Oasis 1FTNW21P74ED06939 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hb8811, this thread has received 2 replies and been viewed 734 times.
post #1 of 3 (permalink) Old 01-28-2009, 05:46 AM Thread Starter
rookie
hb8811's Avatar
I would appreciate it if some one can pull a report for this VIN 1FTNW21P74ED06939
Thanks
hb8811 is offline
post #2 of 3 (permalink) Old 01-28-2009, 02:52 PM
4play's Avatar
OASIS RESULT:
1FTNW21P74ED06939
01/28/2009
10:51:32
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/21/2004 BUILD DATE
03/31/2004 SALE MILEAGE
00008
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0707 - USA 2004 NEW 60/75,000 EXTRACARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: FREDERICK UIHLEIN
OPTIONS:
EXPIRATION DATE: 04/21/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 01862
ESP CONTRACT START DATE: 04/21/2004
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
02/07/2008
DEALER: Western Slope Auto Company
WARRANTY CLAIM NUMBER: 355152 ODOMETER: 050172M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642AA COOLER CRANKCASE OI 001 6007D 42 DOES NOT OPERATE PROPERLY
3C3Z 9433AA GASKET SET-MANIFOLD 001 6642A
XO 10W30QSD 015
50184 D8 CRACKED OIL COOLER HOUSING VERIFY OIL LEAK DYE ENG OIL CHECK WITH UV LAMP FOUND COMING FROM FRONT LEFT SIDE OF OIL COOLER HOUSING REMOVE TURB O, RADIDATOR, FAN, FAN, INNE SHROUD AND INTAKE FOUND OIL COOLER HOUSING CRA CKED NECESSARY TO REPLACE OIL COOLER REASSEM BLE REFILL FLUIDS AND TEST DRI VE REINSPECT NO FURTHER EVIDENCE OF OIL LEAKAGE.
02/01/2008
WARRANTY CLAIM NUMBER: 354737 ODOMETER: 050172M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6A642AA COOLER CRANKCASE OI 001 080307B 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001 12650D
VC 7B 003 12650D45
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 10W30QSD 015
6051 GASKET CYL HEAD 000
50172 42 FAILED OIL AND EGR COOLERS TEST DRIVE VERIFY CONCERN RUN EEC TESTS RETRIEV DTC P-0404 P-0299 PERFROM PIN POINT TEST FOUND EGR VALVE STICKING OPEN AT 2.1V WHEN COMMANDED CLOSED REMOVE EGR VALVE FOUND WET WITH COOLANT PERFORM TSB 08-3-7 EGR COOLER FAILED PRESSURE TEST AND OIL COOLER FAILED T EMP TEST AT 30DEG F DIFFERANCE IN EOT AND ECT NECESSARY TO REPLAC EGR AND OI
AWS Claim Key: 1677226 Trx Code: S07 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2004 Doc #:07073001
Cust Comments: CUST STATES ENGINE CUTS OUT AND LACKS POWER
Tech Comments: DIAG AND REPLACED EGR AND VGT AND EBB SENSORS CLEARED CODE ROAD TESTED
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 4 2G01 030008 4C3Z 12B599 AARM D13 42 7616
AWS Claim Key: 1704171 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2004 Doc #:07083901
Cust Comments: CUST STATES SES LIGHT AND GLOW PLUG LIGHT COME AND ENGINE LOOSES POWER AND RUNS ROUGH
Tech Comments: CODE P2614 P2617 DIAG AND REPLACED FICM MODULE CLEARED CODES ROAD TESTED
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 15 * * * * * * * 24402
AWS Claim Key: 5770997 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2005 Doc #:07677802
Cust Comments: CUST STATES RECALL 05S34 CHARGE AIR COOLER DUCT
Tech Comments: INSTALLED AIR CHARGE COOLER DUCT
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 15 1H03 030008 4C3Z 9J460 A D50 42 24402
AWS Claim Key: 5749442 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2005 Doc #:07677804
Cust Comments: CUST STATES ENGINE CUTS OUT WHILE DRIVING SOMETIMES
Tech Comments: CODE P0299 P0472 DIAG AND REPLACED EBP AND VGT CLEARED CODES AND ROAD TESTED
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 15 2H01 * * * * * * 24402
AWS Claim Key: 5770996 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2005 Doc #:07677803
Cust Comments: CUST STATES RECALL 05B29 FUEL INJECTOR CONTROL MODULE WIRING HARNESS
Tech Comments: INSTALLED FUEL INJECTOR CONTROL MODULE WIRING HARNESS
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 22 * * * * * * * 34090
AWS Claim Key: 8303977 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:08104002
Cust Comments: CUST STATES RECALL 05E15 EBP SENSOR AND RECALIBRATIONS
Tech Comments: INSTALLED EBP SENSOR AND COMPLETED MULTIPLE CONTROL MODULE RECALIBRATIONS TO SPECS
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 22 3A03 * * * * * * 34090
AWS Claim Key: 8317357 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:08104001
Cust Comments: CUST STATES RECALL 04B24 TRANSMISSION REVERSE PLANET REPLACEMENT
Tech Comments: DIAG AND COMPLETED TANSMISSION OVERHAUL INCLUDING VALVE BODY REPLACED OIL TO AIR COOLER FLUSHED COOLER LINES REPLACED IN LINE FILTER ADDED FLUID TO SPECS ROAD TESTED
AWS Claim Key: 8303976 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:08104003
Cust Comments: CUST STATES RECALL 59B01 TEST DRIVE
Tech Comments: 10 COMPLETED TEST DRIVE
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 22 5V09 120307 6C3Z 2A451 A C19 42 34251
AWS Claim Key: 8332100 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01862 - * Name: STEAMBOAT MOTORS, LLC Ph: 970-8791299 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:08115601
Cust Comments: CUST STATES HEAT BLOWS OUT DEFROSTERS ONLY
Tech Comments: VACUUM PUMP DIAG AND REPLACED VACUUM PUMP CONFIRMED OPERATION
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 47 1A02 030102 * 6051 * D42 42 50172
AWS Claim Key: 12461697 Trx Code: E72 Labor Hrs: 7
Dlr Cd-Sub Cd: 03182 - * Name: WESTERN SLOPE AUTO COMPANY Ph: 970-2430843 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-FEB-2008 Doc #:354737A
Cust Comments: WHITE SMOKE FROM EXHAUST, WOULD NOT PULL OVER 50MPH. NO MIL; CHECK AND ADVISE
Tech Comments: 50172 42 FAILED OIL AND EGR COOLERS TEST DRIVE VERIFY CONCERN RUN EEC TESTS RETRIEV DTC P 0404 P 0299 PERFROM PIN POINT TEST FOUND EGR VALVE STICKING OPEN AT 2.1V WHEN COMMANDED CLOSED REMOVE EGR VALVE FOUND WET WITH COOLANT PERFORM TSB 08 3 7 EGR COOLER FAILED PRESSURE TEST AND OIL COOLER FAILED TEMP TEST AT 30DEG F DIFFERANCE IN EOT AND ECT NECESSARY TO REPLAC EGR AND OIL
1FTNW21P74ED06939 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-MAR-2004 21-APR-2004 156495 USA 47 1B03 030204 3C3Z 6A642 AA L65 42 50172
AWS Claim Key: 12461698 Trx Code: E72 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 03182 - * Name: WESTERN SLOPE AUTO COMPANY Ph: 970-2430843 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:07-FEB-2008 Doc #:355152A
Cust Comments: AFTER REPAIR ON RO 354737 FOUND OIL LEAKING FROM ENGINE ON TEST DRIVE
Tech Comments: 50184 D8 CRACKED OIL COOLER HOUSING VERIFY OIL LEAK DYE ENG OIL CHECK WITH UV LAMP FOUND COMING FROM FRONT LEFT SIDE OF OIL COOLER HOUSING REMOVE TURBO, RADIDATOR, FAN, FAN, INNE SHROUD AND INTAKE FOUND OIL COOLER HOUSING CRACKED NECESSARY TO REPLACE OIL COOLER REASSEM BLE REFILL FLUIDS AND TEST DRIVE REINSPECT NO FURTHER EVIDENCE OF OIL LEAKAGE.
4play is offline
hb8811 (01-28-2009)
post #3 of 3 (permalink) Old 01-28-2009, 09:38 PM Thread Starter
rookie
hb8811's Avatar
Thank you
hb8811 is offline
