Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by F3600, this thread has received 7 replies and been viewed 603 times.
post #1 of 8 (permalink) Old 01-15-2009, 02:49 PM Thread Starter
Red face Oasis Report Please
06 F250
1FTSW21P96EC56356
Thanks much in advance!!!
F3600 is offline
post #2 of 8 (permalink) Old 01-15-2009, 10:52 PM
OASIS RESULT:
1FTSW21P96EC56356
01/15/2009
18:52:12
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/26/2006 BUILD DATE
01/13/2006 SALE MILEAGE
00026
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0994 - USA 2006 NEW 60/60,000 P'TRAINCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: TIEN GIANG
OPTIONS:
EXPIRATION DATE: 09/26/2011
DISTANCE: 60,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 40919
ESP CONTRACT START DATE: 09/26/2006
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
01/17/2008
DEALER: Sunset Ford
WARRANTY CLAIM NUMBER: 007071 ODOMETER: 042073M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 001 6083A D8 FAILED GASKET/SEAL
3C3Z 6701A CRANKSHAFT REAR SEAL 001 6007D
VERIFY CONCERN W/DYE FOUND LEAK BETWEEN ENG/TRANS.REMOVE TRANS TO GAIN ACCES S.REAE ENG PLATE SEAL LEAKING REMOVE AND REPLACE W/REARMAIN SEAL.REASSEMBLE RETEST W/BLACK LIGHT PASSED.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P96EC56356
1FTSW21P96EC56356 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-JAN-2006 26-SEP-2006 171151 USA 5 1D05 031004 3C3Z 6D083 AA L85 D1 16584
AWS Claim Key: 3049356 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 05395 - * Name: HEMBORG FORD Ph: 951-7376151 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2007 Doc #:08724952
Cust Comments: CUST STATES OIL/FLUID LEAKS FROM UNDER VEHICLE
Tech Comments: VERIFY CUST CONCERN. REPLACED REAR MAIN SEAL AND RESEAL REAR COVER OF ENGINE. M TIME REQUIRED DUE TO NO LABOR OP
1FTSW21P96EC56356 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-JAN-2006 26-SEP-2006 171151 USA 5 3A11 070100 * 7000 * D02 42 16584
AWS Claim Key: 3049355 Trx Code: E84 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 05395 - * Name: HEMBORG FORD Ph: 951-7376151 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2007 Doc #:08724951
Cust Comments: CUST STATES NO CRANK/NO START, TRANS SHIFTING ERRATIC
Tech Comments: VERIFY CUST CONCERN. INSPECT FOR NO CRANK. FLEXPLATE BROKEN DUE TO TORQUE CONVERTER LOCKED UP. R&R TRANS, COULD NOT REMOVE CONVERTER FROM PUMP. REPLACED UNIT AND FLEXPLATE. RAN OASIS FOR ASSY REQUEST. NO PRIOR APPROVAL NEEDED. FLUSH COOLER. REPLACED OTA COOLER AND INLINE FILTER. ROAD TESTED 6 MILES, OK.
1FTSW21P96EC56356 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-JAN-2006 26-SEP-2006 171151 USA 16 1D01 03XXXX 3C3Z 6701 A L65 D8 42073
AWS Claim Key: 5570050 Trx Code: E72 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 05517 - * Name: SUNSET FORD Ph: 714-8980744 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2008 Doc #:00707105
Cust Comments: CUSTOMER STATES BLACKISH FLUID LEAK CHECK AND ADVISE
Tech Comments: VERIFY CONCERN W/DYE FOUND LEAK BETWEEN ENG/TRANS.REMOVE TRANS TO GAIN ACCESS.REAE ENG PLATE SEAL LEAKING REMOVE AND REPLACE W/REARMAIN SEAL.REASSEMBLE RETEST W/BLACK LIGHT PASSED.
cb44473 is offline
post #3 of 8 (permalink) Old 01-16-2009, 01:39 AM Thread Starter
Thank you very much for running the report!
Quick question, I was wondering about the powertrain warrenty. I was under the impression that it was a 5yr/100,000mile warrenty, but the report lists 5yr/60,000mile. Can someone verify which it really is?
Thanks!
F3600 is offline
post #4 of 8 (permalink) Old 01-16-2009, 02:10 AM Thread Starter
Oh, and is it possible to tell the the gear ratio and whether or not it is limited slip? I'm guessing it's got 3.73's but I'm not sure.
Thanks again for all the help!
F3600 is offline
post #5 of 8 (permalink) Old 01-17-2009, 07:26 PM
4play's Avatar
yep, 3.73 with a limited slip. another thing is if the tag is on rear diff. it would say 373 for open diff. 3L73 for limited. plus another tag may be on cover bolt to specify using friction modifier for the limited slip.
4play is offline
post #6 of 8 (permalink) Old 01-17-2009, 09:47 PM Thread Starter
Thanks for the info 4play. Any idea on the warrenty question I posted earlier?
F3600 is offline
post #7 of 8 (permalink) Old 01-18-2009, 08:01 PM
4play's Avatar
the 5/60k. you see listed is an extended sepvice plan warranty "esp". the 6.0l engine warranty is still 5/100k and im pretty sure a $100 deductable applies after you passed the 3/36k warranty period.
4play is offline
post #8 of 8 (permalink) Old 01-18-2009, 08:14 PM Thread Starter
Ah, that make sense. Thanks for enlightening me a second time 4play!
F3600 is offline
OASIS Report on 97 F-250 ejpowerstroke97 Ford Oasis requests 1 01-06-2008 12:35 AM
Oasis report please liftruck Ford Oasis requests 1 12-04-2007 11:24 AM
Oasis Report Please Rick65 Ford Oasis requests 1 12-04-2006 12:26 PM
Oasis Report Please and Thanks minnboy7 Ford Oasis requests 1 12-04-2006 12:22 PM
oasis report please flycut Ford Oasis requests 1 11-01-2006 08:40 PM
