Oasis Report Request Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vr6dub, this thread has received 2 replies and been viewed 960 times.
post #1 of 3 (permalink) Old 01-07-2009, 11:06 PM Thread Starter
Question Oasis Report Request Please
Hey everybody,
Could I get the Oasis for the following F250's VIN
1FTSW21P26EC88100
Thanks for the info. I really appreciate it a ton.
Mike
vr6dub is offline
post #2 of 3 (permalink) Old 01-09-2009, 11:49 PM
OASIS RESULT:
1FTSW21P26EC88100
01/09/2009
19:49:12
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
TRANSMISSION WARRANTY CANCELLED - COMPANY REQUEST
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/28/2006 BUILD DATE
02/08/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/16/2008
DEALER: Lithia Ford Lincoln Mercury of
WARRANTY CLAIM NUMBER: 385009 ODOMETER: 027321M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 080407F 42 DOES NOT OPERATE PROPERLY
OSP 006
27324 TURBO 000 TEST DRIVE TRUCK AND HEARD A AIR FLUTTER WHINNING NOISE. EE C TEST AND GOT CODE P0299. PERFORM TSB #08-4-7 AND PERFORM VPS TEST AND FO UND THE TURBO VAINS ARE STICKING. REMOVE TURBO AND DISASSEMBLE. FOUND THE T URBO CENTER HOUSING IS RUSTY. REPLACE CENTER HOUSING. TEST DRIVE TRUCK, NO MORE NOISE. OP CODE 080407F
02/20/2008
WARRANTY CLAIM NUMBER: 379087 ODOMETER: 026930M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 7823394AA DRIVE ASY-PWR LIFT W 001 MT23394 42 DOES NOT OPERATE PROPERLY
6W7Z 19B508A 001 12650D45
26931 INOPRITIVE MOTOR ASY 000 VERIFIED CONCERN, PINPOINT TEST SHOWED INOPR ITIVE MOTOR ASY REPLACED REAR SLIDER MOTOR ASY AND CABLES RETEST WINDOW OP ERATION NORMAL AT THIS TIME
02/05/2008
WARRANTY CLAIM NUMBER: 377595 ODOMETER: 026828M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 2820878AAE MLDG FRT DR OS 001 20878A 42 DOES NOT OPERATE PROPERLY
26828 MOULDING 000 VERIFIED COMPLAINT. SUBMITED PICTURES FOR APPROVAL. MOUL DING WAS APPROVED. REMOVED OLD MOULDING AND REPLACED WITH NEW ONE.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P26EC88100
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 4 5N01 110301 6C3Z 3304 B K03 42 6244
AWS Claim Key: 1194145 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:315360B
Cust Comments: CUSTOMER STATES FRONT END SQUEEKS (ADVISE)
Tech Comments: 6246 FRONT TRACK LINK WF4 INSPECT FRONT SUSPENTION,FOUND TRACK LINK BUSHI BUSHINBG WORN,R R TRACK LINK ,AND ADJUST FRONT STEERING WHEEL ALIGNMENT
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 4 6C04 010505 * 2823943 * B43 42 6246
AWS Claim Key: 1224768 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:317098B
Cust Comments: CUSTOMER STATES PASS. DOOR RATTLES AADVISE
Tech Comments: 6251 WARR CONFIRM CONCERN. REMOVE DOOR PANEL AND FOUND THAT THE TOP SCREW ANCHOR WAS BROKEN. INSTALL NEW ANCHOR AND REINSTALL DOOR PANEL. OK AT THIS TIME.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 4 5B03 050300 6C3Z 3B239 A N50 42 6246
AWS Claim Key: 1224769 Trx Code: 1 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2006 Doc #:317098A
Cust Comments: CUSTOMER STATES FRONT END SQUEEKS ADVISE
Tech Comments: 6251 WARR TEST DRIVE TRUCK AND VERIFY COMCERN. INSPECT FRONT SUSPENSION AND FOUND THAT THE BUSHING IN THE FRAME SIDE OF THE TRACK BAR IS BAD. REMO VE TIE ROD AND DRAGLINK TO GAIN ACCESS TO TRACK BAR. REMOVE TRACK BAR AND INSPECT BALL JOINT FOR CONCERNS. INSTALL NEW TRACK BAR AND REASSEMBLE REST OF TRUCK. TEST DRIVE AND ALL IS OK AT THIS TIME.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 8 2E03 030402 4C3Z 9E527 AA D50 42 11506
AWS Claim Key: 2043802 Trx Code: S07 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:330306A
Cust Comments: C S THE EIGINE IS RUNNING ROUGH MISSES
Tech Comments: 11510 RUNS ROUGH WARR PERFORM PERFORMANCE SHEET AND GOT NO CODES. PERFORM POWER BALANCE TEST AND FOUND #8 CYLINDE IS DROPPING OUT. PERFORM COMPRESSION TEST AND GOT 400. DIAG THAT THE #8 INJECTOR IS FAULTY, REPLACE INJECTOR. TEST DRIVE TRUCK
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 9 5B03 0703XX * 4205 * L88 42 12386
AWS Claim Key: 2297745 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2006 Doc #:332507E
Cust Comments: CUSTOMER STATES REAR END LEAKING ADVISE
Tech Comments: 12386 WARR DIAG THAT THE REAR DIFF COVER IS LEAKING. REMOVE COVER AND CLEAN REINSTALL AND FILL.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 9 6L17 011202 5C3Z 25519C44 AAA J03 42 12386
AWS Claim Key: 2285594 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2006 Doc #:332507B
Cust Comments: C S SUN GLASS HOLDER RATTLES
Tech Comments: 12386 WARR REMOVE HEADLINER AND FOUND BRACKET TO BE WORN AND RATTLING OVER BUMPS. INSTALL NEW OVERHEAD CONSOLE BUCKET AND REINSTALL HEADLINER. TEST DR IVE FOR RATTLE FIX.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 10 5V10 060601 5C3Z 2140 HA H19 42 13210
AWS Claim Key: 2465354 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-DEC-2006 Doc #:334359A
Cust Comments: CUSTOMER STATES BRAKES HAVE NO PEDAL PRESSURE
Tech Comments: 13210 NO BRAKES 0 INSPECT FOR NO BRAKES, FOUND NO FLUID, ALL FLUID AND CHECK FOR LEAKS, FOUND LR BRAKE LINE LEAKING AT FITTING, NESS TO REMOVE LINE AND MAKE NEW LINE FROM BULK, REMOVE FITTINGS FROM OLD LINE FOR MAKE NEW LINE, BLEED SYSTEM COMPLETE AND PERFORM HCU BLEED FUNCTION WITH IDS, ROAD TEST AND VERIFY PEDLE FADE AT STOPS, RECHECK FOR LEAKS. NESS TO REPLACE MASTER CYLINDER FOR
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 11 3A05 070100 5C3Z 7A103 C N18 42 15138
AWS Claim Key: 2773080 Trx Code: E84 Labor Hrs: 11.9
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2007 Doc #:339053A
Cust Comments: C S THE TOWHAUL LIGHT FLASHES WHINE NOISE FROM THE VEHICLE WHEN DRIVING CHECK ENGINE LIGHT IS ON
Tech Comments: 15142 TOW HAUL LIGHT IS FLASHING 0 TEST DRIVE TRUCK, TRANNY IS SHIFING HARD AND THE LIGHT IS FLASHING AND THE TRANNY IS MAKING A BUZZING NOISE. EEC TEST AND GOT CODE P0741 TORQUE CONVERTER CLUTCH SOLENOID CKT PERF. CHECK LINE PRESSURE AND FOUND IT TO BE LOW. REMOVE TRANNY PAN AND FOUND CLUTCH MATERIAL IN PAN. OHM TEST TCC SOLENOID AND INTERNAL HANRESS AND FOUND BOTH
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 13 1H03 030804 4C3Z 9P456 AF D50 42 17504
AWS Claim Key: 3174398 Trx Code: S07 Labor Hrs: 18
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2007 Doc #:343975A
Cust Comments: C S THE VEHICLE IS BLOWING WHITE SOMKE USING LOTS OF FUEL
Tech Comments: 17510 BLOWS SMOKE 0 VERIFIED CONCERN. VEHICLE LOW ON COOLANT. TEST DROVE WITH PRESSURE GAUGE ON THE COOLING SYSTEM AND PRESSURE WENT ABOVE 16 PSI. REMOVED THE TURBO. REMOVED THE TRANSMISSION. REMOVED THE ENGINE AND PUT ON ENGINE STAND. REMOVED THE HEADS AND HAD INSPECTED BY MACHINE SHOP. HEADES WERE WARPED AND THEY MILLED THE HEADS .010 INCHES. REPLACED THE HEADGASKETS AND
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 14 6J01 011404 6C3Z 2521813 A L17 42 18098
AWS Claim Key: 3501192 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2007 Doc #:346317C
Cust Comments: CUSTOMER STATES THE DRIVERS DOOR IS HARD TO CLOSE, ADVISE
Tech Comments: 18098 0 ADJUST DOOR STRIKER. COULDNT ADJUST, REPLACE DOOR LATCH
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 15 2E03 030402 4C3Z 9E527 AA D42 42 19921
AWS Claim Key: 3661041 Trx Code: S07 Labor Hrs: 7.8
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2007 Doc #:351078D
Cust Comments: ADD ON C S WHEN STARTED COLD THE ENGINE RUNS ROUGH MISSES
Tech Comments: 19921 RUNS ROUGH COLD 000 PERFORM PERFORMANCE SHEET AND GOT NO CODES. START TRUCK UP COLD AND PERFORM POWER BALANCE TEST AND FOUND #5 CYLINDER IS DROPPING OUT. REMOVE VALVE COVER AND PERFORM COMPRESSION TEST AND GOT 400. REPLACE INJECTOR. TEST DRIVE TRUCK
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 15 5V07 060704 6C3Z 2005 AA H20 42 19921
AWS Claim Key: 3684967 Trx Code: E84 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:17-MAY-2007 Doc #:351078A
Cust Comments: C S WHEN BRAKING THE PEDAL DROPS POOR STOPPING
Tech Comments: 19925 PEDAL GOES TO THE FLOOR AND STEERING IS HARD TO TURN 0 TEST DRIVE TRUCK, THE BRAKE PEDAL IS HARD AND THEN WILL GO TO THE FLOOR. THE STEERING WHEEL WILL NOT RETURN TO CENTER AFTER A TURN. CHECK P S FLIUD AND FOUND FLIUD HAS METAL IN IT. DRAIN COOLANT SYSTEM AND REMOVE UPPER RADIATOR HOSE, REMOVE FAN AND SHRAOD, REMOVE SERP BELT AND REPLACE P S PUMP. REPLACE HYDROBOOSTER,
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 16 5B03 0401XX * 3010 * L88 42 22213
AWS Claim Key: 3903906 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2007 Doc #:353550C
Cust Comments: ADD ON C S THERE IS FLUID LEAKING ENGINE AREA
Tech Comments: 22216 FLIUD LEAK 000 PUT TRUCK ON HOIST AND INSPECT FOR FLIUD LEAK AND FOUND OIL LEAKING FROM REAR DIFF COVER. RESEAL DIFF COVER. TEST DRIVE TRUCK
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 16 5B03 050300 6C3Z 3B239 A H44 42 22213
AWS Claim Key: 3880937 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2007 Doc #:353550A
Cust Comments: C S THERE IS A POP NOISE IN THE FRONT ROUGH ROADS
Tech Comments: 22213 POP NOISE FROM FRONT ON BUMPY ROADS 000 TEST DRIVE TRUCK AND HEARD NOISE COMING FROM FROM OF TRUCK. FOUND TRACK BAR BUSHING IS LOOSE. REPLACE TRACK BAR. TEST DRIVE TRUCK
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 17 5N01 110301 5C3Z 3E651 D K02 42 22593
AWS Claim Key: 4039288 Trx Code: E84 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2007 Doc #:355406A
Cust Comments: C S THERE IS A POP NOISE IN THE FRONT AND OUT OF CONTROLL VIBRATION IN THE FRONT WHEN HITTING BUMPS WAS TOLD SITTING TOO FAR FOREWARD DRAK
Tech Comments: 22605 FRONT END CONCERN INSPECT FRONT END SPEC AND ALL SUSPENSION COPONENTS FOR LOOSNESS FOR VIBRATION CONCERN PERFORM SET BACK CHECK AND WHEEL BASE CHECK OK TOUQUE ALL FRONT END ATTACHING POINTS AND REPLACE STEERING STABILIZER SHOCK AND BRACKET, CENTER STEERING CLEAR VISION
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 20 2E03 030402 4C3Z 9E527 AA D42 42 23949
AWS Claim Key: 4947898 Trx Code: S07 Labor Hrs: 7.7
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:365881A
Cust Comments: C S THE VEHICLE CUTS OUT MISSES ON ACCL
Tech Comments: 23949 INJECTORS 000 ENGINE CUTS OUT AND MISSES COLD. LET TRUCK SIT OUTSIDE OVER NIGHT AND PERFORM COLD START UP AND FOUND CYLINDERS 2,3 AND 4 ARE DROPPING OUT. PERFORM PERFORMANCE SHEET AND GOT NO CODES. CHECK FUEL PRESSURE AND GOT 55 PSI. TEST DRIVE TRUCK AND MISS GOT BETTER BUT THESE CYLINDER ARE STILL DROPPING OUT. PERFORM COMPRESSION TEST AND GOT #2 400, #3 390, #4 400.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 20 6Y20 000000 * TAP1 * A98 82 23949
AWS Claim Key: 4978218 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:365881C
Cust Comments: AUTORIZED RENTAL
Tech Comments: 23961 TAP DAYS TRANS CLAIM #414345 13 DAYS $390.00
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 20 1A01 030102 6C3Z 6049 A D42 42 23949
AWS Claim Key: 4967803 Trx Code: E84 Labor Hrs: 14.7
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:03-OCT-2007 Doc #:365881B
Cust Comments: C S HAS TO ADD COOLANT THERE IS WHITE RESIDUE AROUND THE RECOVERY RES
Tech Comments: 23961 WARPED HEADS 0 INSPECT COOLANT SYSTEM AND FOUND COOLANT RESERVOIR IS LOW. FILL RESERVOIR IS MIN MARK. PRESSURE TST RAD CAP AND CAP IS HOLDING AT 13 PSI. WITH PRESSURE TESTER HOOK UP TO COOLANT SYSTEM TEST DRIVE TRUCK. PRESSURE IS GETTING OVER 16 PSI. REMOVE BOTH CYLINDER HEADS AND MEASURE HEADS FOR WARPPAGE. THE RIGTH HEAD IS WARPED 005 AND THE LEFT IS WARPED .004
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 22 2H01 031202 6C3Z 6C640 A D50 42 25473
AWS Claim Key: 5150436 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2007 Doc #:372175G
Cust Comments: CUSTOMER STATES CHARGE AIR COOLER BLEW OFF
Tech Comments: 25479 CHARGE AIR COOLER TUBE 000 INSPECT AND FOUND THE LEFT CHARGE AIR COOLER TUBE BOOT BLEW OFF THE TURBO. REMOVE THE LEFT CHARGE AIR COOLER TUBE AND REPLACE THE BOOT. TEST DRIVE TRUCK
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 22 5I01 110204 3C3Z 3A674 AARM H21 42 25473
AWS Claim Key: 5150435 Trx Code: E90 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2007 Doc #:372175A
Cust Comments: CUSTOMER STATES POWER STEERING GETS STIFF AT TIMES WHEN TURNING AND BRAKING
Tech Comments: 25477 P S PUMP 000 TEST DRIVE TRUCK, WHEN TURNING THE STEERING WILL SOMETIMES GET STIFF AND WHEN TURNING AND BRAKING THERE IS A WHINE NOISE. BLEED P S SYSTEM SEVERAL TIMES, BUT THE WHINE IS STILL THERE. DRAIN COOLANT SYSTEM. REMOVE FAN AND SHROAD, REMOVE SERP BELT, AND REPALCE P S PUMP. TEST DRIVE TRUCK WHINE IS GONE AND STEERING IS BETER.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 24 6N01 010805 5C3Z 2820878 AAE B63 42 26828
AWS Claim Key: 5542964 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2008 Doc #:377595B
Cust Comments: CUSTOMER STATES RIGHT FRONT DOOR MOULDING IS COMMING LOOSE
Tech Comments: 26828 MOULDING 000 VERIFIED COMPLAINT. SUBMITED PICTURES FOR APPROVAL. MOULDING WAS APPROVED. REMOVED OLD MOULDING AND REPLACED WITH NEW ONE.
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 25 7N02 011105 6C3Z 7823394 AA G07 42 26930
AWS Claim Key: 5643531 Trx Code: E83 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2008 Doc #:379087A
Cust Comments: CUSTOMER STATES REAR SLIDER WINDOW WONT OPEN OR SHUT, ACCED APPROVAL PAALT REFFER TO RO374557
Tech Comments: 26931 INOPRITIVE MOTOR ASY 000 VERIFIED CONCERN, PINPOINT TEST SHOWED INOPRITIVE MOTOR ASY REPLACED REAR SLIDER MOTOR ASY AND CABLES RETEST WINDOW OPERATION NORMAL AT THIS TIME
1FTSW21P26EC88100 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-FEB-2006 28-FEB-2006 156593 USA 26 2H01 030407 5C3Z 9G489 AARM D42 42 27321
AWS Claim Key: 6098116 Trx Code: E84 Labor Hrs: 4
Dlr Cd-Sub Cd: 03897 - * Name: LITHIA FORD LINCOLN MERCURY OF BOISE Ph: 208-3426811 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:16-APR-2008 Doc #:385009B
Cust Comments: CUSTOMER STATES HE CAN HEAR A WHINNING NOISE WHILE ACCELERATING
Tech Comments: 27324 TURBO 000 TEST DRIVE TRUCK AND HEARD A AIR FLUTTER WHINNING NOISE. EEC TEST AND GOT CODE P0299. PERFORM TSB #08 4 7 AND PERFORM VPS TEST AND FOUND THE TURBO VAINS ARE STICKING. REMOVE TURBO AND DISASSEMBLE. FOUND THE TURBO CENTER HOUSING IS RUSTY. REPLACE CENTER HOUSING. TEST DRIVE TRUCK, NO MORE NOISE. OP CODE 080407F
60psdboy is offline
post #3 of 3 (permalink) Old 01-10-2009, 12:41 AM Thread Starter
Thank you 60psdboy.I appreciate it.
Mike
vr6dub is offline
Oasis report request RAC400 Ford Oasis requests 0 03-27-2008 11:35 PM
request for an Oasis report tallman_rob Ford Oasis requests 0 03-24-2008 05:24 PM
OASIS Report Request Chris562 Ford Oasis requests 2 01-19-2008 02:37 AM
Oasis Report Request Please Amarillo_PSD Ford Oasis requests 1 09-03-2007 10:58 PM
OASIS report request PSDfreak Ford Oasis requests 4 04-11-2006 08:52 PM
