OASIS Report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thesmokinstroke02, this thread has received 3 replies and been viewed 882 times.
post #1 of 4 (permalink) Old 01-27-2009, 11:48 PM Thread Starter
Hadley Coal Roller
thesmokinstroke02's Avatar
OASIS Report
vin 1FTSW31P14EC17490 please. thank you.
-Konnor-
Dark Grey 02 F-350 4x4 CC SB
Diesel Innovations 6pos Chip
DIY intake
Autometer C2 Gauges
Sky Manufacturing leveling kit
35" pro comps with mickey thompson classic locks
B.O.M.B Squad #75
Ridin' Dirty #19
American Club #75
Riding High Club #19 (The Dodge Got this one)
"Northern by birth, Southern by heart"
thesmokinstroke02 is offline
post #2 of 4 (permalink) Old 01-28-2009, 05:13 AM
********* and Mafia #90
Bcarriveau's Avatar
Moved to the Oasis Section.. .
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 4 (permalink) Old 01-28-2009, 05:33 AM
4play's Avatar
OASIS RESULT:
1FTSW31P14EC17490
01/28/2009
01:30:53
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/15/2004 BUILD DATE
02/17/2004 SALE MILEAGE
00020
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0736 - EXPIRED
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: JASON RODGERS
OPTIONS:
EXPIRATION DATE: 01/26/2006
DISTANCE: 73,648
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07313
ESP CONTRACT START DATE: 10/26/2005
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
08/12/2008
DEALER: Washington Ford, Inc.
WARRANTY CLAIM NUMBER: 034275 ODOMETER: 081352M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 081103B 42 DOES NOT OPERATE PROPERLY
VC 7B 003 081103A
6C3Z 5A231AA CLAMP-MUFFLER 001
6051 GASKET CYL HEAD 000
TECH 102 VERIFIED LOSS OF POWER & SMOKE. SYSTEM TEST, P0266, P0272, P0291, P 0478, P0678. PERFORMED TSB 08-11-03, FOUND EGR COOLER LEAKING. REPLACED COOL ER & RETEST, OK AT THIS TIME
07/21/2008
WARRANTY CLAIM NUMBER: 033209 ODOMETER: 080924M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9G489AARM KIT TRBCH CTR HSG RO 001 080407F 42 DOES NOT OPERATE PROPERLY
6K682 TURBO CHG-EXH DRIVE 000
TECH 102 VERIFIED CONCERN. DI SYSTEM TEST, P0299. PERFORMED DIAGNOSIS AS PER TSB 08-04-07. REPLACED TURBO CHRA AS PER TSB. RETEST, OK
06/24/2008
WARRANTY CLAIM NUMBER: 031862 ODOMETER: 080309M
LABOR OP
CONDITION CODE
CONDITION DESC
VC 7B 003 081103A
6051 GASKET CYL HEAD 000 081103G
TECH 102 VERIFIED OVERHEAT, WHITE SMOKE. PERFORMED DIAGNOSIS AS PER TSB 08-1 1-03, ENGINE IS HYDROLOCKED. REMOVED GLOW PLUGS TO VENT. REPLACED LEAKING EG R COOLER & TEST OIL COOLER. MONITORED EOT & ECT. ROADTEST, OK AT THIS TIME
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 0 5B03 050301 * 3254 * N50 42 5
AWS Claim Key: 534525 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2004 Doc #:05815351
Cust Comments: CK FOR SQUEELING NOISE IN FRT END
Tech Comments: TECH 111 VERIFIED CONCERN. ISOLATE NOISE COMING FROM END OF RT SIDE AXE TUBE. LUBED SEAL AND RETEST. OK AT THIS TIME.
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 1 5G03 040104 * 3280 * N58 42 2125
AWS Claim Key: 633152 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 03856 - * Name: COUNTRY FORD LTD Ph: 516-7357400 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:05880451
Cust Comments: CUST STATES KNOCKING NOISE IN STEERING
Tech Comments: VERIFIED CUSTOMERS NOISE CONCERN AND EXPLAINED TO CUSTOMER THE STEERINSTOPS WERE CAUSING NOISE CONCERN AND ITS A NORMAL CHARACTERISTIC OF FRONT END CUSTOMER WANTED US TO CHECK
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 1 3A11 070100 * 7000 * P83 42 2125
AWS Claim Key: 633153 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03856 - * Name: COUNTRY FORD LTD Ph: 516-7357400 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2004 Doc #:05880452
Cust Comments: CUST STATES HESITATION IN TRANSMISSION SHIFTING
Tech Comments: CHECKED CONCERN FOR CUSTOMERS SATISFACTION HE STATED ITS NOT LIKE HIS OTHER VEHICLE TESTED TRANSMISSION AND SHIFT POINTS OK NO REPAIRS NEEDED AT THIS TIME ALL OK
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 1 2G04 000615 * DIAG * D36 82 3293
AWS Claim Key: 1022440 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2004 Doc #:05999252
Cust Comments: CK FOR ENGINE FEELS LIKE HAS SURGE ON ACCELL FEELS LIKE ENGINE IS BUILDING POWER ON ACCELL
Tech Comments: TECH 161 COULD NOT VERIFY SURGE ON ACCELL. CK FOR UPDATED CALIBRATION IN PCM, TCM, FICM NONE AVAILABLE. PERFORMED SYSTEM TEST, NO CODES. ROADTEST WITH WDS PID MONITOR, BOOST OK, 0 23 PSI, EBP FINE, ALL PIDS IN SPEC. AT THIS TIME NO PROBLEM CAN BE FOUND
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 1 5V01 0503XX * 3B396 * N50 82 3293
AWS Claim Key: 1136897 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2004 Doc #:05999254
Cust Comments: REFUND FOR RENTAL WHILE IN NEW YORK FOR REPAIR
Tech Comments: REFUND FOR RENTAL WHILE IN NEW YORK FOR REPAIR
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 1 2H01 030008 * 6K682 * E42 D8 3293
AWS Claim Key: 1004380 Trx Code: S07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2004 Doc #:05999255
Cust Comments: CK FOR POSS EXHAUST LEAK MAY BE FROM AROUND FIREWALL
Tech Comments: TECH 161 CK FOR EXHAUST LEAK. CK AND TIGHTENED ALL CLAMPS ON PIPES ON TURBO. ALL OK. NO EXHAUST LEAKS AT THIS TIME
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 12 5V01 050306 1C3Z 3B396 CB N50 42 30991
AWS Claim Key: 3820400 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2005 Doc #:07517251
Cust Comments: FRNT END CLANKS WHEN TURNING HAD IT LOOKED AT FORD DEALER IN NEW YORK FIXED TEMPORARLY NOW IT IS CLANKING AGAIN,POSS U JTS MAKING NOISE
Tech Comments: TECH 165 VERIFIED CONCERN. FOUND LEFT FRT HUB NOT DISENGAGING. BCE TEST, CK CIRCUITS 145, GY BK,C281A, PIN 7. CK CIRCUITS 605, RED AT C281, PIN 6 AND C1247 ALL OK. TESTED VAC TO STRG KNUCKLE, OK. CK HUB FOR VAC LEAK, OK. REPLACED HUB ASSY AND RETEST,OK
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 12 2G05 031405 * RECAL * G29 42 30991
AWS Claim Key: 3820401 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2005 Doc #:07517252
Cust Comments: CK FOR WATER IN FUEL LIGHT IS ON
Tech Comments: TECH 165 VERIFIED CONCERN. RAN OASIS AND FOUND TSB 04 19 04. REPROGRAMMED PCM, TCM AND FICM AS PER TSB. RETEST, OK
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 12 1H03 030008 3C3Z 9F452 AC D36 42 35219
AWS Claim Key: 4227908 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAR-2005 Doc #:07662451
Cust Comments: CHECK FOR ENGINE SURGES ON HIGHWAY AT 60 70 MPH ON A GRADE AT STEADY SPEEDS,GOES AWAY WHEN YOU LET UP,ALSO BOGGS DOWN SOMETIMES WHEN TAKEOFF STOPS
Tech Comments: TECH 129 VERIFIED CONCERN. PERFORMED DI PERFORMANCE DIAG FOR CODES P0404, P0470. PERFORMED EGR POSITION TEST, 2.2V CLOSED, 2.2V OPEN. REPLACED EGR VALVE AND TESTED EXHAUST SENSOR, EBP SENSOR DOESNT CHANGE. REPLACED EBP SENSOR. ROADTEST, RETEST, OK
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 20 * * * * * * * 69619
AWS Claim Key: 7564278 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:08920852
Cust Comments: RECALL 05S34
Tech Comments: TECH 102 REPLACED FICM HARNESS AND CONNECTOR AS PER 05S34
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 20 5K06 * * * * * * 69619
AWS Claim Key: 7564280 Trx Code: 04C07 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:08920855
Cust Comments: RECALL 04C07
Tech Comments: TECH 102 INSPECTED TIRES AS PER 04C07 ALL OK
AWS Claim Key: 7579415 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:08920854
Cust Comments: RECALL 59B01
Tech Comments: TECH 102 ROADTEST AS PER 59B01
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 20 2H01 * * * * * * 69619
AWS Claim Key: 7564277 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:08920851
Cust Comments: RECALL 05B29
Tech Comments: TECH 102 REPLACED CAC DUCT AS PER 05B29
AWS Claim Key: 7564279 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:08920853
Cust Comments: RECALL 05E15
Tech Comments: TECH 102 REPLACED EP SENSOR AND CONNECTOR AND RECAL AS PER 05E15
1FTSW31P14EC17490 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-FEB-2004 15-MAR-2004 144443 USA 29 2E05 100106 6C3Z 9B249 B D36 42 75432
AWS Claim Key: 9832777 Trx Code: E72 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 07313 - * Name: WASHINGTON FORD, INC. Ph: 724-2235100 St:PA Ctry Cd: USA Reg Cd: NA Repr Date:11-JUL-2006 Doc #:00073651
Cust Comments: WILL NOT RUN GOOD WATER IN FUEL LAMP ON,BLACK SMOKE OUT EXHAUST,ALSO LOSS OF POWER,STARTED HAPPENING LAST THURSDAY,AFTER IT GETS WARMED UP
Tech Comments: TECH 102 VERIFIED LOSS OF POWER. DI SYSTEM TEST FOR CODES P0299,P0341,P0404,P0405,P0478,P2269. PID MONITOR, ONLY 12 PSI BOOST. FOUND CAC TUBE LEAKING. REPLACED CAC TUBE. FOUND EB TUBE PLUGGED. CLEANED OUT TUBE AND REPLACED EB. REROADTEST AND FOUND EGR NOT CLOSING, STAYING AT .98. REPLACED EGR AND RETEST. HAS ONLY CODE P2269. REPLACED FUEL MANIOFLD & WIF SENSOR & REPROGRAM AS PER TSB 06 06 05. RETE
4play is offline
post #4 of 4 (permalink) Old 01-28-2009, 01:35 PM Thread Starter
Hadley Coal Roller
wow. okay thanks. somebody chime in with how much stuff has been replaced and if its not alot for this year or it is and if should steer clear from this truck
-Konnor-
DIY intake
Autometer C2 Gauges
B.O.M.B Squad #75
Ridin' Dirty #19
American Club #75
Oasis report please, Thanks! parasail Ford Oasis requests 3 06-11-2007 04:18 PM
Oasis Report Please imported_bulldogdad Ford Oasis requests 1 05-21-2007 03:14 AM
oasis report sledstorm1 Ford Oasis requests 2 08-15-2006 02:01 AM
oasis report if you please! willmceliece Ford Oasis requests 1 08-11-2006 02:28 AM
Oasis Report Please hydromatikman Ford Oasis requests 1 08-11-2006 02:20 AM
