F250 Oasis request please! F250 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4x4freak, this thread has received 1 replies and been viewed 1032 times.
post #1 of 2 (permalink) Old 02-12-2009, 05:10 PM Thread Starter
Just a college kid
4x4freak's Avatar
1ftsw21p25eb75990
Stolen and rebuilt- 2005 6.0 CC SB 4x4-SCT-ARP-Fass 95/150-O/D Alternator pully-GoGo intake manifold
Special thanks to Doug at GoGoDiesel
4x4freak is offline
post #2 of 2 (permalink) Old 02-12-2009, 09:12 PM
4play's Avatar
OASIS RESULT:
1FTSW21P25EB75990
02/12/2009
17:12:13
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/05/2005 BUILD DATE
12/13/2004 SALE MILEAGE
01389
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
08/09/2008
DEALER: Freeway Ford
WARRANTY CLAIM NUMBER: 091929 ODOMETER: 044841M
LABOR OP
CONDITION CODE
CONDITION DESC
W300012 002 6007D D1 POROSITY
OSP 001 9438A
6K682 TURBO CHG-EXH DRIVE 000 9438AZW
OIL LEAK DIAG FOUND ORINGS LEAKING FROM TURBO DRAIN BACK TUBE R&R TURBO TO R EPL. ORINGS & CLEANED CAC TUBES RETESTED NO LEAKS. OSP= ENG OIL DYE
AWS Claim Key: 649294 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-APR-2005 Doc #:07177951
Cust Comments: PULLING TO THE RIGHT
Tech Comments: OUT OF SPECS CASTER, CAMBER, TOE IN CHECK
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 3 7M01 150101 * 18C815 * A07 42 6127
AWS Claim Key: 863062 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04466 - * Name: BOGGUS FORD Ph: 956-4232580 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2005 Doc #:03135651
Cust Comments: RADIO VOLUME KNOB INOP
Tech Comments: REMOVE AND INSTALL RADIO
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 4 7M01 150101 5C3T 18C815 CB A07 42 6121
AWS Claim Key: 1222365 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-MAY-2005 Doc #:33718900
Tech Comments: REQUESTING DEALER'S P/A CODE 04466
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 7 6N04 010802 5C3Z 16720 VA B66 05 13900
AWS Claim Key: 1862557 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2005 Doc #:08145751
Cust Comments: RT & LT FRT FNDERS F 150 EMBLEMS
Tech Comments: FENDER NAMEPLATE PEEL REMOVE REPLACE OEN NAMEPLATE
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 8 2G04 031401 * 12A650 * D21 42 14521
AWS Claim Key: 1942497 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04241 - * Name: VAN BURKLEO FORD Ph: 956-5652421 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-SEP-2005 Doc #:101092A
Cust Comments: UNIT CRANK BUT WILL NOT START
Tech Comments: UNIT TOWED IN BY FORD ROAD SIDE RAN EEC TEST TEST AND FOUND CODE P2291 LOW ICP NOTE UNABLE TO DUCPLICATE NO START OR STALLED REPROGRAM PCM CUSTOMER WILL TAKE UNIT AS IS UNABLE TO DUPLICA T CONCERN AT THIS TIME ADVICE CUSTOMER UNIT MAY NOT BE FIX
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 8 2E03 030400 * 9543 * D50 X1 14556
AWS Claim Key: 2103973 Trx Code: E84 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-SEP-2005 Doc #:08434451
Cust Comments: CUSTOMER CONCERN OF NO START AFTER DRIVING FOR A WHILE THEN TRY TO RESTART
Tech Comments: DIESEL ENGINE DIAG SELFTEST NO CODES FOUND CK OIL PRESSURE AFTER TRUCKWAS NORMAL TEMP. LOW OIL PRESSURE SHOWING 280PSI REMOVE TURBO AND REMOVE HIGH PRESSURE OIL PUMP FOUND O RING WAS BUSTED FROM FITTING REPLACE NEW FITTING TRUCK STARTED TEST DRIVE TRUCK SHUT OFF ENGINE TRUCK STARED OK .
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 9 7A01 140101 BXT 65 750 D02 X1 15288
AWS Claim Key: 2153634 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2005 Doc #:08594251
Cust Comments: CUSTOMER CONCERN OF HARD TO START SLOW CRANK
Tech Comments: CK CHARGING SYSTEM CK ALTERNATOR CHARGING 13.92 VOLTS OK CK BATERRIES ONE BATTERY BAD REPLACE NEW TRUCK OK RETEST OK.
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 13 * * * * * * * 20354
AWS Claim Key: 3609046 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04466 - * Name: BOGGUS FORD Ph: 956-4232580 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:04862553
Cust Comments: 59B01
Tech Comments: RECALL 59B01
AWS Claim Key: 3609044 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04466 - * Name: BOGGUS FORD Ph: 956-4232580 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:04862551
Cust Comments: RECALL 05E15
Tech Comments: RECALL EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 3609045 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04466 - * Name: BOGGUS FORD Ph: 956-4232580 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:04862552
Cust Comments: RECALL 05B32
Tech Comments: RECALL COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 28 1H03 030008 5C3Z 9F452 AA D36 55 34623
AWS Claim Key: 7813538 Trx Code: S07 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04241 - * Name: VAN BURKLEO FORD Ph: 956-5652421 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2007 Doc #:114964A
Cust Comments: HAS NO POWER , BLOW SMOKE ON ACCEL, POSSIABLE WHITE
Tech Comments: CLEAR OUT EGR, CARBON UP ALL WORK DONE I A W TSB 06 19 06
1FTSW21P25EB75990 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-DEC-2004 05-FEB-2005 152097 USA 43 2H01 0300XX * 6K682 * L65 D1 44841
AWS Claim Key: 10249388 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 03759 - * Name: FREEWAY FORD Ph: 281-5885000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2008 Doc #:09192951
Cust Comments: CUST STATES VEHICLE HAS FLUID OIL LEAKS
Tech Comments: OIL LEAK DIAG FOUND ORINGS LEAKING FROM TURBO DRAIN BACK TUBE R&R TURBO TO REPL. ORINGS & CLEANED CAC TUBES RETESTED NO LEAKS. OSP ENG OIL DYE
4play is offline
4x4freak (02-16-2009)
07 F250 OASIS.....Please... 250fan Ford Oasis requests 1 01-22-2009 08:48 PM
Oasis 99 F250 John_DeereGreen Ford Oasis requests 2 01-06-2008 12:32 AM
OASIS Request: 2005 F250 6.0 PSD jmerlet Ford Oasis requests 1 11-28-2007 05:16 PM
2006 F250 request surfdunn Ford Oasis requests 0 11-23-2007 05:18 PM
2005+ f250 factory wheels on a 2004 f250 4wd kline925 General Ford Truck and Excursion 2 10-16-2006 05:46 PM
