need oasis for '04 F-350 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PADLER, this thread has received 2 replies and been viewed 516 times.
post #1 of 3 (permalink) Old 02-11-2009, 04:22 PM Thread Starter
1ftsw31p74ed09980
PADLER is offline
post #2 of 3 (permalink) Old 02-11-2009, 05:40 PM
4play's Avatar
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
41 ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/18/2004 BUILD DATE
04/06/2004 SALE MILEAGE
00050
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
AWS Claim Key: 2539609 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: A6050 - * Name: WOODRIDGE FORD LINCOLN LTD Ph: 403-2532211 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:11-NOV-2004 Doc #:19393101
Cust Comments: RIGHT LOWER BALL JOINTS NOTED ON JOB 1
Tech Comments: R&R LOWER BALL JOINTS CHECK AND SET TOE
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 6 2G05 031405 * RECALEM * D36 42 19387
AWS Claim Key: 2570889 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: A6050 - * Name: WOODRIDGE FORD LINCOLN LTD Ph: 403-2532211 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:12-NOV-2004 Doc #:19396201
Cust Comments: CHECK AND ADVISE ON SURGING WHILE DRIVING
Tech Comments: DIAG SURGE, KOEO, KOEO INJECTOR SELF TEST. KOER, BOOST REPROGRAM PCM & TCM AS PER TSB 03 20 12 RETEST OK
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 11 3A03 * * * * * * 30277
AWS Claim Key: 4803942 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: B6050 - * Name: ADVANTAGE FORD SALES LTD Ph: 403-2253636 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:06-APR-2005 Doc #:17622001
Cust Comments: RECALL 04B24 REVERS PLANET
Tech Comments: PREFORMED RECALL 04B24.CHECK AND RECHECK.
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 14 1H03 030008 * 9F452 * D13 55 36260
AWS Claim Key: 5848337 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: B6233 - * Name: DRAYTON VALLEY FORD SALES LTD Ph: 780-5424438 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:20-JUN-2005 Doc #:020870A
Cust Comments: SPUTTERS KICKS PUFFS OF BLUE SMOKE.STRUGGLES TO GET OVER 1000RPM
Tech Comments: PERFORM DIESEL DIAGS PER SHEET. EGR FAILS. REPLACEEGR VALVE RETEST EBP SENSOR FAILS ON ROADTEST R EPLACE EBP RE TEST OK
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 14 6L05 011201 5C3Z 2513560 CAA T50 01 36260
AWS Claim Key: 5848338 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6233 - * Name: DRAYTON VALLEY FORD SALES LTD Ph: 780-5424438 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:20-JUN-2005 Doc #:020870B
Cust Comments: REPAIR CUP HOLDER IN DASH
Tech Comments: REPLACE CUP HOLDER SPRING BROKEN
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 16 * * * * * * * 43477
AWS Claim Key: 6621871 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6050 - * Name: ADVANTAGE FORD SALES LTD Ph: 403-2253636 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:22-AUG-2005 Doc #:18282003
Cust Comments: PLEASE PERFORM RECALL 59B01 FOR TEST DRIVE.
Tech Comments: CUSTOMER ASSURANCE TEST DRIVE
AWS Claim Key: 6621870 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: B6050 - * Name: ADVANTAGE FORD SALES LTD Ph: 403-2253636 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:22-AUG-2005 Doc #:18282002
Cust Comments: PLEASE PERFORM RECALL 05E15
Tech Comments: REPLACED EP SENSOR, EP CONNECTOR, AND RECALIBRATED CONTROL MODULES
AWS Claim Key: 6621869 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: B6050 - * Name: ADVANTAGE FORD SALES LTD Ph: 403-2253636 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:22-AUG-2005 Doc #:18282001
Cust Comments: PLEASE PERFORM RECALL 05S34
Tech Comments: INSPECTET FICM HARNESS FOR PART NUMBER, CHAFING, INSTALLED FICM REPAIRKIT AND INSTALLED ICP CONNECTOR KIT
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 24 1A01 030008 3C3Z 6049 AA D50 42 67070
AWS Claim Key: 9460681 Trx Code: E72 Labor Hrs: 20.8
Dlr Cd-Sub Cd: A6050 - * Name: WOODRIDGE FORD LINCOLN LTD Ph: 403-2532211 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:01-MAY-2006 Doc #:59509501
Cust Comments: ADVISE RE LOTS OF WHITE SMOKE OUT THE TAILPIPE, SMELLS OF OIL, USIN NIPPLE BROKE OFF WHEN ATTEMPTING TO REMOVE HOSE
Tech Comments: MT 6.5HRS FOR ABNORMAL DIAG*** CHARTS,COMPLETE PERFORMANCE DIAG STEPS1 4 OK.CHECKED OASIS FOUND TSB#05 17 13,COMPLETESTEPS 1 4. FOUND COOLANT LE AKING INTO INTAKE, GAIN ACCESS TO EGR COOLER & REPLACE, REASSEMBLE ENGINE, ROADTEST,WHEN ENG GOT TO OPERATING TEMP, NOTICED CLOUDS OF WHITE SMOKE COMING FROM EXH, PRESS TEST COOLING SYSTM, NO PRESS LOSS, COMPLETE STEP 5 OF TSB,PRESS ON GAUGE INCREA
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 34 1A02 030102 4C3Z 6051 EA L87 D8 96458
AWS Claim Key: 11276664 Trx Code: E72 Labor Hrs: 24.8
Dlr Cd-Sub Cd: B6270 - * Name: FREEDOM FORD SALES LIMITED Ph: 780-4627575 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:07-FEB-2007 Doc #:349868A
Cust Comments: CUSTOMER REPORTS ENGINE COOLANT LOSS,WHITE SMOKE,LOSS OF POWER
Tech Comments: DIAG,INSP PER TSB FOUND EGR FULL OF COOLANT,CYL HAS COOLANT IN IT, INSTALL PRESS GAUGE,LIFT BACK OF UNIT SO COOLANT FLOW TO FRONT OF INTAKE,CLEAN OUT,FOUND TRACES OF COOLANT,REPLACED EGR COOLER,RECHK STILL BUILDS OVER 20PSI ON ROAD TEST,REPL HEAD GASKETS FOUND HEADBOLTS CAME OUT,INSTALLED NEW GASKETS AND HEADBOLTS,REASSEMBLED, MT TIME REQUIRED AS PER TSB 06 21 02, MT062102 TO PERFORM REPAIR
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 34 2H02 030008 * 6F089 * D42 55 96458
AWS Claim Key: 11160445 Trx Code: E72 Labor Hrs: 5.6
Dlr Cd-Sub Cd: B6270 - * Name: FREEDOM FORD SALES LIMITED Ph: 780-4627575 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:07-FEB-2007 Doc #:349868D
Cust Comments: INSPECT FOR LACK OF POWER
Tech Comments: PREFORM TSB 06 23 02 WHEN FOUND TURBO HOLD DOWN BOLT CROSS THREADED ON BACK BOLT SO HAD TO TRY TO GET BOLT FREE AND REMOVE TURBO FOUND THE PEDISTOLE NO GOOD HOLE AND TREADS GONE SO THEN REPLACED TURBO HOLD DOWN BRACKET AND DISASSEMBL TURBO FOUND RUST AND OIL SEAL GONE SO PUT OLD TURBO BACK TOGETHER AND INSTALL NEW ONE. RETST,OK
1FTSW31P74ED09980 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 06-APR-2004 18-MAY-2004 4A6050 CAN 34 2E03 030402 4C3Z 9E527 AA D13 42 0
AWS Claim Key: 11252962 Trx Code: S07 Labor Hrs: 8.5
Dlr Cd-Sub Cd: B6270 - * Name: FREEDOM FORD SALES LIMITED Ph: 780-4627575 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:07-FEB-2007 Doc #:349868E
Cust Comments: INSPECT FOR ROUGH RUNNING
Tech Comments: INSP,PERFORM TSB 06 22 03,THEN LET SIT OVER NOGHT FOR COLD START FOUND 3 INJHECTORS NO GOOD #7,#3,#2 NO GOOD SO REMOVED VALVE COVERS BOTH SIDES AND REMOVE INJECTORS THEN INSTALL NEW ONE S AND RETEST ALL PASS ACTUAL KMS ON THIS VEHICLE IS 155235 DDDME
4play is offline
post #3 of 3 (permalink) Old 02-11-2009, 05:55 PM Thread Starter
THANKS
YOU DA MAN
PADLER is offline
