oasis please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 1 replies and been viewed 1056 times.
post #1 of 2 (permalink) Old 01-31-2009, 12:54 AM Thread Starter
vcassens's Avatar
oasis please
the vin# is 1FTSW31P24EA59855 thanks very much
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 2 (permalink) Old 01-31-2009, 05:06 AM
4play's Avatar
OASIS RESULT:
1FTSW31P24EA59855
01/31/2009
01:04:40
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/20/2003 BUILD DATE
08/27/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/29/2008
DEALER: Jerseyville Motor Company, Inc
WARRANTY CLAIM NUMBER: 077259 ODOMETER: 068192M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640C CONNECTION A/C DUCT 001 6007D D8 FAILED GASKET/SEAL
6C3Z 6C640B CONNECTION A/C DUCT 001 6584AL
3C3Z 12A690AA WIRING ASY EC SENSOR 001 9278A
F81Z 9278AA SENDER-OIL PRES 001 MT12A690
3C3Z 6582BA COVER ASY-VALVE ROCK 001
W302725 001
W300020 001
W301373 002
PERFORMED OIL LEAK DIAGNOSIS REPLACED LEFT VALVE COVER SEALING SURFACE CORRO DED LEFT GLOW PLUG HARNESS AND OIL PRESSURE SENDING UNIT RETESTED OK
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P24EA59855
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 4 2G04 031401 * 12A650 * D11 42 5029
AWS Claim Key: 246336 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2003 Doc #:04126502
Cust Comments: FAST IDLE POOR FUEL MILEAGE
Tech Comments: REPROGRAM PCM PER TSB 032012
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 8 4A02 080103 3C3Z 7563 AA P24 63 13161
AWS Claim Key: 748460 Trx Code: E84 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2004 Doc #:04382001
Cust Comments: TRANSMISSION SLIPS IN 5TH AND 6TH GEARS
Tech Comments: CHK CLUTCH OPERATION SLIPS UNDER LOAD CALLED HOTLINE WAS ADVISED TO RE
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 8 6F45 011105 * 2542006 * R04 07 13161
AWS Claim Key: 748462 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2004 Doc #:04382003
Cust Comments: WATER LEAK AT REAR SLIDING GLASS
Tech Comments: MARTIN GLASS INVOICE 0512361 OSP 20 DOLLARS RESEAL BACKGLASS
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 8 2G04 031401 * 12A650 * D35 42 13161
AWS Claim Key: 748461 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2004 Doc #:04382002
Cust Comments: POOR FUEL MILEAGE
Tech Comments: COMPLAINS OF POOR FUEL ECONOMY RUN EEC TEST MODES NO CODES DIAGNOSED P
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 17 6L03 011201 2C3Z 25044D70 DAA B53 33 20965
AWS Claim Key: 3221888 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2005 Doc #:04992101
Cust Comments: RATTLE IN DASH PANEL
Tech Comments: REPLACED DASH PANEL DUE TO CLIPS BROKEN
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 17 7M01 150101 * 18806 * A16 42 20990
AWS Claim Key: 3363321 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2005 Doc #:04996101
Cust Comments: CUSTOMER STATES CD WILL NOT EJECT
Tech Comments: 3C3T 18C815 AC REMOVE AND REPLACED CD WITH EXCHANGE UNIT
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 17 7M01 150101 3C3T 18C815 AC A07 42 20990
AWS Claim Key: 4078925 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:21-JAN-2005 Doc #:09580900
Tech Comments: REQUESTING DEALER'S P/A CODE 08109
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 18 1H03 030008 3C3Z 9J460 AA D36 42 22746
AWS Claim Key: 4229075 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2005 Doc #:05129601
Cust Comments: CUSTOMER STATES LACK OF POWER ON ACCELERATION
Tech Comments: CUSTOMER STATES LACK OF POWER TEST DROVE 30 MILES COULDNOT DUPLICATE CONCERN RUN EEC TEST MODES NO CODES DIAGNOSE PER SERVICE MANUAL AND REPLACED EBP SENSOR READY 12 2 PSI WITH ENGINE OFF
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 20 5V01 0603XX * 1102 * N27 14 26098
AWS Claim Key: 4931429 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-APR-2005 Doc #:05218504
Cust Comments: CUSTOMER STATES VIBRATION WHEN BRAKING
Tech Comments: VIBRATION WHEN BRAKING MACHINED FRONT ROTORS WARPED
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 20 2H01 030008 3C3Z 6K682 AARM D42 41 26511
AWS Claim Key: 5245471 Trx Code: S07 Labor Hrs: 5.5
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2005 Doc #:05232501
Cust Comments: CUSTOMER STATES LACK OF POWER WHEN TOWING TRAILER
Tech Comments: LACK OF POWER ON HARD ACCEL TEST DROVE NPF TEST DROVE WITH CUSTOMER AGAIN WITH TRALER HOOKED TO TRUCK VERIFIED CONCERN AND MADE READING RUN EEC TEST MODES NO CODES DIAG PER SERV MANUAL AND CALL TECH HOTLINE WAS ADVISED BY HOTLINE TO PERFORM BOOST TEST MAGNET TESTS ON TURBO AND REPRO PCM TCM AND FICM
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 28 7W06 000301 3L2Z 14A626 AA L20 28 34436
AWS Claim Key: 8092178 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:05779504
Cust Comments: CUSTOMER STATES KEYLESS ENTRY PAD INOPERABLE
Tech Comments: DIAGNOSE KEYPAD INOPERABLE REPLACE KEYPAD NO LABOR OP TIME FOR KEYPAD REPLACEMENT
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 28 5G02 040103 4C3Z 3049 DA H21 33 34436
AWS Claim Key: 8092177 Trx Code: E84 Labor Hrs: 3
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:05779501
Cust Comments: CUSTOMER STATES FRONT TIRE WEAR
Tech Comments: REPLACED ALL FOUR BALLJOINTS DUE TO BEING LOOSE CHECK ALIGNMENT NO ADJUSTMENT NEEDED
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 31 * * * * * * * 43085
AWS Claim Key: 8953851 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:05997102
Cust Comments: RECALL 59B01 CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: PERFORMED CUSTOMER ASSURANCE TEST DRIVE PER RECALL 59B01
AWS Claim Key: 8938227 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:05997101
Cust Comments: RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: REPROGRAMED PCM TCM AND FICM PER RECALL 06E17
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 40 2E03 030008 * 9E527 * D36 42 49809
AWS Claim Key: 10856688 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2006 Doc #:06534001
Cust Comments: CUSTOMER STATES MISSES WHEN COLD
Tech Comments: ENGINE MISS WHEN COLD DIAGNOSE PER SERVICE MANUAL AND RUN EEC TEST MODES NO CODES DIAGNOSE AND REPROGRAM PCM FICM AND TCM PER TSB 062203 AND PERFORM TEST DRIVE AND PID MONITER RETEST OK
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 51 2E03 030402 3C3Z 9E527 EBRM D36 42 64419
AWS Claim Key: 12326401 Trx Code: E72 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-2007 Doc #:07239001
Cust Comments: CUSTOMER STATES BLOWS WHITE SMOKE ENGINE MISS AND LACK OF POWER ON COLD STARTS
Tech Comments: ENGINE MISS AND LACK OF POWER WHEN COLD DIAG PER SERVICE MANUAL AND RUN EEC TEST NO CODES REPROGRAM PCM TCM AND FICM PER TSB 070504STILL MISSES ENGINE RUNS ROUGH WHEN COLD DIAGNOSE AND FOUND CYLINDERS 2 4 5 8MISSING DIAG AND REPLACED CYLINDER 2 4 5 8 INJECTOR REASSEMBLED ENGINE RETESTED OK
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 51 6Y20 000000 * TAP1 * A98 82 64419
AWS Claim Key: 12326402 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-2007 Doc #:07239002
Tech Comments: 5 DAYS OF TAP VEHICLE PROVIDED FOR VEHICLE REPAIR 5 DAYS AT $15.00 EQUALS $75.00
1FTSW31P24EA59855 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 27-AUG-2003 20-SEP-2003 153182 USA 60 1D05 031004 3C3Z 6582 BA L65 D8 68192
AWS Claim Key: 12832023 Trx Code: E72 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 08109 - * Name: JERSEYVILLE MOTOR COMPANY, INC. Ph: 618-4982139 St:IL Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2008 Doc #:07725901
Cust Comments: VEHICLE HAS AN OIL LEAK
Tech Comments: PERFORMED OIL LEAK DIAGNOSIS REPLACED LEFT VALVE COVER SEALING SURFACE CORRODED LEFT GLOW PLUG HARNESS AND OIL PRESSURE SENDING UNIT RETESTED OK
4play is offline
vcassens (01-31-2009)
