Requesting OASIS report - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Scotty, this thread has received 2 replies and been viewed 596 times.
post #1 of 3 (permalink) Old 01-29-2009, 06:41 PM Thread Starter
What's that funny noise..
Just bought an 03 F250 6.0. Would like an Oasis report on it:
1FTNW21P43EB36747
Thank you!
Scotty is offline
post #2 of 3 (permalink) Old 01-29-2009, 07:59 PM
4play's Avatar
OASIS RESULT:
1FTNW21P43EB36747
01/29/2009
15:58:00
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
31 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/19/2002 BUILD DATE
11/21/2002 SALE MILEAGE
00003
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 1 * * * * * * * 6
AWS Claim Key: 332393 Trx Code: TDE Labor Hrs: 1
Dlr Cd-Sub Cd: 04274 - * Name: BIG VALLEY AUTO Ph: 575-3568584 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-2002 Doc #:10643501
Cust Comments: REPLACE BUMPER DAMAGED IN TRANSIT
Tech Comments: REPLACE FRT BUMPER.
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 1 7S12 180101 * 19B573 * C05 X2 1629
AWS Claim Key: 388868 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04274 - * Name: BIG VALLEY AUTO Ph: 575-3568584 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2003 Doc #:10674601
Cust Comments: CUST STATES VEHICLE A C DOES NOT BLOW COLD.
Tech Comments: A C COMPRESSOR NOT COMING ON. CHECKED FUSES, CHECKED R134A FREON LEVEL. GROUNDS GOOD. NO POWER AT CONNECTOR C100, PIN 1 RESEATED PIN 1 IN CONNECTOR C100 AT A C COMPRESSOR. A C FUNCTIONING CORRECTLY AT THIS TIME.
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 13 2E01 * * * * * * 22041
AWS Claim Key: 4068009 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20316 - * Name: ROSWELL FORD LINCOLN MERCURY, INC. Ph: 505-6233673 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2004 Doc #:12392001
Cust Comments: RECALL 03B05
Tech Comments: COMPLETED RECALL 03B05 NAD 03B06 PER RECALL INSTRUCTIONS REPROGRAMED MULTIPLE MODULES AND REPLACED THE ICP SENSOR
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 13 2G05 * * * * * * 22041
AWS Claim Key: 4049330 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 20316 - * Name: ROSWELL FORD LINCOLN MERCURY, INC. Ph: 505-6233673 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2004 Doc #:12392005
Cust Comments: 03B06 COLD OPERATION CALIBERATION RE PROGRAM
Tech Comments: 03B06 COLDOPERATION CALIBERATION RE PROGRAM COMPLETED
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 25 2E06 030008 3C3Z 9E527 AE D21 42 36903
AWS Claim Key: 8930427 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 20403 - * Name: CHALMERS CAPITOL FORD LINCOLN MERCURY Ph: 505-4733673 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:10-DEC-2004 Doc #:09429151
Cust Comments: CK VEHICLE JUST QUIT ON ROAD,WOULD CRANK & WOULDNT START ALSO LACK OF POWER & RUNNING ROUGH ADVISE
Tech Comments: FUEL PRESSURE,50PSI WITHIN SPECS,REPLACED #2 & #8 INJECTORS,RETESTED SYSTEM PASS,TEST DROVE
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 25 2E06 100106 3C3Z 9G282 AF D21 42 37308
AWS Claim Key: 9705751 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 20403 - * Name: CHALMERS CAPITOL FORD LINCOLN MERCURY Ph: 505-4733673 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC-2004 Doc #:09510851
Cust Comments: CK FOR SPUTTERING & LACK OF POWER ON INCLINE ADVISE WAS JUST IN WE REPLACED 6 INJECTORS ALREADY
Tech Comments: FOUND FUEL PUMP MAKING NOISE,TOOKFUELPRESSURE READING DROPING BELOW FUELPUMP ASSEMBLY,RETESTED 50PS UNDER LOAD EXCESSIVEDIAG TIME DUE TO INTERMITTENT FAILURE
1FTNW21P43EB36747 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-NOV-2002 19-DEC-2002 156516 USA 43 * * * * * * * 57618
AWS Claim Key: 14038498 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06822 - * Name: PANHANDLE MOTOR COMPANY Ph: 580-6253262 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:01153701
AWS Claim Key: 14038499 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06822 - * Name: PANHANDLE MOTOR COMPANY Ph: 580-6253262 St:OK Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:01153702
4play is offline
Scotty (01-29-2009)
post #3 of 3 (permalink) Old 01-29-2009, 08:26 PM Thread Starter
Thank you very much! I appreciate your time!
Scotty
Scotty is offline
Please Read Before Requesting A Report Rcannon Ford Oasis requests 6 02-26-2009 12:05 PM
Requesting OASIS report please MileHigh Ford Oasis requests 1 02-01-2008 12:50 AM
Requesting for an OASIS report gssuperduty Ford Oasis requests 2 08-04-2007 01:24 PM
Requesting Oasis Report, Please laduckdog Ford Oasis requests 2 05-16-2007 01:35 AM
requesting an oasis report fyreman94 Ford Oasis requests 1 03-30-2007 01:48 AM
