Can someone help me out? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by supr87gt, this thread has received 6 replies and been viewed 702 times.
post #1 of 7 (permalink) Old 01-21-2009, 01:32 PM Thread Starter
supr87gt's Avatar
1FTWW31R28EA25438
Much appreciated.
Tom
supr87gt is offline
post #2 of 7 (permalink) Old 01-21-2009, 08:49 PM
4play's Avatar
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
8F716A0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/06/2007 BUILD DATE
02/14/2007 SALE MILEAGE
08B07
CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) AND INSTRUMENT CLUSTER (IC)
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/06/2008
DEALER: Ed Kenley Ford, Inc.
WARRANTY CLAIM NUMBER: 766086 ODOMETER: 028721M
LABOR OP
CONDITION CODE
CONDITION DESC
RAV REACQUIRED VEHICLE 000 RAV 82 FREIGHT/POSTAGE/MAINTENANCE
COMPLETED INSPECTION
11/06/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8B379B GASKET SET RAD TANK 001 08B06B
11/06/2008
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 1007A WHEEL ASSY 004 MT5C145 82 FREIGHT/POSTAGE/MAINTENANCE
8C3Z 3E652A BRACKET -STRG SHOCK 001 3001A
8C3Z 3E651E ABSORBER-STEERING SH 001 3001A6
W712055S439 004
W520114S441 004
W706196S439 001
W709296S441 004
7C3Z 3A093A BRKT (FRT SUSP TRACK 001
W706345S439 004
W710257S441 004
8C3Z 3B239A BAR ASY F/AXLE TRACK 001
7C3Z 5K483A LINK ASY-STAB BAR 002
W709373S439 004
W707243S441 004
5C3Z 5310DA FRONT SPRING 002
8C3Z 2078A HOSE ASY-BRAKE 001
8C3Z 2078BL HOSE ASY-BRAKE 001
7C3Z 5598HB SPACER REAR SPRING 001
7C3Z 5598JB SPACER REAR SPRING 001
5C3Z 5705AA U BOLT-REAR SPRING 004
N620485S441 008
5C3Z 3590BA ARM-STRG PITMAN 001
7C3Z 18124NEA ABSORBER KIT-FRT SHO 002
7C3Z 18125LEA ABSORBER KIT-REAR SH 002
9OO2 04320060000 004
OSP 001
11/06/2008
LABOR OP
CONDITION CODE
CONDITION DESC
ENTRE MULTI PNL PAINT REPR 000 OSL P3 SPRAY PANEL REPAIR (PAINT)
SUBLET TO CUTRUBUS CHRYSLER JEEP
05/08/2008
DEALER: Willey Ford - Bountiful
WARRANTY CLAIM NUMBER: 614647 ODOMETER: 025744M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9A543A PUMP ASY-FUEL INJECT 001 6007B 42 DOES NOT OPERATE PROPERLY
8C3Z 6619A GASKET (OIL PUMP) 001 6007B47
8C3Z 6619B GASKET (OIL PUMP) 001 6005F
8C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F1
8C3Z 9A332B HOSE ASY (FUEL HIGH 001 6005F1X1
W302674 003 6005F2
W302649 016 6600A
W302494 016 MT071208
8C3Z 6N640A GASKET TURBO TO MANI 004 6005F18
W302506 002 6005F45
W302515 001 6005F12
8C3Z 6N640B GASKET TURBO TO MANI 002
VC 7B 003
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 10W30QSD 016
W712878S439 006
W712879S439 002
W302474 002
8C3Z 6K682B TURBO CHG-EXH DRIVE 001
8C3Z 9T514A KIT-HDW TRBCH MTNG 001
W302870A 004
8C3Z 9J559A CONTROL ASY-ENG AIR 001
8C3Z 9J559BA CONTROL ASY-ENG AIR 001
7C3Z 5A231AC CLAMP-MUFFLER 001
7C3Z 6L612B GSKT-ENG CHG EXH OLE 001
388898S 002
XT 2QDX MOTORCRAFT BATTERY 002
VC 7B 004
OSP 002
1 CHECKE FOR A LACK OF LOW END POWER, FOUND IT HAD A LACK OF POWER THE OI L WAS OVER FULL. REMOVED THE VALVE COVER AND PERFOMRED THE HIGH PRESSURE FUE L LEAK TEST, REMOVED THE CAB REPALCED THE HIGH PRESSURE FUEL PUMP, THE HIGHT URBO AND THE ACCUATOR. 3 OF THE CAB BOLT NUTS SPUN, CHANGED THE OIL AND FILE R. TOPPED OFF ALL FUIDS, BLEED THE FULE COOLING SYSTEM A
05/08/2008
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229B GASKET CARB FUEL INL 001 12650D60 42 DOES NOT OPERATE PROPERLY
1 CHECEKD AND REPLACED CAM SESNOR O-RINGS. JP1626
05/08/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
1 INSPECTED AND INSTALLED THE REPAIR KIT. JP1626
05/08/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 5D090A PLT FR RL BK FUL TNK 001 08B03B
1 INSTALLED THE STOP BRACKET AS PER RECALL. JP1626
03/15/2008
DEALER: Larry H. Miller Ford
WARRANTY CLAIM NUMBER: 105483 ODOMETER: 024449M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8009B RADIATOR & SUPP ASY 001 8005A D8 FAILED GASKET/SEAL
24449 RADIATOR VERIFIED CONCERN FOUND COOLANT LEAKING FROM FRONT OF ENGINE PERFORMED A CCOLING SYSTEM PRESSURE TEST FOUND RADIATOR SIDE TANKS LEAKING REPLACED THE RADIATOR AND BLED COOLING SYSTEM NO LEAKS AT THIS TIME
03/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
RECALEM ECC PROCESSOR RECAL 000 071703A 04 SOFTWARE REVISION/FLASH MODULE
000 6005F12
000 6005F19
000 6005F33
24449 PCM UPDATE PERFORMED DIESEL DIAG SHEET FOUND NO CODES REFLASHED THE P CM WITH LATEST UPDATE PULLED FUEL FILTERS OUT RECOMEND TO CUST TO CHANGE F ILTERS
4play is offline
supr87gt (01-21-2009)
post #3 of 7 (permalink) Old 01-21-2009, 09:16 PM Thread Starter
supr87gt's Avatar
WOW!
Is this the norm with these trucks or is this thing beat? Almost looks like maybe been in an accident?
supr87gt is offline
post #4 of 7 (permalink) Old 01-21-2009, 10:51 PM
11/06/2008
LABOR OP
CONDITION CODE
CONDITION DESC
means ford bought it back from the previous owner
cb44473 is offline
The Following User Says Thank You to cb44473 For this addition to TDG:
post #5 of 7 (permalink) Old 01-21-2009, 11:03 PM Thread Starter
supr87gt's Avatar
Thank you sir. That appears to be what this particular dealership tends to do. Buy the buybacks.
supr87gt is offline
post #6 of 7 (permalink) Old 01-22-2009, 03:34 AM
4play's Avatar
i think buybacks are assigned to dealers, some are donated to schools, and some go to the auction pool.
4play is offline
post #7 of 7 (permalink) Old 01-22-2009, 03:50 AM
4play's Avatar
oh and that last big repair on 11/06/08 was a repair made to put vehicle back into factory condition. it was noted this truck had a lift kit and oversized tires. also noted the reason for the buy back is not told. i have had the experience in working on and fixing a re-aquired vehicle. during my repair i contacted the ford hotline for info concerning the buy back and they would not disclose to me. but they were very interested in what i did to repair. hmm? honestly i did not say.
4play is offline
supr87gt (01-22-2009)
