oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brmpipes, this thread has received 3 replies and been viewed 960 times.
post #1 of 4 (permalink) Old 01-09-2009, 03:01 AM Thread Starter
oasis please
1FTWX31P46ED49810 thanks
brmpipes is offline
post #2 of 4 (permalink) Old 01-09-2009, 09:35 PM Thread Starter
bumpo
brmpipes is offline
post #3 of 4 (permalink) Old 01-09-2009, 11:53 PM
OASIS RESULT:
1FTWX31P46ED49810
01/09/2009
19:52:36
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/30/2006 BUILD DATE
04/03/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
2011 - CAN 2006 NEW 60/150000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 CAD
OWNER NAME: BRNARD MACKAY
OPTIONS:
EXPIRATION DATE: 08/30/2011
DISTANCE: 150,000
RENTAL: 35 UP TO 10 DAYS
TOWING: 0 CAD
CONTRACT SOLD BY: CAN B6060
ESP CONTRACT START DATE: 08/30/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
2701 - CAN 2006 NEW 60/100000 POWERTRAINCARE W/ROADSIDE
OWNER NAME: BERNARD MACKAY
OPTIONS:
DISTANCE: 100,000
TOWING: 0 CAD
CONTRACT SOLD BY: CAN H1054
WARRANTY REPAIR HISTORY
11/17/2008
DEALER: Rainbow Ford Sales Inc.
WARRANTY CLAIM NUMBER: 059213 ODOMETER: 100454K
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 10346DA ALTERNATOR LESS PULL 001 10200AB 42 DOES NOT OPERATE PROPERLY
10346 ALTERNATOR LESS PULL 000 10346A
DIAG. WEAK OR LOW ELECTRICAL POWER, CHECKED CHG SYSTEM DIODE IN ALT FAILED R R ALTERNATOR RECHECK CHG SYSTEM OK
09/09/2008
WARRANTY CLAIM NUMBER: 058217 ODOMETER: 091924K
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 4635AB SPIDER & BRG ASY-U/J 001 4602A3 D8 FAILED GASKET/SEAL
B7A 4662A SPACER DRIVE PINION 001 4676AA
TBAA 4621A CONE & ROLLER-DR PIN 001 4205A6
E5TZ 4616A CUP-DRIVING PINION B 001
390313S100 001
F81Z 4630AA PINION BEARING 001
F81Z 4628AA CUP DRIVING PINION B 001
CXY 75W1401L 003
CXL 3 002
E8TZ 4676B SEAL ASY-DRIVE PINIO 001
F5DZ 3B478AA BOOT CLAMP 001
*INSPECTED REAR DIFF - PINION SEAL LEAKING-REMOVE AND REPLACED REAR DIFF AND CHANGED PINION AND SIDEBEARING - BEARINGS ROUGH AND PITTED - REASSEMBLED AN D ROADTEST GOOD
08/14/2008
WARRANTY CLAIM NUMBER: 057900 ODOMETER: 089088K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6K854AA PIPE (TURBO INLET LO 001 9438A 42 DOES NOT OPERATE PROPERLY
5C3Z 6K854CA PIPE (TURBO INLET LO 001 9438A2
3C3Z 6N640AA GASKET TURBO TO MANI 001 MTBOLT
W300006 002
W300013 004
W300051 004
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001
*DIAG HIGH PITCH SQUEALING NOISE-VISUAL FOUND TURBO INLET PIPE AT ACORDIAN D AMAGED - ACCESS EXHAUST YPIPES BY REMOVING TURBO HAD PROBLEM REMOVING EXHAUS T BOLTS RUSTED MTBOLT REMOVE AND REPLACE YPIPE RESTORE ROADTEST GOOD
| On-line 1878
END OF OASIS REPORT FOR 1FTWX31P46ED49810
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 3 6X04 010902 6C3Z 17D742 AA B66 05 4357
AWS Claim Key: 2929546 Trx Code: 2 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:24-NOV-2006 Doc #:048255A
Cust Comments: EXTRIOR MIRROR CHROME IS COMING OFF ONE ORDERED
Tech Comments: DIAG EXTERIOR MIRROR CHROME COMING OFF REMOVED ANDREPLACED RIGHT SIDE MIRROR FACE GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 3 6A22 010203 * 16006 * B66 P3 4357
AWS Claim Key: 2952682 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:24-NOV-2006 Doc #:048255B
Cust Comments: CLEARCOAT IS PEELING FROM FRONT FENDERS AND PAINT FAALING OFF BADGES
Tech Comments: INSPECT PAINT IMPERFECTIONS CLEAR COAT PEELING ANDBOTH BADGES ARE MISSING PAINT SEND TO BODY SHOP AS PER ESTIMATE
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 11 2E03 030008 * 9E527 * D50 42 25353
AWS Claim Key: 4788303 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-JUL-2007 Doc #:051636A
Cust Comments: POOR START IF NOT LET WARM UP WELL ENOUGH,RUNS POORLY WIT LOW POWER
Tech Comments: *DIAG RUNS ROUGH LACKS POWER AND WHITE SMOKE EEC TEST NO CODES CHECKED OASIS REPROGRAMMED PCM FICM AND TCM AS PER TSB 07 05 04 GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 11 1H03 030008 * 9F452 * D50 55 25353
AWS Claim Key: 4809614 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-JUL-2007 Doc #:051636D
Cust Comments: CUSTOMER CONCERNED THAT EGR HAS NEVER BEEN CLEARED OR REMOVED COOLANT STILL SEEMS TO BE DISAPPEARING OUT OF THE OVER FLOW,BUT NO LONGER FROM THE CAP
Tech Comments: *DIAG CUSTOMER CONCERN THAT EGR HAS NEVER BEEN CLEARED OR REMOVED CLEAN AND REINSTALLED EGR VALVE ASPER TSB 06 19 06
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 11 6H19 011103 F81Z 2521452 AA B66 07 25353
AWS Claim Key: 4777109 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-JUL-2007 Doc #:051636E
Cust Comments: CUSTOMER REQUESTS CHECK FOR WINDOW MOULDING LETS DDIRT IN AND SCRATCHES WINDOW
Tech Comments: *DIAG CUSTOMER REQUEST CHECK FOR WINDOW MOULDING LETS DIRT IN AND SCRATCHES WINDOW REPLACED BOTH LOWER OUTER WEATHERSTRIPS AS PER TSB 07 10 05 GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 11 1A02 030102 * 6051 * L87 42 25353
AWS Claim Key: 4788304 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-JUL-2007 Doc #:051636B
Cust Comments: COOLANT LOSS FROM RESEVOIR,ON 2 OCCASIONS HAD TO ADD A GALLON OF COOLANT EACH TIME PUT REGULAR DIESEL(GREEN) ANTI FREEZE IN THE LAST TIME,HAVE ALSO NOTICED WHITE EXHAUST
Tech Comments: *DIAG COOLANT LOSS FROM RESERVOIR FOLLOWED TSB 07 14 05 10 DEG C DIFFERNCE BETWEEN ECT AND EOT PRESSURE EXCEEDS 10 PSI NEEDS HEAD GASKETS AND BOTH EGRAND OIL COOLERS
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 12 1A02 030102 * 6051 * L87 42 28888
AWS Claim Key: 4588638 Trx Code: E84 Labor Hrs: 21.2
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:13-AUG-2007 Doc #:052283A
Cust Comments: FRIDAY 05.07 LOST ABOUT 1 2 GALLON OF ANTI FREEZE AGAIN
Tech Comments: *DIAG COOLANT LOSS REFERNCED FORDSTAR BROADCAST ROAD TEST NONITO PID DATA N ECT EOT OUT OF SPEC 21DEG TEMP DIFFERNCE VENTING FROM DEGAS BOTTLE EXCEEDSCAP PRESS REQUIRES OIL COOLER RR OIL COOLER RETES T EOT N ECT WINTHIN SPEC CODING SYS PRESS STILL VNETING FROM DEGAS BOTTLE CAP 14PSI N REQUIRES HEAD GSKTS RR HEAD GASKTS MT062102 EXTENSIVE DIAG AND ADDITION TIME FOR EGR COOLER RETEST GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 24 2H01 030008 5C3Z 6K854 AA D50 42 55356
AWS Claim Key: 7276988 Trx Code: E72 Labor Hrs: 5.4
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:14-AUG-2008 Doc #:057900A
Cust Comments: HIGH PITCH SQUEALING NOISE
Tech Comments: *DIAG HIGH PITCH SQUEALING NOISE VISUAL FOUND TURBO INLET PIPE AT ACORDIAN DAMAGED ACCESS EXHAUST YPIPES BY REMOVING TURBO HAD PROBLEM REMOVING EXHAUST BOLTS RUSTED MTBOLT REMOVE AND REPLACE YPIPE RESTORE ROADTEST GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 25 5A09 050204 E8TZ 4676 B L88 D8 57118
AWS Claim Key: 7308985 Trx Code: 2701D Labor Hrs: 4.7
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:09-SEP-2008 Doc #:058217A
Cust Comments: REAR DIFF PINION SEAL LEAKING
Tech Comments: *INSPECTED REAR DIFF PINION SEAL LEAKING REMOVE AND REPLACED REAR DIFF AND CHANGED PINION AND SIDEBEARING BEARINGS ROUGH AND PITTED REASSEMBLED AND ROADTEST GOOD
1FTWX31P46ED49810 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 03-APR-2006 30-AUG-2006 4B6060 CAN 28 7B02 140201 * 10346 * C26 42 62419
AWS Claim Key: 7471444 Trx Code: 2011D Labor Hrs: 1.8
Dlr Cd-Sub Cd: B6198 - * Name: RAINBOW FORD SALES INC. Ph: 403-8453673 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:17-NOV-2008 Doc #:059213B
Cust Comments: *W
Tech Comments: DIAG. WEAK OR LOW ELECTRICAL POWER, CHECKED CHG SYSTEM DIODE IN ALT FAILED RR ALTERNATOR RECHECK CHG SYSTEM OK
60psdboy is offline
The Following User Says Thank You to 60psdboy For this addition to TDG:
brmpipes (01-10-2009)
post #4 of 4 (permalink) Old 01-10-2009, 12:53 AM Thread Starter
thanks again for your help.
brmpipes is offline
