink) Old 05-05-2008, 01:21 AM Thread Starter
Oasis Please
2 trucks I'm looking at
96 250 - 1FTHX26FXTEA87955
02 250 - 1FTNX21FX2ED35157
Thanks.
#23 B.O.M.B. Squad[/B]
rwhite is offline
post #2 of 3 (permalink) Old 05-05-2008, 01:24 AM Thread Starter
never mind the 96
Thanks.
rwhite is offline
post #3 of 3 (permalink) Old 05-05-2008, 02:34 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
OASIS RESULT:
1FTNX21FX2ED35157
05/04/2008
22:33:56
FCXWS446
// for our friends in vrep var strVehDesc = "2002 F-SERIES"; function getVehDesc() { return strVehDesc; } VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES< td> BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF M6HD-C 6-SPEED AXLE CODE
ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN ARN MESSAGES GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/10/2002 BUILD DATE
05/23/2002 SALE MILEAGE
00018 OUTSTANDING FIELD SERVICE ACTIONS
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles) 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 19 2E06 030008 2C3Z 9G804 AA L65 33 30665 AWS Claim Key: 8673986 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03149 - * Name: TOM YOUTZ FORD, LINCOLN-MERCURY Ph: 307-8562254 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2003 Doc #:06064551 Cust Comments: ENGINE OIL LEAK. Tech Comments: LOOSE ENGINE OIL LEAKS DIAGNOSIS 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 20 7B02 140201 2C3Z 10346 BARM D02 46 30833 AWS Claim Key: 8673987 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03149 - * Name: TOM YOUTZ FORD, LINCOLN-MERCURY Ph: 307-8562254 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:02-JAN-2004 Doc #:06069951 Cust Comments: CUST. KEEPS HAVING TO JUMP START VEHICLE TO GET STARTED. Tech Comments: BURNED OUT BATTERY TEST, CHARGE, AND RE TEST 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 54 1B03 030204 1C3Z 6A642 AA D50 D8 79891 AWS Claim Key: 15814650 Trx Code: E72 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 03149 - * Name: TOM YOUTZ FORD, LINCOLN-MERCURY Ph: 307-8562254 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2006 Doc #:07691651 Cust Comments: CUSTOMER IS SEEING ENGINE OIL IN THE COOLING SYSTEM. Tech Comments: (3 TIMES) FLUSH WITH CLEAN WATER, ADD COOLANT TO SYSTEM TEST DRIVE AFTER REPAIRS. OK. 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 57 7C06 030008 2C3Z 14A163 AB D13 42 83806 AWS Claim Key: 15956368 Trx Code: E72 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 03172 - * Name: GLENWOOD SPRINGS FORD-LINCOLN-MERCURY, INC. Ph: 970-9452317 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-JAN-2007 Doc #:18871001 Cust Comments: CUSTOMER STATES THAT ENGINE SPUTERS RUNNING ROUGH. CHECK ENGINE LIGHT COMES ENGINE WILL DIE THEN TAKES ABOUT 20 MINUTES TO RESTART. Tech Comments: TEST DROVE VEH SEVERAL TIMES UNABLE TO DUPLICATE CONCERN, PERF DI DIAG 1 7 USED IDS TO RET CODES MON. PIDS FOUND CODES FOR IDM AND CAM SENSOR ABNORMAL DIAG HEAT SOAK VEH RUN KOEO INJ BUZZ TEST FINALL REM CAC TUBES, BOTH VALVE COVERS, INSTALLED UVC HARNESS RETAINER CLIPS, CLEARED CODES TEST DROVE SEVERAL MILES VEH OPERATES AS INTENDED. CP# 14A163 CC# 42 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 57 2G01 031401 XC3Z 12B599 AA D42 42 84053 AWS Claim Key: 15990840 Trx Code: E72 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 03172 - * Name: GLENWOOD SPRINGS FORD-LINCOLN-MERCURY, INC. Ph: 970-9452317 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2007 Doc #:18902401 Cust Comments: CUSTOMER BROUGHT VEHICLE IN A FEW DAYS AGO, WE COULDN T GET THE VEHICLE TO HAVE THE SAME PROBLEMS WITH US. WE FIXED A FEW ITEMS ON THE VEHICLE BUT THE CUSTOMER STATES HE IS STILL HAVING TH Tech Comments: TEST DROVE VEH VERIFY CONCERN, USED IDS TO MON. PIDS AFTER ENGINE DIED, PERF DI DIAG 1 7 FOND CODES FOR IDM AND CAM SENSOR, VEH WILL NOT PERF INJ BUZZ TEST AT THIS TIME RET CODE FOR CID LOW. SW R&R IDM, TESTED CAM SENSOR WITH TESTING TOOL FAILS R&R CAM SENSOR, CLEARED CODES TEST DROVE VEH OPERATES AS INTENDED. CP# 12B599 CC# 42 1FTNX21FX2ED35157 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 23-MAY-2002 10-JUN-2002 156405 USA 60 2E06 030402 F81Z 9A543 CRM L65 D1 88970 AWS Claim Key: 16106960 Trx Code: E72 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 03218 - * Name: COLUMBINE FORD, INC. Ph: 970-6251680 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2007 Doc #:168090A Cust Comments: CUSTOMER STATES THERE IS AN ENGINE OIL LEAKR A Tech Comments: 88970 POROSITY CHECK FOR LEAK USING ROTUNDA LEAK DETECTOR PINPOINT TO LEAKING SMALL PLUG ON HIGH PRESSURE OIL PUMP REPLACE PUMP RETEST OK.
2003 F250 "Pulling Truck"
hhrecovery is offline
