Oasis - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TommEyBoy, this thread has received 1 replies and been viewed 615 times.
post #1 of 2 (permalink) Old 01-27-2009, 12:10 AM Thread Starter
TommEyBoy's Avatar
Send a message via MSN to TommEyBoy
Oasis
can i ger a Oasis Please Thx guys
1FMSU43F12EA14768
Tom
2004.5 Dodge Ram 3500 Grand Rock Stacks, Smarty, Boost fooler. Pulls 2003 Kioti 25hp tractor with tools on 25' goose neck and 2005 28' Jayco Travel Trailer
TommEyBoy is offline
post #2 of 2 (permalink) Old 01-27-2009, 01:58 AM
OASIS RESULT:
1FMSU43F12EA14768
01/26/2009
21:57:48
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/20/2001 BUILD DATE
07/26/2001 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/28/2008
DEALER: Bergstrom Neenah-Menasha Ford
WARRANTY CLAIM NUMBER: 115238 ODOMETER: 118749M
LABOR OP
CONDITION CODE
CONDITION DESC
F7TZ 12K073B TRNSDC ASY-C/SHT PSN 001 07S57B
1 RECALL 07S57 COMPLETE NEW SENSOR INSTALLED
| On-line 1878
END OF OASIS REPORT FOR 1FMSU43F12EA14768
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 8 2B01 030701 F7TZ 12K073 A D03 42 16145
AWS Claim Key: 967339 Trx Code: S07 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 06169 - * Name: SERVICE MOTORS, INC. Ph: 920-9212120 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2002 Doc #:14555101
Cust Comments: CHECK ENGINE WILL NOT START, TURNS OVER WILL NOT FIRE
Tech Comments: NGS TEST, CODES P1670, PO344, REPLACED CAM POSITION SENSOR CLEAR ALL CODES, TEST DRIVE AND RECHECK
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 14 6J02 011404 * 2626412 * B05 41 22695
AWS Claim Key: 3086719 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02807 - * Name: RACETTE FORD OF OSHKOSH, INC. Ph: 920-2311610 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2002 Doc #:074913B
Cust Comments: C S DRIVER RR DOOR SOMETIMES DOES NOT OPEN FROM INSIDE CHILD LOCK IS OFF
Tech Comments: VERIFY REAR DOOR DOES NOT ALWAYS OPEN FROM INSIDE.CHILD SAFETY LATCH IS STICKING. LUBED LATCH AND R ECHECK OK.
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 14 5V09 12XXXX F81Z 2A451 BA C19 55 22695
AWS Claim Key: 3086718 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 02807 - * Name: RACETTE FORD OF OSHKOSH, INC. Ph: 920-2311610 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2002 Doc #:074913A
Cust Comments: NO VENTILATION THROUGH THE VENTS
Tech Comments: CK AND VERIFY AIR DISTRIBUTION ONLY COMING FROM DEFROST. PERFORM SELF TEST ON EATC W NGS. PERFORM PINPOINT TESTS. NO VACUUM SUPPLY FROM VACUUM MOTOR. CK POWER AND GROUND AT CIRCUITS 295 PIN 4 CONNECTOR C1119 (LB PK) AND BLACK WIRE CIRCUIT 57 AT C1119BOTH OK. CK FOR BLOCKAGE PUMP RESTRICTED. REPLACEDVACUUM PUMP AND RECHECK OPERATION
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 41 5T01 * * * * * * 73601
AWS Claim Key: 12349238 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2004 Doc #:05732801
Cust Comments: RECALL # 03B03 ADJUSTABLE ACCELERATOR PEDAL
Tech Comments: 1 1 RECALL 03S03 ADJUSTABLE PEDAL COMPLETED
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 53 2B01 0300XX F7TZ 12K073 A E29 42 89199
AWS Claim Key: 14694190 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2005 Doc #:07643902
Cust Comments: GUEST STATES WHEN DRIVING, ENGINE SEEMS TO CUT OFF & YOU CAN SEE THE RPM S DROP, THEN IT COMES RIGHT BACK ON.
Tech Comments: VERIFY GUEST CONCERN. VEHICLE DIED DRIVING INTO SHOP. PUSH V EHICLE IN SHOP. PERFORM EEC TEST. KOEO PASS. MEM P1670, P034 4 & P0340. PERFORM PINPOINT TEST FJ 1. POSSIBLE FALSE CODE, UNABLE TO RECREATE. USING NGS, PERFORM PID MONITOR TEST MONI TOR IPR & RPM, NO IPR CHANGE. HOOK UP KAM SENSOR TESTER & TE ST KAM SENSOR, NO LIGHT PULSE. R&R SENSOR & RETEST, OKAY. CL
1FMSU43F12EA14768 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 26-JUL-2001 20-AUG-2001 141104 USA 82 * * * * * * * 118749
AWS Claim Key: 16827128 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06226 - * Name: BERGSTROM NEENAH-MENASHA FORD Ph: 920-7279000 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2008 Doc #:11523801
Cust Comments: PERFORM CAMPAIGN 07S57
Tech Comments: 1 RECALL 07S57 COMPLETE NEW SENSOR INSTALLED
60psdboy is offline
The Following User Says Thank You to 60psdboy For this addition to TDG:
TommEyBoy (04-05-2011)
