oasis need for used 6l for me - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Robts, this thread has received 1 replies and been viewed 570 times.
post #1 of 2 (permalink) Old 01-15-2009, 01:37 PM Thread Starter
Robts's Avatar
I need an oasis to see if this is worthy of a purchase
1FMSU45P05EA57475
05 excursion
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
post #2 of 2 (permalink) Old 01-15-2009, 10:50 PM
OASIS RESULT:
1FMSU45P05EA57475
01/15/2009
18:48:19
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
4 DR EDDIE BAUER 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/14/2004 BUILD DATE
08/31/2004 SALE MILEAGE
00267
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 5 7W88 000615 * NPF * G29 82 8626
AWS Claim Key: 332553 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2005 Doc #:62954702
Cust Comments: CUSTOMER STATES THAT THE BACK UP SENSORS QUIT WORKING CHECK AND ADVISE
Tech Comments: *311 253 087* TECH HOTLINE CONTACT ID PERFORMED WDS DIAG, CHECKED PARKING AID MODULE FOR CODES NO CODES. PARKING AID IS WORKING NORMAL THIS TIME.
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 5 6H05 011104 YC3Z 7830478 AA G09 42 8626
AWS Claim Key: 332554 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-JAN-2005 Doc #:62954701
Cust Comments: CUSTOMER STATES THAT QUARTER WINDOWS SQUEEK WHEN OPENING SPECIAL ORDER PART IS HERE
Tech Comments: NOISEY REMOVED AND REPLACED RIGHT REAR QUARTER GLASS MTR. LUBRICATED LEFT WINDOW HINDGE.
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 7 1H03 030008 3C3Z 9J460 AA D42 42 11327
AWS Claim Key: 580693 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-MAR-2005 Doc #:63749201
Cust Comments: CUSTOMER STATES THAT ENGINE LACKS POWER INTERMITTENTLY. SMOKING ALOT WHEN THIS HAPPENDS
Tech Comments: 6.0 DIT INTERMITTENT LOSS OF POWER,DIAGNOSTICS,EEC TEST CONT P2269 PINPOINT TEST O ,KOEO,KOEO INJ ELE,KOER REPLACED EBP SENSOR WITH LATEST UPDATED SENSOR, DRAINED WIF,ROADTEST,BOOST PRSSURE TEST,RETESTS
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 9 5S11 100103 * 9N184 * D42 42 15626
AWS Claim Key: 899276 Trx Code: E84 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:64482401
Cust Comments: CUSTOMER HAS EXPERIENCED DRIVEABILITY CONCERN WHERE THE TRUCK FEELS LIKE IT IS STARVING FOR FUEL, AND THE GAS PUMP SYMBOL IS STAYING ON.
Tech Comments: WATER IN FUEL LIGHT ON,6.0 DIT PERFORMANCE DIAGNOSTICS,VISUA L,OIL,FUEL,INSPECTION,EEC TEST CONT P2269,PINPOINT TEST 0 , KOEO,KOEO INJ ELEC,KOER,KOER GLOW PLUG MONITOR,POWER BALANCE ,EGR POSITION,INTAKE REPROGRAMMED PCM AND TCM WITH LATEST GREATESS UPDATE PER B37 .3 P5,DRAINED AND CLEANED WATER FUEL SEPERATOR AND SENSOR, RECORD MONITOR PID DATA (BOOST)ROADTEST,RETESTS SYSTEMS PASS
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 14 2G04 000615 * DIAG * D42 42 21014
AWS Claim Key: 2168986 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2005 Doc #:66624104
Cust Comments: TECHNICIAN EXPERIENCED A DRIVEABILITY CONCERN DURING TEST DRIVE. (SEVERE ENGINE MISFIRE) CHECK AND ADVISE
Tech Comments: 6.0DIT PERFORMANCE DIAGNOSTICS,VISUAL,OIL,FUEL,INSPECTION, EEC TEST CONT,KOEO,KOEO INJ ELEC.,KOER,KOER GLOW PLUG MONITO RSYSTEMS PASS,INTAKE EXAHAUST RESTRICTION,IPR,EGR POSITION, INJECTOR INTERRUPT F VEHICLE WILL RETURN FOR FURTHER DIAGNOSIS NO PROBLEM FOUND OASIS # 516 474 125
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 14 1H03 030008 5C3Z 9F452 AA D42 42 21281
AWS Claim Key: 2260364 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2005 Doc #:66766101
Cust Comments: CK FOR VEHICLE IS CHUGGING AND BLOWING BLACK SMOKE
Tech Comments: 6.0 DIT PERFORMANCE DIAGNOSTICS,VISUAL,OIL,FUEL,INSPECTION EEC TEST CONT,KOEO,P1335,PINPOINT TEST W,KOEO INJ ELE,KOER, PASS,EGR POSITION,BOOST PRESSURE,IPR,INTAKE EXHAUST RESTRICT ION,SCAN TOLL RECORD REPLACED EXHAUST BACKPRESSURE(EGR) VALVE,ROADTEST ,RETESTS SYSTEMS PASS
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 15 7W15 131302 1L1Z 15K859 AA G29 42 23301
AWS Claim Key: 2684108 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2005 Doc #:67335202
Cust Comments: CK FOR BACK UP SENSORS IN OP ADVISE
Tech Comments: HOOK UP WDS RUN SELF TEST HAD CODE C1710 TESTED AND REPLACED RIGHT HAND INNER SENSOR AND CHECK OPERATION
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 17 * * * * * * * 27574
AWS Claim Key: 3555880 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:68152503
Cust Comments: VOLUNTARY EMISSION RECALL SUPPLEMENT#2 CERTAIN 2004 MODEL YEAR F250 350 450 550, EXCURSION, AND E350 450 VEHICLES
Tech Comments: 1 INSTALL NEWLY DESIGNED EP SENSOR, INSTALL NEWLY DESIGNED EP SENSOR, AND RECALIBRATE(REFLASH) ENGINE CONTROL MODULE WITH
AWS Claim Key: 3555879 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:68152504
Cust Comments: DEGAS FILL LEVEL FSA 05B32
Tech Comments: INSTALLED LABEL PER RECALL 05B32B 0.2 DEGAS FILL LEVEL
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 17 6H10 011104 YC3Z 7830478 AA G07 42 27574
AWS Claim Key: 3555881 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:68152501
Cust Comments: CK FOR PASS SIDE REAR QUARTER WING WINDOW MOTOR IS MAKING LOUD NOISE WHEN OPENING AND CLOSING AND THE OTHER DAY IT DIDN T WORK AT ALL
Tech Comments: PERFORM GEM SELF TEST,NO CODES,DCL DISPLAY,WDS RECORDER MONITOR,PERFORM PINPOINT TEST E,E1 12.23V,E2 0.2 & 0.3 OHMS E3 12.1 TO 12.0,REPLACE RR QUARTER GLASS MOTOR,RETEST,OK
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 19 1H03 030008 5C3Z 9F452 AA D42 42 30556
AWS Claim Key: 4246994 Trx Code: E91 Labor Hrs: 2
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-APR-2006 Doc #:69056701
Cust Comments: CK FOR CK ENG LIGHT IS ON
Tech Comments: 6.0 DIT PERFORMANCE DIAGNOSTICS,VISUAL,OIL,FUEL,INSPECTION EEC TEST CONT,KOEO,KOER P1335,PINPOINT TEST W,EGR POSITION TEST,SCAN TOOL RECORD MONITOR PID DATA REPLACED EXHAUST BACK PRESSURE VALVE(EGR),ADD CETANE BOOSTER TO FUEL TANK,RAODTEST,RETESTS SYSTEMS PASS
1FMSU45P05EA57475 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 31-AUG-2004 14-SEP-2004 148576 USA 29 6R01 012001 5C3Z 78613E58 AAA S25 42 44969
AWS Claim Key: 6833428 Trx Code: E81 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2007 Doc #:72808801
Cust Comments: SEAT BELT HAS RECOILED INTO ASSEMBLY
Tech Comments: 1 FOUND 2ND ROW CENTER SEAT BELT RETRACTOR FAULTY AND REPLACED
cb44473 is offline
The Following User Says Thank You to cb44473 For this addition to TDG:
Robts (01-17-2009)
