oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jteam, this thread has received 3 replies and been viewed 546 times.
post #1 of 4 (permalink) Old 01-30-2009, 02:03 AM Thread Starter
oasis please
need an Oasis report if anyone could help. Thanks in advance.
VIN - 1FTNW21P23EB81721
jteam is offline
post #2 of 4 (permalink) Old 01-30-2009, 03:45 AM
4play's Avatar
OASIS RESULT:
1FTNW21P23EB81721
01/29/2009
23:44:32
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/01/2003 BUILD DATE
01/22/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 0 7S02 180102 * 14401 * L69 33 15
AWS Claim Key: 654726 Trx Code: 1 Labor Hrs: 6
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2003 Doc #:22309401
Cust Comments: FUEL GAUGE DOES NOT REGISTER PROPER
Tech Comments: REMOVE DASH CLUSTER ASSY TEST COMPLETE CLUSTER HARNESS CALL TALK TO FORD HOTLINE TEST FOR CURRENT AT TANK UNIT TEST WIRE HARNESS FROM DASH CLUSTERNK SENDING UNIT REPAIR WIRE HARNESS RIGHT SIDE KICK PANEL TO SENDING UNIT AND FUEL PUMP CUT OFF SWITCH
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 2 2E06 030008 3C3Z 9E527 ABRM D50 28 6521
AWS Claim Key: 1152813 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2003 Doc #:22440301
Cust Comments: CUST STATES THERE IS ENGINE MISS
Tech Comments: TEST ENGINE PERFORMANCE INSTALL NO 5 INJECTOR RIGHT SIDE
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 2 7K12 011202 2C3Z 10D898 AA L69 42 6521
AWS Claim Key: 1152814 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2003 Doc #:22440304
Cust Comments: CUST STATES FUEL GAUGE IS NOT READING CORRECTLY LIGHT COMES ON
Tech Comments: TEST SYSTEM INSTALL MESSAGE CENTER INDICATOR ROOF CONSOLE RECALIBRATE
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 4 1F03 03XXXX B7AZ 8287 D N12 01 15231
AWS Claim Key: 1561316 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 01055 - * Name: BOB DUNN FORD, INC. Ph: *-* St:NC Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2003 Doc #:03487501
Cust Comments: CHECK WHISTLING NOISE FROM ENGINE AREA
Tech Comments: TUBRO PIPE BLOWER OFF AT INTERCOOLER REPLACE REPLACE WITH HOSE CLAMO
Dlr Cd-Sub Cd: 01055 - * Name: HUNNICUTT FORD, INC. Ph: 828-2451626 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2003 Doc #:03487501
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 7 2E06 030008 3C3Z 9E527 AE D03 42 30134
AWS Claim Key: 2459391 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 00368 - * Name: CITY MOTORS OF CARTERSVILLE, INC. Ph: 770-3825780 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-SEP-2003 Doc #:018630A
Cust Comments: WILL NOT START
Tech Comments: WONT START CHECK CODES AND REPLACE CYLINDER 8 CHANGE OIL AND FILTER AND REPLACE RING ON VENT TUBE TEST DRIVE AND CHECK FOR LEAKS AND NO LEAKS FOUND AT THIS TIME
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 8 7X01 011000 F65Z 15672A32 AAF T90 01 17847
AWS Claim Key: 2900486 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:22768901
Cust Comments: CUSTOMER STATES CENTER CONSOLE CLIP BROKEN PASS SIDE OF ARM REST
Tech Comments: INSTALL RIGHT SIDE CONSOLE ARM REST COVER
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 8 2G01 * * * * * * 17847
AWS Claim Key: 2900487 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:22768903
Cust Comments: 03L12 INSTALL RECALL LABEL
Tech Comments: INSTALL EMISSION LABEL
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 9 2G05 031405 * RECALEM * D50 42 40866
AWS Claim Key: 3443846 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:21-NOV-2003 Doc #:22845301
Cust Comments: CUST STATES VEHICLE RUNS ROUGH LOSS OF POWER
Tech Comments: TEST ENGINE PERFORMANCE RECALIBRATE PCM WITH LATEST CALIBRATION
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 19 * * * * * * * 86549
AWS Claim Key: 7665237 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2004 Doc #:23409301
Cust Comments: CUSTOMER STATES THAT THE RECALL 04S15 MAY APPLY
Tech Comments: INSPECT BATTERY CABLE END
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 38 * * * * * * * 168042
AWS Claim Key: 13397566 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2006 Doc #:24390901
Cust Comments: 06E17 CONTROL MODULE RECALIBRATON
Tech Comments: RECALIBRATE CONTROL MODULES
AWS Claim Key: 13397567 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03843 - * Name: BEDFORD FORD-MERCURY, INC. Ph: 540-5868281 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2006 Doc #:24390902
Cust Comments: 59B01 ASSURANCE TEST DRIVE
Tech Comments: ROAD TEST FOR ANY MORE CONCERNS
1FTNW21P23EB81721 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-JAN-2003 01-MAR-2003 127506 USA 55 2H01 030407 3C3Z 6K682 CBRM N12 D8 359001
AWS Claim Key: 15461731 Trx Code: SPW Labor Hrs: 3.3
Dlr Cd-Sub Cd: 06634 - * Name: UNIVERSITY FORD, INC. Ph: 919-6829171 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:16-AUG-2007 Doc #:113212A
Cust Comments: LOUD NOISE FROM TURBO BLACK SMOKE FROM TAIL PIPE
Tech Comments: EEC TEST NO CODES MOTOR OIL COMING FROM EXHAUST PIPE CHECKED Y PIPE FOR OIL CHECKED CAC TUVBES FOR OIL NO OIL ON INTAIKE SIDE, FOUND TURBO SHAFT BROKEN AND LEAKING OIL FROM EXHAUST SIDE, R AND R TURBOAND REPLACED AND CHECKED DRAIN BACK AND OIL TO TU RBO.ALL OK AT THIS TIME
4play is offline
post #3 of 4 (permalink) Old 01-30-2009, 05:11 PM Thread Starter
Thanks 4play
Thanks 4 play!, thinking of buying the truck. Hard to believe that it has not had any work done since 2003. It currently has 260k miles on it. Seller is asking $8500. Good deal? What does anyone think?
jteam is offline
post #4 of 4 (permalink) Old 01-30-2009, 06:40 PM
4play's Avatar
the format of these can be hard to read but the last warranty repair on the list was
Repr Date:16-AUG-2007 Doc #:113212A.
4play is offline
