Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sierraflyer, this thread has received 4 replies and been viewed 947 times.
post #1 of 5 (permalink) Old 02-13-2009, 03:37 PM Thread Starter
Oasis Report Please
I would like an Oasis report on my 2008 F-450 please.
Vin#1FTXW3R48EA91075
Thanks for yoour help
Sierraflyer is offline
post #2 of 5 (permalink) Old 02-13-2009, 04:10 PM
4play's Avatar
check you vin, needs to be 17 characters long you only have 16
4play is offline
post #3 of 5 (permalink) Old 02-13-2009, 04:20 PM
HARLEY6LF250SDU's Avatar
Images: 6
here ya go...................just missed the 4 W43 = F450 4X4
1FTXW 3R48EA91075
randy
OASIS RESULT:
1FTXW43R48EA91075
02/13/2009
12:15:56
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 F-SERIES BODY STYLE
F-450 CREW CAB 4X4 ENGINE
6.4L TC DIESEL V8
TRANSMISSION
TORQSHIFT AXLE CODE
8L ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/18/2007 BUILD DATE
04/28/2007 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0968 - USA 2007 NEW 84/100000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: HERMAN KUHL
OPTIONS:
EXPIRATION DATE: 05/18/2014
DISTANCE: 100,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 07892
ESP CONTRACT START DATE: 05/18/2007
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
01/27/2009
DEALER: Capital Ford
WARRANTY CLAIM NUMBER: 222778 ODOMETER: 029174M
LABOR OP
CONDITION CODE
CONDITION DESC
000 08B07B
11/10/2008
WARRANTY CLAIM NUMBER: 219631 ODOMETER: 026572M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8009B RADIATOR & SUPP ASY 001 8005A D8 FAILED GASKET/SEAL
VC 7B 003 8005D
. .. VERIFY COOLANT LEAK. PRESSURE TEST COOLING SYSTEM. FOUND LEAKING RADI ATOR. REPLACE RADIATOR, FILL COOLANT TO FULL AND RETEST. PASS. NO LEAKS
11/10/2008
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z 8B379B GASKET SET RAD TANK 001 08B06B
09/22/2008
WARRANTY CLAIM NUMBER: 217545 ODOMETER: 022881M
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 12B579A SENSOR EEC MASS AIR 001 072602A X1 POOR GROUND
8C3Z 9A332B HOSE ASY (FUEL HIGH 001
8C3Z 9A332A HOSE ASY (FUEL HIGH 001
W302474 004
W302870A 004
W300003 002
W302649 016
8C3Z 6N640B GASKET TURBO TO MANI 002
8C3Z 6N640A GASKET TURBO TO MANI 004
W302494 012
W712879S439 002
W712878S439 006
W302512 001
7C3Z 6L612B GSKT-ENG CHG EXH OLE 001
W302511 001
7C3Z 5A231AC CLAMP-MUFFLER 001
8C3Z 9G805AA KIT-CVR PMP FUEL 001
8C3Z 9T514B KIT-HDW TRBCH MTNG 001
VC 7B 003
1W1Z 19E889CC O RING - A/C COMP 001
VERIFIED NO START IDE HOOK UP SELF TEST CHECKED KOEO,KOEC P0003 P0091 CHECKE D FUSE 74 FOUND BLOWN REPLACED FUSE TRUCK STARTED OHMED WIRING TO HPP FOUND HIGH RESITANCE REMOVED CAB REPLACED HPP GASKET AND ALL EXHAUST BOLTS AND NUT S AND GSKETS CLEARED CODES RDTEST RETESTED P0103 P0101 IN SYSTEM TESTED MAF FLOW CHECKED REPL MAF CLERED CODES AGAIN GOOD
08/15/2008
WARRANTY CLAIM NUMBER: 215989 ODOMETER: 021363M
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 081303A 04 SOFTWARE REVISION/FLASH MODULE
VERIFIED IDLING CONCERN CHECKED OASIS TSB 08-13-03 REPROGRAMMED PCM,TCM,IC R ETESTED ALL OK 081303 .5
07/30/2008
WARRANTY CLAIM NUMBER: 215242 ODOMETER: 020988M
LABOR OP
CONDITION CODE
CONDITION DESC
TAP7 SERVICE LOANER 000 42 DOES NOT OPERATE PROPERLY
04/14/2008
WARRANTY CLAIM NUMBER: 210358 ODOMETER: 016200M
LABOR OP
CONDITION CODE
CONDITION DESC
8C3Z25600A58C KIT - SEAT FASTENERS 001 08C01B
02/27/2008
WARRANTY CLAIM NUMBER: 208300 ODOMETER: 016158M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 15A436AA BZL-BDY SD REFL 001 999A 42 DOES NOT OPERATE PROPERLY
F81Z 15442BA LAMP ASY-MARKER 001
REMOVED MARKER LIGHT AND FOUND MARKER LIGHT BASE IS BROKEN. NEED TO REPLACE LIGHT AND RETAINER. ORDERED PARTS. REPLACED RIGHT REAR FENDER MARKER LIGHT AND RETAINER, TESTED OK.
| On-line 1878
END OF OASIS REPORT FOR 1FTXW43R48EA91075
Ford Fleet/Comm Truck Mngr. Custom F-650 Trucks, Shelby GT500 & KR Mustangs. 406 544-6891 [email protected] Thanks Randy
TDG Mafia #53 ... Riding High Club #30 https://www.thedieselgarage.com/foru...pictureid=1589
I'd rather be riding my motorcycle thinking about God, than in church thinking about my motorcycle. ~unknown~
"I wanna die like my grandfather, in his sleep, not like the other 4 passengers screaming in his car".
2008 Harley Softail Custom 105th Aniv Limited Edition
2006 Harley F-250 Black w/Blue Flames FOR SALE $23K
2006 Harley F-350 Tor Red w/Black Flames SOLD
2005 Harley F-250 True Blue w/Med Blue Flames SOLD
2004 Harley F-250 Black & DSG 2/tone 6" Lift SOLD
1.3 million miles OTR and still Truckin!!
If you can read this, thank a teacher. If it's in English, thank a soldier.
HARLEY6LF250SDU is offline
post #4 of 5 (permalink) Old 02-13-2009, 04:28 PM
Images: 6
Different look at report if it helps............
Standard Claims List For Model Year 2008
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 3 5T03 110402 7C3Z 7210 AA G29 42 8569
AWS Claim Key: 113265 Trx Code: S07 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07809 - * Name: JONES-WEST FORD Ph: 775-3298800 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:25-JUL-2007 Doc #:37365302
Cust Comments: CUST STATES TOW HAUL INOP
Tech Comments: VERIFIED CONCERN, FOUND ECM DOES NOT NOTICE THE TOW HAUL SWITCH IS INOP. R ANR SHIFT HANDLE AND RETEST. PASS TOW HAUL WORKS NOW.
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 3 2G88 000615 * NPF * L69 82 8569
AWS Claim Key: 111467 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07809 - * Name: JONES-WEST FORD Ph: 775-3298800 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:25-JUL-2007 Doc #:37365303
Cust Comments: CUST STATES OVER QUARTER TANK OF FUEL LOW FUEL LIGHT COMES ON AND READS 50 MILES TO EMPTY
Tech Comments: RAN OASIS, NO TSB. EEC TEST NO COEDS. COULD NOT VERIFY CONCERN, NO CODES. NO PROBLEMS AT THIS TIME.
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 3 7D03 010401 F81Z 15442 CA L29 42 8569
AWS Claim Key: 111468 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07809 - * Name: JONES-WEST FORD Ph: 775-3298800 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:25-JUL-2007 Doc #:37365301
Cust Comments: CUST STATES RUNNING LIGHTS ON PASS DUALLY FLARE HAVE FELL OUT
Tech Comments: VERIFIED CONCERN, FOUND FENDER LIGHTS FALLING OUT AND WONT STAY IN WHEN REINSTALLED. R AND R WHEEL WELL COVER AND LIGHTS AND BRACKETS. VERIFIED REPAIR. OK
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 10 7D03 010401 F81Z 15A436 AA L26 42 16158
AWS Claim Key: 508474 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2008 Doc #:20830004
Cust Comments: CUST. REPORTS R.R. FENDER MARKER LOOSE AND HANGING
Tech Comments: REMOVED MARKER LIGHT AND FOUND MARKER LIGHT BASE IS BROKEN. NEED TO REPLACE LIGHT AND RETAINER. ORDERED PARTS. REPLACED RIGHT REAR FENDER MARKER LIGHT AND RETAINER, TESTED OK.
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 12 6E01 * * * * * * 16200
AWS Claim Key: 696301 Trx Code: 08C01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2008 Doc #:21035802
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 15 6Y20 000000 * TAP7 * A99 42 20988
AWS Claim Key: 1298585 Trx Code: TAP7 Labor Hrs: 0
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2008 Doc #:21524203
Cust Comments: TAP CAR ONE DAY
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 16 2G05 031405 * RECAL * P59 04 21363
AWS Claim Key: 1373612 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:15-AUG-2008 Doc #:21598901
Cust Comments: CUST STATES WHEN DRIVING INTERMITTENLY HAS HIGH IDLE AND WHE COMING TO A STOP, IT DOES NOT WANT TO HAVE TO STAND ON BRAKE
Tech Comments: VERIFIED IDLING CONCERN CHECKED OASIS TSB 08 13 03 REPROGRAMMED PCM,TCM,IC RETESTED ALL OK 081303 .5
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 17 2E06 030408 8C3Z 9G805 AA D02 X1 22881
AWS Claim Key: 1666342 Trx Code: S07 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:22-SEP-2008 Doc #:21754501
Cust Comments: ENGINE LIGHT TRUCK WILL NOT START TOW IN EXTENDED CRANK
Tech Comments: VERIFIED NO START IDE HOOK UP SELF TEST CHECKED KOEO,KOEC P0003 P0091 CHECKED FUSE 74 FOUND BLOWN REPLACED FUSE TRUCK STARTED OHMED WIRING TO HPP FOUND HIGH RESITANCE REMOVED CAB REPLACED HPP GASKET AND ALL EXHAUST BOLTS AND NUTS AND GSKETS CLEARED CODES RDTEST RETESTED P0103 P0101 IN SYSTEM TESTED MAF FLOW CHECKED REPL MAF CLERED CODES AGAIN GOOD
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 19 1F01 * * * * * * 26572
AWS Claim Key: 1949541 Trx Code: 08B06 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2008 Doc #:21963102
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 19 1F01 030301 8C3Z 8009 B L87 D8 26572
AWS Claim Key: 1949542 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:10-NOV-2008 Doc #:21963101
Cust Comments: PRESSURE TEST COOLING SYSTEM, CHECK FOR LEAKS, TEST COOLANT COOLANT IS LEAKING FROM DRIVERS SIDE RADIATOR AREA CK AND ADVISE
Tech Comments: . .. VERIFY COOLANT LEAK. PRESSURE TEST COOLING SYSTEM. FOUND LEAKING RADIATOR. REPLACE RADIATOR, FILL COOLANT TO FULL AND RETEST. PASS. NO LEAKS
1FTXW43R48EA91075 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 28-APR-2007 18-MAY-2007 172404 USA 21 2G01 * * * * * * 29174
AWS Claim Key: 2601108 Trx Code: 08B07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07892 - * Name: CAPITAL FORD Ph: 775-8825353 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2009 Doc #:22277801
post #5 of 5 (permalink) Old 02-13-2009, 06:04 PM Thread Starter
Thanks for your fast reply. I really appreciate your help.
Oasis report please 489gus Ford Oasis requests 1 05-16-2007 12:49 AM
oasis report please boss351 Ford Oasis requests 2 10-10-2006 01:17 AM
OASIS report please SDEric Ford Oasis requests 1 10-04-2006 01:27 AM
Oasis Report Please PSDfreak Ford Oasis requests 1 09-25-2006 11:24 AM
Oasis Report Please TheBAT Ford Oasis requests 2 09-18-2006 04:19 AM
