oasis request please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by barry1me, this thread has received 1 replies and been viewed 502 times.
post #1 of 2 (permalink) Old 02-11-2009, 11:51 PM Thread Starter
1ftsw31p74ee03096
06 F250 6.0L ID tuning. RCD EGR delete 03 turbo
barry1me is offline
post #2 of 2 (permalink) Old 02-12-2009, 04:56 AM
4play's Avatar
OASIS RESULT:
1FTSW31P74EE03096
02/12/2009
00:53:39
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/27/2004 BUILD DATE
06/13/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
AWS Claim Key: 5260320 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04917 - * Name: GATOR FORD TRUCK SALES, INC. Ph: 813-9803673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2005 Doc #:048943C
Cust Comments: CUST STATES THAT THE ENGINE HAS AN OIL LEAK L65
Tech Comments: 31255 6C646 CC 42 PREFORM OIL LEAK DIAG FOR DIESEL ENG FOUND LEAK AT CAC TUBE REPLACE TUBE ASSY AND RETEST
1FTSW31P74EE03096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 13-JUN-2004 27-AUG-2004 124902 USA 9 3A03 * * * * * * 31245
AWS Claim Key: 5260319 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 04917 - * Name: GATOR FORD TRUCK SALES, INC. Ph: 813-9803673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2005 Doc #:048943A
Cust Comments: PERFORM TORQSHIFT REVERSE PLANET RECALL ON TRANS
Tech Comments: 31255 04B24N 6.4 R.R. TRANS AND REPLACE REAR PLANET SET AND FILTERS PER RECALL ROAD TEST AND RETEST
1FTSW31P74EE03096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 13-JUN-2004 27-AUG-2004 124902 USA 18 * * * * * * * 64832
AWS Claim Key: 8348717 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04945 - * Name: BILL CURRIE FORD LINCOLN MERCURY Ph: 813-8725555 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:74799608
Cust Comments: PERFORM ONP 59B01 ONE TIME CUST ASSURANCE TEST DRIVE
Tech Comments: 59B01 ROAD TEST PER FORD GUIDELINES
AWS Claim Key: 8348718 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04945 - * Name: BILL CURRIE FORD LINCOLN MERCURY Ph: 813-8725555 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:74799607
Cust Comments: PERFORM RECALL 05E15 EXHAUST PRESSURE SENSOR REPL
Tech Comments: 05E15 PERFORM RECALL
1FTSW31P74EE03096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 13-JUN-2004 27-AUG-2004 124902 USA 18 1H03 030008 4C3Z 9F452 A D42 41 65480
AWS Claim Key: 8425983 Trx Code: E72 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 04945 - * Name: BILL CURRIE FORD LINCOLN MERCURY Ph: 813-8725555 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:30-JAN-2006 Doc #:74898206
Cust Comments: CUST STATES WHILE TOWING A SMALL TRAILER AT HWY SPEEDS & COME TO AN INCLINE ENGINE WILL BOG DOWN & BLOW WHITE SMOKE FROM EXHAUST. ADVISE. CCCD42 (SEE RO 747996)
Tech Comments: DED $100 EEC TESTS DIESEL DIAG P0404 REPLACE STUCK EGR VALVE RETEST PASS
1FTSW31P74EE03096 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 13-JUN-2004 27-AUG-2004 124902 USA 24 1B03 030204 3C3Z 6A642 AA D50 42 86599
AWS Claim Key: 9988021 Trx Code: E72 Labor Hrs: 14.7
Dlr Cd-Sub Cd: 05774 - * Name: GRAHAM FORD-LINCOLN-MERCURY, INC. Ph: 615-4462308 St:TN Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:12742301
Cust Comments: CS THEIR TRUCK IS BLOWING HEAVY WHITE SMOKE OUT OF THE EXHAUST HAVE FILLED WITH 10 GALLONS OF ANTIFREEZE SO FAR SAYS COOLANT IS LEAKING FROM UNDER TRUCK SAYS TRUCK IS NOT RUNNING HOT BUT H
Tech Comments: VERIFY CONCERN PERFORM HARD START DIAG 6005E THROUGH E8 ALL PASS WHITE SMOKE APPEARED TO BE COOLANT CALLED HOT LINE TECH ADVISED REMOVONG EGR VALVE AND CHECKING FOR COOLANT COOLANT WAS PRESENT THEN WAS ADVISED TO REPLACE BOTH EGR COOLER AND OIL COOLER REMOVE COOLANT TANK FAN SHROUD TURBO CAC HOT AND COLD TUBES BELT TENSIONER INTAKE MANIFOLD REPLACE
4play is offline
barry1me (02-13-2009)
Oasis request please Bcarriveau Ford Oasis requests 2 09-04-2007 12:16 AM
oasis request webrats Ford Oasis requests 2 08-31-2007 02:17 AM
Oasis request ZeroOne Ford Oasis requests 1 08-19-2007 01:02 AM
Oasis request please Bcarriveau Ford Oasis requests 0 08-18-2007 11:04 PM
OASIS request - please snagnever Ford Oasis requests 1 09-20-2006 02:49 AM
