Oasis Report Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by merlin5577, this thread has received 4 replies and been viewed 631 times.
post #1 of 5 (permalink) Old 01-13-2009, 04:20 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
Thanks in advance!
1FTWW32F8YEB12300
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #2 of 5 (permalink) Old 01-14-2009, 02:52 AM
OASIS RESULT:
1FTWW32F8YEB12300
01/13/2009
22:52:01
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/24/1999 BUILD DATE
10/13/1999 SALE MILEAGE
00009
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
0759 - EXPIRED
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: *************
OPTIONS:
EXPIRATION DATE: 11/24/2005
DISTANCE: 75,000
RENTAL: 28 UP TO 5 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 08873
ESP CONTRACT START DATE: 11/24/1999
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FTWW32F8YEB12300
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 0 * * * * * * * 1
AWS Claim Key: 199901 Trx Code: TDE Labor Hrs: 0
Dlr Cd-Sub Cd: 01620 - * Name: IVERSEN FORD SALES, INC. Ph: *-* St:MA Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-1999 Doc #:18885951
Tech Comments: REPAIR & REFINISH PER AMERICAN ROAD ESTIMATE
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 2 6B07 010104 * 3827841 * A99 82 1501
AWS Claim Key: 429671 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:18-JAN-2000 Doc #:05476801
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 3 1D04 030008 F81Z 8255 AA L85 01 3035
AWS Claim Key: 541706 Trx Code: 1 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2000 Doc #:05560203
Cust Comments: CUSTOMER STATES AN ANTIFREEZE LEAK A LITTLE BIT OF ANTIFREEZ E ON FLOOR
Tech Comments: TECH CHECKED FOR ANTIFREEZE LEAK A LITTLE ON FLOOR TECH PRESSURE TESTED THE COOLING SYSTEM FOUND LEAK AT WATER PUMP INLET REPLACED GASKET
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 22 5G05 040402 * TIRE * H21 01 27593
AWS Claim Key: 11804943 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2001 Doc #:07476203
Cust Comments: RATTLES FROM FRONT END OVER BUMPS
Tech Comments: REPLACED THE 6 TIRWES 5 OF THEM HAD LARGE BUBBLES IN THE SID WALLS DEFECTIVE TIRES DSE SAW THE CONCERN REPLSACED ALL 6
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 22 5V09 12XXXX F81Z 2A451 BA A85 01 27593
AWS Claim Key: 11614261 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:21-AUG-2001 Doc #:07476202
Cust Comments: A C IS NOT BLOWING OUT OF PANEL
Tech Comments: REPLACED THE VACCUM PUMP
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 43 2B01 030701 F7TZ 12K073 A D36 01 36500
AWS Claim Key: 20831773 Trx Code: E72 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2003 Doc #:09636601
Cust Comments: CHEKC THE RUNNING CONDITION STALLS WHEN IT IS HOT FOOT OFF THE GAS AND THE TRUCK STALLS
Tech Comments: CLEAR 011 CODES ROADTEST ENG STALL PO 340 CAME BACK ON CAM SENSOR
1FTWW32F8YEB12300 T/F7 F T/BC T/CD T/B A1 T/DQ T/DS 13-OCT-1999 24-NOV-1999 111044 USA 64 5W01 060901 F81Z 2C205 AD A85 01 43903
AWS Claim Key: 24024198 Trx Code: 0759D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08873 - * Name: DANVERS MOTOR COMPANY, INC. Ph: 978-7740727 St:MA Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2005 Doc #:11775001
Cust Comments: CHECK THE ABS LIGHT IS ON
Tech Comments: CODE 1155 L F IMPUT REPLACED LEFT ABS SENSOR
60psdboy is offline
The Following User Says Thank You to 60psdboy For this addition to TDG:
merlin5577 (01-14-2009)
post #3 of 5 (permalink) Old 01-14-2009, 04:09 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
Can you tell me from the Vin, what gears it has in it and if its a limited slip or not?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #4 of 5 (permalink) Old 01-15-2009, 10:59 PM
no i tried its to old
cb44473 is offline
The Following User Says Thank You to cb44473 For this addition to TDG:
merlin5577 (01-18-2009)
post #5 of 5 (permalink) Old 01-17-2009, 07:39 PM
4play's Avatar
look for a tag on one of the rear diff cover bolts. you will see numbers like 355, 3L55, 373
3L73, 410 4L10 etc... the "L" denotes limited slip.
4play is offline
OASIS Report on 97 F-250 ejpowerstroke97 Ford Oasis requests 1 01-06-2008 12:35 AM
Oasis report please liftruck Ford Oasis requests 1 12-04-2007 11:24 AM
Oasis report please floridafishhunt Ford Oasis requests 1 12-01-2007 02:28 AM
Oasis Report Please and Thanks minnboy7 Ford Oasis requests 1 12-04-2006 12:22 PM
Oasis report please imported_dbric36 Ford Oasis requests 1 11-01-2006 08:37 PM
