Oasis Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Blk350on20s, this thread has received 1 replies and been viewed 462 times.
post #1 of 2 (permalink) Old 01-28-2009, 01:50 AM Thread Starter
BLING BLING
Blk350on20s's Avatar
Send a message via AIM to Blk350on20s
Oasis Please
Can I get an Oasis report please. VIN 1FTWW31P85EA66912. Thanks in advance. Ryan
08 F350 4x4 CCSB 6.4, 6" on 37s and 22s, Spartan DD w/ 310/KEM 345, Elite HPFP, Ported rails, EGR delete w/ wastegate, studs, CFM +, Rudys IC pipe, BD BOV, FASS 150 w/ custom fuel system, S&B intake, Rudys downpipe and DOC/DPF delete, CCV mod, Zex nitrous, Suncoast Trans, 1 piece drive shaft, Recon and tint everywhere. Under Construction
Blk350on20s is offline
post #2 of 2 (permalink) Old 01-28-2009, 04:11 AM
4play's Avatar
OASIS RESULT:
1FTWW31P85EA66912
01/28/2009
00:09:20
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/31/2004 BUILD DATE
09/16/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
AWS Claim Key: 1173392 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:21712906
Cust Comments: AOR REPLACE FRONT STABILIZER SHOCK DUE TO EXCESSIVE LEAKING VERIFIED BY SERVICE MANAGER
Tech Comments: CC42 3E651 M O 12088 DIAG STEERING DAMPER LEAKING OIL. REPLACED STEERING DAMPER ADD JAB
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 6 3A11 * * * * * * 12087
AWS Claim Key: 1173395 Trx Code: 05B27 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:21712902
Cust Comments: 05B27 TRANS REVERSE PLANET RECALL
Tech Comments: MO 12118 R&I TRANS. MOUNTED ON BENCH DISSAMBLED & REPLACED REV. SNAP RING PER 05B27 PROGRAM. REROAD TESTED.
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 6 6N04 010802 5C3Z 16720 NA B66 D7 12087
AWS Claim Key: 1173393 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:21712904
Cust Comments: ALL F350 EMBLUMS ALL THE WAY AROUND THE TRUCK ARE PEELING (3 EMBLUMS)
Tech Comments: 12087 16720 D7 REPLACED ALL THREE OUTSIDE EMBLEMS WERE PEELING BOTH FENDERS AND TAILGATE OK NOW
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 6 2G04 000615 * NPF * P59 82 12087
AWS Claim Key: 1173396 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:21712901
Cust Comments: TRANS SEEMS TO BE SLIPPING WHEN DOWNSHIFTING, SEEM STO SLAM WHEN SLOWING DOWNA
Tech Comments: MO 12118 OASIS#416113784 ROAD TESTED , EEC TESTED NO CODES, CHECKED FLUID . NO PROBLEM FOUND AT THIS TIME.
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 6 5V01 060301 * 1125 * N27 49 12087
AWS Claim Key: 1173394 Trx Code: E84 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-JUN-2005 Doc #:21712903
Cust Comments: WHEN BRAKING AT E WAY SPEEDS THERE SEEMS TO BE A BAD VIBRATION
Tech Comments: MO12095 CC49 1125 2C026 ROAD TEST AND VERIFY CONCERN. BRAKE INSPECTION. FRONT AND REAR ROTORS HAVE BRAKE PAD TRANSFER ON ROTORS. RESURFACE FRONT AND REAR ROTORS OVL. ROTOR SPEC LF377MM TO 374MM LR337MM TO 334MM RR339MM TO 335MM. REMOVED REAR DRIVE SHAFT TO RESURFACE REAR ROTORS. ROAD TEST OK. RIGHT FRONT ROTOR HAS DAMAGE FROM LOOSE LUG NUTS AT ONE TIME,COULD NOT RESURF
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 6 1G03 030507 * 8620 * E19 42 12594
AWS Claim Key: 1375685 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2005 Doc #:21816804
Cust Comments: BELTS ARE SQUEAKING, PLEASE CHECK AND ADVISE
Tech Comments: CAUSEL 8620 CODE 42 MO 12595 REPLACED SERP BELT
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 14 * * * * * * * 26550
AWS Claim Key: 3585480 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856F
Cust Comments: 05B32 COOLANT DEGAS BOTTLE
Tech Comments: 26552 INSTALL LABEL AND SET COOLANT LEVEL PER PROGRAM. 05B32B 0.2 HR
AWS Claim Key: 3585481 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856G
Cust Comments: 59B01 TEST DRIVE
Tech Comments: 26552 ROAD TEST VEHICLE PER PROGRAM. 59B02A 0.3 HR
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 14 6P07 010301 * 5420124 * F06 42 26550
AWS Claim Key: 3585478 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856C
Cust Comments: CUSTOMER STATES THAT THE PAINT IS FLAKING AROUND WINDOW BELT MOLDINGS ON BOTH FRONT DOORS
Tech Comments: WARRANTABLE CONCERN, CUSTOMER TO SCHEDULE WITH BODY SHOP
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 14 6N04 010802 5C3Z 16720 NA B66 42 26550
AWS Claim Key: 3684168 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856D
Cust Comments: CUSTOMER STATES THAT THE DRIVER F350 EMBLEM PAINT IS PEELING
AWS Claim Key: 3585479 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856E
Cust Comments: 05E15 EBP SENSOR
Tech Comments: 26552 REPLACE EBP SENSOR AND PLUG END AND REPROGRAM MODULES PER RECALL. 05E15G 1.3 HR
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 14 2E06 030008 4C3Z 9E527 AA D13 42 26550
AWS Claim Key: 3585477 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 02709 - * Name: TOM HOLZER FORD, INC. Ph: 248-4741234 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2006 Doc #:224856A
Cust Comments: CUSTOMER STATES THAT THE ENGINE RUNS ROUGH
Tech Comments: 26552 INJECTOR INOP PERFORMANCE DIAG STEPS 1 23, CODE P0281, REPLACE #7 CYL FUEL INJECTOR, CLEAR CODES AND RETEST, PASS CODES, ROAD TEST, OK. CC 42 CP 9E527
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 16 7Q02 12XXXX 5W7Z 12A647 A A35 42 28701
AWS Claim Key: 4194605 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03003 - * Name: BILL BROWN FORD, INC. Ph: 734-4217000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:089485A
Cust Comments: CK ADV AMBIENT OUTSIDE TEMPERATURE READING TOO HIGH SOMETIMES READS 110 DEGREES
Tech Comments: 28701 CC 42 CP 12A647 CK PINPOINT TEST AMBIENT TEMP SENSOR READING 82 DEGREES.ACCESS GRILLE & REPL AMBIENT TEMP SENSOR. RETEST OK 62 DEGREES.
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 16 1G04 0305XX * 6B209 * E19 42 28701
AWS Claim Key: 4194606 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03003 - * Name: BILL BROWN FORD, INC. Ph: 734-4217000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:089485C
Cust Comments: CK ADV FOR BELT CHIRP ALL SPEEDS
Tech Comments: 28701 CC 42 PERFORMED A VISUAL INSPECTION OF BELT, FOUND BELT GLAZED, ACCESSED AND REPLACED THE BELT OK AT THIS TIME.
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 20 1A02 030102 4C3Z 6051 EA D21 D8 38372
AWS Claim Key: 5688228 Trx Code: E72 Labor Hrs: 20.8
Dlr Cd-Sub Cd: 02707 - * Name: BRIGHTON FORD-MERCURY, INC. Ph: 810-2271171 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2006 Doc #:24227501
Cust Comments: 100.00 POWERSTROKE CK FOR LOSS OF POWER RUNS ROUGH, BLOWING COOLANT WHEN TOWING A LOAD
Tech Comments: MO 38384 CCD8 6051 INSPECTED VEHILCE. PERFROMED DIESEL DIAG P0299 PO478 P0284. PERFORMED PIN POINT TEST. MISSFIRING FUEL INJECTOR ON CYL NUMBER 8 BANK 2. RELATIVE COMPRESSION TEST PERFROMED ALL CYL OK. VGT VANE POSITION TEST PERFROMED AND KA PIN POINT TEST. STICKING VANES IN TURBO. TSB06171B. UPDATED VGT INSTALLED. PERFORMED COOLANT PSI TEST TO 16 PSI FOR 5 MIN DROP OF 7 PSI
1FTWW31P85EA66912 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 16-SEP-2004 31-DEC-2004 148508 USA 28 2E03 030402 4C3Z 9E527 AA D42 42 50634
AWS Claim Key: 7557860 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 09708 - * Name: DON SEELYE FORD, INC. Ph: 269-3753820 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2007 Doc #:74015801
Cust Comments: HARD STARTING WHEN COLD SMOKES ALOT AND HAS NO POWER UNTIL TRUCK IS WARMED UP
Tech Comments: 6.0 DIT PERFORMACE DIAGNOSTICS,VISUAL,OIL,FUEL,INSPECTION MONITOR RECORD PID DATA,FUEL PRESSURE INLET RESTRICTION TEST EEC TEST,KOEO PASS,CONT P0269,P0275,P0404,PINPOINT TEST W,P1 ,KOEO INJ ELEC,KOER, PERFORMED EGR VALVE CLEANING PER 061906A,CC#55 REPROGRAMMED FICM PER 070504A,CC#42 RETESTED VEHICLE AFTER SETTING OVERNIGHT REPLACED LEFT BANK #2 & #4 FUEL INJECTORS AND RIGHT BANK #3 & #5 FUEL INJEC
4play is offline
