need oasis for '04 F-250 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 5 replies and been viewed 597 times.
post #1 of 6 (permalink) Old 02-11-2009, 03:27 PM Thread Starter
SSpeeDEMONSS's Avatar
vin # TMW2IP4EA81715
not sure about the i's and 1's.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 6 (permalink) Old 02-11-2009, 03:34 PM
4play's Avatar
check this vin, vin number should have 17 characters. sometimes it easier to read the vin off the white sticker on the drivers door jam you only have 14 characters
4play is offline
post #3 of 6 (permalink) Old 02-11-2009, 05:13 PM Thread Starter
its my dads truck and he checked it. i knew i should have done it.
post #4 of 6 (permalink) Old 02-11-2009, 05:13 PM
KEE KEE WHOO!
sotexy's Avatar
Send a message via AIM to sotexy
haha
TDG LUSH ELITE #1
TDG Singles Member #148
TDG Outlaw #29
TDG AMERICAN #3
TDG B.O.M.B Squad #3
TDG Ridin Dirty #13
"Lose the zero, get with a Hero!"
"PUT SOME SOUTH IN YOUR MOUTH!!"
sotexy is offline
post #5 of 6 (permalink) Old 02-11-2009, 05:15 PM Thread Starter
ok, here it is.
1FTNW21P94EA81715
post #6 of 6 (permalink) Old 02-11-2009, 05:54 PM
4play's Avatar
OASIS RESULT:
1FTNW21P94EA81715
02/11/2009
13:53:00
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/10/2003 BUILD DATE
09/16/2003 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
AWS Claim Key: 633426 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD, INC. Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:09782401
Cust Comments: G32 WATER IN FUEL LIGHT.
Tech Comments: MODULE MT9B249 REPLCED FUEL IN WATER MODULE.
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 6 2G05 031405 * RECAL * D50 79 5303
AWS Claim Key: 633424 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD, INC. Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:09782403
Cust Comments: A99 03T02 CALIBRATION UPDATE.
Tech Comments: RECALL 03T02B REPROGRAMMED PCM.
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 6 7S06 180101 * 12B637 * D02 X2 5303
AWS Claim Key: 633425 Trx Code: S07 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD, INC. Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2004 Doc #:09782402
Cust Comments: D02 ENGINE STALLS OUT HWY DRIIVNG
Tech Comments: WIRING HARNESS TO FICM 12B599 PASS DIAGNOSIS 1 13 REPAIRED LOOSE CONNECTOR TO HARNESS #12B637 C1388C CIRCUIT 574 BK PK. R&I FICM FOR ACCESS MT12B599
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 11 1H03 030008 3C3Z 9J460 AA D36 28 8821
AWS Claim Key: 1777411 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD, INC. Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2004 Doc #:11052301
Cust Comments: D36 ENGINE IS SLUGGISH ON ACCELERATION WHEN COLD
Tech Comments: FAULTY EBP SENSOR EEC TEST PASSPINPOINT TEST, REPLACE EBP SENSOR RPROGRAM PCM, AND TCM, ROAD TEST
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 13 2H02 030008 3C3Z 6F089 AA D42 28 10029
AWS Claim Key: 2423223 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD, INC. Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2004 Doc #:11483501
Cust Comments: VEH HAS NO POWER OFF TAKE OFF WORSE WHEN COLD SEE MIKE
Tech Comments: FAULTY VGT SENSOR EEC TEST PASS, PINPOINT TEST, MONITER BOOST PSI. REPLACE MT6F089 VGT ACTUATOR , ROAD TES
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 23 7G09 120203 F81Z 19893 AAL C19 01 15978
AWS Claim Key: 6519422 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 02574 - * Name: BOB UTTER FORD LINCOLN-MERCURY Ph: 903-8923555 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:202326A
Cust Comments: CK TWO A C VENTS ARE COMING APART
Tech Comments: REPLACE LEFT AND ONE CENTER AC REGISTERS
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 30 2A01 031201 * 9600 * D42 33 24679
AWS Claim Key: 9251757 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04122 - * Name: COMMERCE AUTO GROUP Ph: 903-8864014 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2006 Doc #:058071A
Cust Comments: VEH HAS NO POWER,LOUD NOISE LOSS POWER
Tech Comments: FOUND THE CAC TUBE HAS BLOWN OFF,REMOVE AIR FILTER AND REPLACED THE CLAMP ON THE TUBE
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 30 * * * * * * * 24679
AWS Claim Key: 9251759 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04122 - * Name: COMMERCE AUTO GROUP Ph: 903-8864014 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2006 Doc #:058071C
Cust Comments: RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: PERFORMED RECALL 06E17
AWS Claim Key: 9251758 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04122 - * Name: COMMERCE AUTO GROUP Ph: 903-8864014 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2006 Doc #:058071B
Cust Comments: RECALL 59B01 ONE TIME CUST ASSURANCE TEST DRIVE
Tech Comments: PERFORMED RECALL 59B01
1FTNW21P94EA81715 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-SEP-2003 10-OCT-2003 152302 USA 35 6C03 010503 4C3Z 2651944 BAB B73 33 29640
AWS Claim Key: 10209982 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 02574 - * Name: BOB UTTER FORD LINCOLN-MERCURY Ph: 903-8923555 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:219606A
Cust Comments: CHECK HEADLINER MATERIAL COMING LOOSE FOR BACKING
Tech Comments: REPLACE HEADLINER ASSEMBLY
4play is offline
SSpeeDEMONSS (02-11-2009)
