oasis request - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jlund, this thread has received 1 replies and been viewed 594 times.
post #1 of 2 (permalink) Old 01-30-2009, 11:59 PM Thread Starter
oasis request
please run oasis report for vin# 1FTWW33P25EB21660. Thank You very much in advance.
jlund is offline
post #2 of 2 (permalink) Old 01-31-2009, 05:03 AM
4play's Avatar
OASIS RESULT:
1FTWW33P25EB21660
01/31/2009
01:02:54
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/25/2005 BUILD DATE
10/26/2004 SALE MILEAGE
00009
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW33P25EB21660 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2004 25-MAR-2005 152765 USA 6 7S02 180102 * 14401 * C05 28 23209
AWS Claim Key: 1799383 Trx Code: E83 Labor Hrs: 2
Dlr Cd-Sub Cd: 04414 - * Name: CENTER MOTOR COMPANY Ph: 936-5983361 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:03310902
Cust Comments: CHECK AC NOT COOLING
Tech Comments: M TIME TO RUN DIAG ON EATC TEST FUSES CUT OUT AND DUAL SWITCHES FUSES IN BATTERY JUNCTION BOX AND LOCATE AND REPAIR OPEN IN WIRING OUT OF BOX CIRCUIT 326
1FTWW33P25EB21660 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2004 25-MAR-2005 152765 USA 6 2H01 031202 6C3Z 6C640 AA D42 42 23209
AWS Claim Key: 1901483 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04414 - * Name: CENTER MOTOR COMPANY Ph: 936-5983361 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:03310901
Cust Comments: CHECK FUEL MILEAGE POOR AND LACKS POWER
Tech Comments: CAC TUBE NOT SEALING AND REPROGRAMMED PCM TO UPDATE CALIBRATION
1FTWW33P25EB21660 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2004 25-MAR-2005 152765 USA 10 7G02 120202 4C3Z 18476 BA L87 01 31252
AWS Claim Key: 3144362 Trx Code: E83 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04414 - * Name: CENTER MOTOR COMPANY Ph: 936-5983361 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2006 Doc #:03493301
Cust Comments: HOT WATER LEAKING IN GLOVE BOX SMELLS ANTI FREEZE
Tech Comments: HEATER COR LEAKING
1FTWW33P25EB21660 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2004 25-MAR-2005 152765 USA 10 6P07 010301 * 3820124 * B15 07 31252
AWS Claim Key: 3144363 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04414 - * Name: CENTER MOTOR COMPANY Ph: 936-5983361 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2006 Doc #:03493302
Cust Comments: CHECK BOTH FRONT DOORS HARD TO CLOSE HAVE TO SLAM TO SHUT
Tech Comments: BOTH DOORS OUT OF ADJUSTMENT
1FTWW33P25EB21660 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 26-OCT-2004 25-MAR-2005 152765 USA 28 * * * * * * * 85271
AWS Claim Key: 8301756 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02871 - * Name: EXCEL FORD LINCOLN MERCURY, LP Ph: 903-6933821 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2007 Doc #:05629207
AWS Claim Key: 8235480 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02871 - * Name: EXCEL FORD LINCOLN MERCURY, LP Ph: 903-6933821 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2007 Doc #:05629206
AWS Claim Key: 8235479 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02871 - * Name: EXCEL FORD LINCOLN MERCURY, LP Ph: 903-6933821 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2007 Doc #:05629205
4play is offline
jlund (01-31-2009)
Oasis request johns Ford Oasis requests 1 08-17-2007 12:48 AM
OASIS Request cwalker Ford Oasis requests 1 08-03-2007 01:38 PM
OASIS Request please Mustang50 Ford Oasis requests 1 08-03-2007 01:27 PM
OASIS request please? Mustang50 Ford Oasis requests 1 08-03-2007 01:22 PM
Oasis request please............ Motown Fire Ford Oasis requests 3 05-24-2006 03:19 AM
