Oasis still? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JIMS 03 73, this thread has received 1 replies and been viewed 449 times.
post #1 of 2 (permalink) Old 02-11-2009, 12:12 AM Thread Starter
JIMS 03 73's Avatar
Oasis still?
Oasis still?
2003 f-350 7.3l
1ftsx31f73ea98248
thanks DID ONCE IN ANOTHER COLUME, OOOPPS
__________________
2003 F-350
SRW SC SINGLE #197
STILL A STOCKER
Charcoal Gray 2003 F-350 7.3L
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
DIY INTAKE AND NO CAT
EDGE EVO. W/ POD
JIMS 03 73 is offline
post #2 of 2 (permalink) Old 02-11-2009, 04:49 AM
4play's Avatar
OASIS RESULT:
1FTSX31F73EA98248
02/11/2009
00:48:23
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
D1 ENGINE CALIBRATION
2F719N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/04/2002 BUILD DATE
10/13/2002 SALE MILEAGE
00020
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
0714 - EXPIRED
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: RYAN RABER
OPTIONS:
EXPIRATION DATE: 11/04/2005
DISTANCE: 46,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 09143
ESP CONTRACT START DATE: 11/04/2002
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
| On-line 1878
END OF OASIS REPORT FOR 1FTSX31F73EA98248
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 4 6Y05 000001 * MAINT * A96 82 5907
AWS Claim Key: 505199 Trx Code: 0714S Labor Hrs: 1.4
Dlr Cd-Sub Cd: 01390 - * Name: BRUNSWICK FORD Ph: 207-7251228 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2003 Doc #:07845202
Cust Comments: MAINTENANCE BASED ON TODAYS MILEAGE. .
Tech Comments: COMPLETED MAINTENANCE, CHANGED OIL AND FILTER, TOPPED OFF FLUIDS AND ADJUSTED TIRE PRESSURES.
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 9 7T03 060901 F85Z 2L373 AB H19 42 14012
AWS Claim Key: 1826390 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2003 Doc #:30027901
Cust Comments: CUSTOMER STATES THE ABS LIGHT IS ON VERIFIED ABS LIGHT IS ON , PERF SELF TEST HAS DTC C1230
Tech Comments: PERF PIN POINT TEST F IN SERVICE MANUAL. TRACED TO REAR WHEEL SPEED SENSOR, REPLACED CLEARED CODES ROAD TESTED OK.
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 9 6Y05 000001 * MAINT * A96 82 14012
AWS Claim Key: 1841236 Trx Code: 0714S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2003 Doc #:30027801
Cust Comments: PERFORM SCHDULE M AND B SERVICE
Tech Comments: 1 PERFORMED M AND B SERVICE PER SCHDDULE
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 9 7Q88 000615 * NPF * A25 82 14012
AWS Claim Key: 1826389 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:17-JUL-2003 Doc #:30027902
Cust Comments: CUSTOMER STATES THE SPEEDO QUITS AND CRUISE SHUTS DOWN ROAD TESTED FOR CONCERN FOR SPEEDO AND CRUISE ISSUE,
Tech Comments: WAS UNABLE TO CREATE CONDITION. RAN OASIS NO CONCERN FOUND FOR THIS COMPLAINT. INSTALLED WDS PERF ECC TEST ON INS CLUSTER AND PCM SYSTEM PASS ON BOTH MODULES. TOOK VEHICLE ON EXTENSIVE ROAD TEST EVERYTHING OPERATING NORMAL.
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 15 7B02 140201 2C3Z 10346 BARM D02 42 23577
AWS Claim Key: 4618224 Trx Code: E83 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2003 Doc #:481219A
Cust Comments: TOWED IN JUST CLICKS
Tech Comments: 5000 PUSHED VEHICLE IN WOULD NOT TAKE BOOST TESTED BATTERIES,BOTH FAILED REPLACED BOTH BATTERIES TESTED CHARGING SYSTEM FAILED,REPLACED ALTERNATORTED OK NOW OK,TESTED FOR DRAWS NONE FOUND.COULD NOT FIND CAUSE AT THIS TIME ***LTS
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 15 5R01 110401 * 3524 * N57 41 23577
AWS Claim Key: 4451587 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2003 Doc #:481219C
Cust Comments: CUST SAYS ST COLUMN SQUEAKS
Tech Comments: 23577 VERIFIED CONCERN,FOUND STEERING SHAFT RUBBING ON RUBBER IN FIREWALL.LUBED PARTS NOISE IS GONE ***LTS
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 15 6Y05 000001 * MAINT * A96 82 25236
AWS Claim Key: 4239242 Trx Code: 0714S Labor Hrs: 1.2
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2004 Doc #:32157801
Cust Comments: LUBE OIL FILTER, TOP OFF ALL FLUIDS, CHECK TIRE PRESSURES, LUBE ALL DOOR LATCHES AND HINGES.
Tech Comments: 1 PERFORMED 25,000 MAINT SERVICE
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 15 7G88 000615 * NPF * C07 82 25236
AWS Claim Key: 4278851 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09143 - * Name: ROWE FORD SALES Ph: 207-8542555 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2004 Doc #:32157701
Cust Comments: CUSTOMER STATES DOSEN T THINK THE BLOCK HEATER IS WORKING CHECKED ELECTRICAL MEASURED RESISTANCE OK PLUGGED
Tech Comments: IT IN TO EXTENSION LET SIT FOR SEVERAL MINUTES THEN MEASURED THE TEMP WAS AT 148 DEGREES HEATER IS WORKING AS DESIGNED
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 18 6L03 011201 2C3Z 25044D70 EAB B95 01 30112
AWS Claim Key: 6133514 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:489742C
Cust Comments: DASH CRACKED RIGHT ABOVE STEERING WHEEL
Tech Comments: 30112 VERIFIED CONCERN NEED TO ORDER NEW INSTRUMENT CLUSTER TRIM REORDERED PART REPLACED TRIM AROUND INSTRUMENT CLUSTER ***LTS
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 18 7M01 150101 * 18C815 * A16 42 30112
AWS Claim Key: 6133515 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:489742D
Cust Comments: CD PLAYER WONT EJECT CDS
Tech Comments: 30112 VERIFIED CONCERN REMOVED RADIO AND GOT PART NUMBER, NEEDS NEW CD RADIO PLAYER REPLACED RADIO ***LTS
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 18 7D07 17XXXX * 13465 * L26 46 30112
AWS Claim Key: 6133516 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:489742F
Cust Comments: 3RD BRAKE LIGHT INOP
Tech Comments: 33368 30112 REPLACED BULD ***LTS
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 18 6Y05 000001 * MAINT * A99 82 30112
AWS Claim Key: 6133513 Trx Code: 0714S Labor Hrs: 2
Dlr Cd-Sub Cd: 08807 - * Name: ROWE AUBURN Ph: 207-7842321 St:ME Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:489742B
Cust Comments: FACTORY SPECIFIED OIL FILTER AND UP TO 5 QUARTS OF MOBIL OIL, FLUID CHECK, TIRE CHECK AND MULTI POINT INSPECTION.
Tech Comments: 30112 SLA DONE PERFORMED 30000 MILE MAINT REPPL AIR FILTER XXXXXXXXX QCM XXXXXXXXXXX
1FTSX31F73EA98248 T/F7 F T/BD T/CD T/E A1 T/D8 T/DS 13-OCT-2002 04-NOV-2002 111212 USA 19 7M01 150101 * 18C815 * A07 42 30112
AWS Claim Key: 6693483 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67701 - * Name: VISTEON AFTERMARKET-U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-2004 Doc #:01523709
Tech Comments: REQUESTING DEALER'S P/A CODE 08807
4play is offline
