oasis report please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rcarson10, this thread has received 3 replies and been viewed 1186 times.
post #1 of 4 (permalink) Old 01-29-2009, 06:58 PM Thread Starter
Smile oasis report please
here is my vin 1FTWW33R08EA24897 THANKS FOR YOUR TIME
rcarson10 is offline
post #2 of 4 (permalink) Old 01-29-2009, 08:04 PM
4play's Avatar
OASIS RESULT:
1FTWW33R08EA24897
01/29/2009
16:03:23
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
8F716A0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL REGION CONTACT
Click here for CUDL
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/21/2007 BUILD DATE
02/21/2007 SALE MILEAGE
08B07
CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) AND INSTRUMENT CLUSTER (IC)
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
11/12/2008
DEALER: Performance Ford
WARRANTY CLAIM NUMBER: 029398 ODOMETER: 111585M
LABOR OP
CONDITION CODE
CONDITION DESC
6007 ENGINE ASSY 000 6005E43 42 DOES NOT OPERATE PROPERLY
6C3Z 6K786EA CLAMP AIR COOLING 001 6584AL
8C3Z 6W651A HOS-ENG CHG AIR TUB 001 9527AR
6C3Z 6K786CA CLAMP AIR COOLING 001 6731A
8C3Z 9E527A NOZZLE ASY-FUEL INJE 001
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 015
LEAKING INJECTOR VERIFY CONCERN, OIL LEVEL OVER FULL DUE TO FULL OF DIESE L DRAIN OIL AND REFILL,PERFORM TSB 07-08-09,SEC.A.REMOVE BOTH VALVE COVERS,S TART THE ENGINE,NO LEAK FOUND. HIGH PRESSURE FUEL SYS TEST,24,000 PSI # 7 IN J. LEAKING PAST TOP NUT,REPL. #7 INJ. RETEST,OIL WAY OVER FULL AGAIN,DRAIN A ND REFILL,RETE ST,AND ROAD TEST.
10/15/2008
DEALER: All Star Ford-Mercury, Inc.
WARRANTY CLAIM NUMBER: 171325 ODOMETER: 111501M
LABOR OP
CONDITION CODE
CONDITION DESC
6007 ENGINE ASSY 000 6005F 42 DOES NOT OPERATE PROPERLY
8C3Z 6584A GASKET VALVE ROCKER 001 6005F13
8C3Z 6721A GSKT-OIL FILL CAP SE 001 6005F1
8C3Z 9E933A GSKT-EGR TO-TH-BDY 002 6005F2
W301924 003 6005F14
8C3Z 9E933B GSKT-EGR TO-TH-BDY 001 6005F6
8C3Z 9A332B HOSE ASY (FUEL HIGH 001 6005F1X1
8C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F10
8C3Z 6710A GASKET SET-OIL PAN 001 6005F18
8C3Z 6049BB CYLINDER HEAD 001 6005F12
8C3Z 8287G CLAMP ASY-RAD HOSE 001 6007B
8C3Z 6108F PISTON & PIN ASY 001 6007B24
8C3Z 6211A BEARING ROD 001
8C3Z 9229A GASKET CARB FUEL INL 003
W302475 001
W302474 006
8C3Z 8287H CLAMP ASY-RAD HOSE 001
8C3Z 9J559A CONTROL ASY-ENG AIR 001
W302448 001
W302511 001
W302512 001
8C3Z 9T514B KIT-HDW TRBCH MTNG 001
W302474 004
3C3Z 9439AA GASKET-INTAKE MANIFO 002
8C3Z 6N640A GASKET TURBO TO MANI 002
7C3Z 6L612B GSKT-ENG CHG EXH OLE 001
8C3Z 6N640B GASKET TURBO TO MANI 002
6C3Z 9448A GSKT EXH MNFLD TO CY 001
XO 15W40QSD 015
TEST ENGINE,MISSFIRING.CK AND RECIEVE CODE P0266.RAN POWER BALANCE FOUND #2 MISFIRING.RAN RELATIVE COMPRESSION TEST,WEAK. MANUAL TEST ONLY 125 PSI OF CO MPRESSION.REMOVED ROCKER ARMS FOR #2,RUN LEAK DOWN TEST.LEAKING THROUGH INTA KE REMOVED CAB AND LT CYL HEAD.PIECE OF INTAKE VALVE MISSING AND EDGE OF PIS TON BROKEN.REMOVE ENGINE,REPLACE PISTON AND R BRG.REPL NO.2 INJ AND LT HEAD
10/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
PERFORMED RECALL 08C01.INSTALLED CLAMP ON SEAT BACK
10/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
000 08B06A
INSPECTED FOR VENTUEI TEE,WAS ALREADY INSTALLED
09/02/2008
DEALER: Varsity Ford Lincoln Mercury,
WARRANTY CLAIM NUMBER: 299834 ODOMETER: 102922M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 9F468B TUB-E/G/R COOL INLT 001 8005D D1 POROSITY
8C3Z 8287K CLAMP ASY-RAD HOSE 001 MT9F468
VC 7B 002
102922 PRESSURE TEST COOLING SYSTEM. REPLACE TUBE FROM FRONT ENGINE COVER TO EGR COOLER. ENGINE ASSEMBLY REPLACED CUSTOMER PAY ON AUGUST 11, 2008 AT 10 0,154 MILES.
09/02/2008
LABOR OP
CONDITION CODE
CONDITION DESC
TAP3 RENTAL - LINC LESS S 000 82 FREIGHT/POSTAGE/MAINTENANCE
CLAIM FOR TRANSPORTATION ASSISTANCE INVOICE 299834
06/03/2008
DEALER: Henson Ford, Inc.
WARRANTY CLAIM NUMBER: 175055 ODOMETER: 100153M
LABOR OP
CONDITION CODE
CONDITION DESC
RENTAL AWA FOR RENTAL VEHIC 000 42 DOES NOT OPERATE PROPERLY
NO ACTION WENT TO ANOTHER DEALERSHIP
05/13/2008
DEALER: Bienville Motors, Inc.
WARRANTY CLAIM NUMBER: 055378 ODOMETER: 099073M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 6K682B TURBO CHG-EXH DRIVE 001 MT071208 42 DOES NOT OPERATE PROPERLY
7C3Z 12B591B SNS ASY-ENG EXH TEMP 002 8005A
7C3Z 5H247A FLTR ASY ENG EXH PRT 001 6007B41T
7C3Z 5H267AA CTLST DSL OXDTN 001 5221A
7C3Z 9J454A TUBE & VALVE (EXHAUS 001 5212B
8C3Z 12B591C SNS ASY-ENG EXH TEMP 001 6005E
8C3Z 6K682A TURBO CHG-EXH DRIVE 001 6005E2
8C3Z 6N640A GASKET TURBO TO MANI 002 6005F
8C3Z 6N640B GASKET TURBO TO MANI 001 6005F12
8C3Z 9T514A KIT-HDW TRBCH MTNG 001 6854AT
VC 7B 004 OSL
W302474 002
W302506 002
W302511 001
W302512 001
W302515 001
W302624 001
7C3Z 5H221CA FLTR ASY ENG EXH PRT 001
W506424S436 006
W611645S439 002
W710252S439 001
W712878S439 004
XT 5QMC 004
XO 15W40QSD 015
05/13/2008
LABOR OP
CONDITION CODE
CONDITION DESC
RENTAL AWA FOR RENTAL VEHIC 000 82 FREIGHT/POSTAGE/MAINTENANCE
RENTAL ASSISTENCE THROUGH FORD
05/13/2008
LABOR OP
CONDITION CODE
CONDITION DESC
CONEXP AWA FOR CONSEQUENTIA 000 82 FREIGHT/POSTAGE/MAINTENANCE
VEHICLE IN SHOP THIS IS CHARGE FOR HOTEL BILL
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33R08EA24897
4play is offline
post #3 of 4 (permalink) Old 01-29-2009, 09:42 PM Thread Starter
thanks for info, i assume that this is a job 1 truck with a job 3 motor, i was shown a receipt for 13,000 for new motor. i have not had any problems with the truck. do i need any flashes at this time?
post #4 of 4 (permalink) Old 01-30-2009, 03:43 AM
4play's Avatar
there is a recall for a possible reflash. reflashes can and have fixed alot of problems with these, it seems the engineers come out with new calibrations weekly for certain fixes but that does not mean you need the latest. but dont be suprised if you take your truck to the dealer for a problem and it gets fixed with a reflash.
4play is offline
Oasis report please floridafishhunt Ford Oasis requests 1 12-01-2007 02:28 AM
Oasis Report Please DevilDocTater Ford Oasis requests 1 12-01-2007 02:24 AM
OASIS Report Please moyerd Ford Oasis requests 1 12-01-2007 02:23 AM
Oasis Report Please 06jimmy Ford Oasis requests 1 11-30-2007 05:21 PM
OASIS Report Please lilgsx Ford Oasis requests 1 11-02-2006 12:52 AM
