early 6.0 oasis please=) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hybrid_4x4_Superduty, this thread has received 1 replies and been viewed 947 times.
post #1 of 2 (permalink) Old 02-15-2009, 07:20 PM Thread Starter
TDG Mafia Member #64!
Hybrid_4x4_Superduty's Avatar
Send a message via Yahoo to Hybrid_4x4_Superduty
1ftsw31p03ed71039
-ADAM-
2008 Ford F-350 King Ranch, 4x4, 6.4L, Powerstroke Diesel, Torqueshift, Spartan Tuned, 4in FloPro Straight Duals, Afe Stg 2 Intake, Chromed & Tinted out!!! 115k Miles!
Hybrid_4x4_Superduty is offline
post #2 of 2 (permalink) Old 02-16-2009, 12:06 AM
4play's Avatar
OASIS RESULT:
1FTSW31P03ED71039
02/15/2009
20:05:35
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/12/2003 BUILD DATE
06/11/2003 SALE MILEAGE
00112
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0736 - USA 2005 USED 48/48,000 PREMIUMCARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: AJ JOHNSON
OPTIONS:
EXPIRATION DATE: 10/14/2009
DISTANCE: 100,554
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 02762
ESP CONTRACT START DATE: 10/14/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
0968 - USA 2007 NEW 84/200,000 DIESELCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 0 USD
OWNER NAME: A.J. JOHNSON
OPTIONS:
EXPIRATION DATE: 08/12/2010
DISTANCE: 200,000
TOWING: 0 USD
CONTRACT SOLD BY: USA 06164
ESP CONTRACT START DATE: 08/12/2003
WARRANTY REPAIR HISTORY
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 1 6D01 011001 3C3Z 3662900 AAA S50 D4 3424
AWS Claim Key: 3162989 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 02762 - * Name: GREAT LAKES FORD LINCOLN MERCURY OF MUSKEGON Ph: 231-7772750 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-SEP-2003 Doc #:13653405
Cust Comments: CUSTOMER STATES FLAW IN PASSENGER SEAT BOTTOM
Tech Comments: INSPECT AND SEND OUT OT BAKER AUTO TRIM REMOVE AND REPLACE PASSENGER SIDE SEAT BOTTOM COVER AND VERFIY REPAIR
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 9 7S11 1801XX * 14489 * D11 28 20000
AWS Claim Key: 6514820 Trx Code: E83 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 02762 - * Name: GREAT LAKES FORD LINCOLN MERCURY OF MUSKEGON Ph: 231-7772750 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2004 Doc #:14402902
Cust Comments: CUSOTMER STATES IDLES HIGH WHEN BRAKES APPLIED AT A STOP
Tech Comments: TEST DRIVE AND PERFORM DIAGNOSIS AND PINPOINTS TRACE ELECTRICAL AND FOUND OPEN WIRE ON PIN 44 PK LB REPAIR WIRING AND RE PROGRAM THE PCM MODULE AND TEST DRIVE TO VERFIY REPAIR
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 9 2E05 100106 3C3Z 9B249 AB D50 42 20000
AWS Claim Key: 6514821 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02762 - * Name: GREAT LAKES FORD LINCOLN MERCURY OF MUSKEGON Ph: 231-7772750 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2004 Doc #:14402903
Cust Comments: CUSOTMER STATES VEHICLE BLOWS BLACK SMOKE ON START UP WATER IN FUEL LIGHT WILL NOT GO OUT
Tech Comments: INSPECT AND DIAGNOSIS AND PERFORM TSB 04 09 02 REPLACING THE FUEL MANIFOLD ASSEMBLY
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 9 6A13 010809 XC3Z 16A470 AA F13 D4 20000
AWS Claim Key: 6514819 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02762 - * Name: GREAT LAKES FORD LINCOLN MERCURY OF MUSKEGON Ph: 231-7772750 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2004 Doc #:14402901
Cust Comments: CUSTOMER STATES RUNNING BOARD PLATES LOSING CLEAR COAT
Tech Comments: INSPECT AND VERFIY AND REMOVE AND REPLACE BOTH SIDES RUNNING BOARD PLATES
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 29 5B03 050301 F81Z 3254 CB P82 D8 56137
AWS Claim Key: 12763843 Trx Code: 0736D Labor Hrs: 1.9
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2005 Doc #:11470101
Cust Comments: CHECK 4X4 INOP ON AUTO AND HUBS ARE HARD TO TURN
Tech Comments: CK 4X4 AUTO NOT ENGAGING CK VACUUM SEALS LF NOT HOLDING VACU UM BOTH FRT HUBS SEIZED WONT TURN REPLACED VAC SEALS AT LF SPINDLE AND AXLE SHAFT REPALCED BOTH AUTO LOCK HUBS CK 4X4 NOW OPERATES NORMAL
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 33 * * * * * * * 60170
AWS Claim Key: 13663423 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770408
Cust Comments: CUSTOMER STATES CHECK 59B01 TEST DRIVE
Tech Comments: 1 PERFORM RECALL
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 33 3A15 0701XX 4C3Z 7G383 AA P69 42 60170
AWS Claim Key: 13663425 Trx Code: 0736D Labor Hrs: 1.8
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770405
Cust Comments: CUSTOMER STATES CHECK VEHICLE IS SLOW TO SHIFT FROM REVERSE
Tech Comments: PERFORMED LINE PRESSURE TEST ROAD TEST SLIPS DELAY IN REVERSE CHECK INLINE FILTER GRAY IN COLOR METAL REMOVED PAN INSPECT FOR METAL CALL HOTLINE REPLACED PRESSURE CONTROL SOLENOID CLEANED ALL SOLENOIDS CLEAR KEEP ALIVE MEMORY ROAD TEST SHIFTS GOOD
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 33 2G02 030008 3C3Z 12A690 BA L65 42 60170
AWS Claim Key: 13673301 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770404
Cust Comments: CUSTOMER STATES CHECK OIL LEAK
Tech Comments: CHECKED OIL LEAKING FROM GLOW PLUG BUSHING BAR ASSEMBLY NEED TO REPLACED BUS BARS REPLACED GLO PLUG WIRE HARNESSES O N BOTH SIDES
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 33 5G03 050301 5C3Z 3050 A N50 33 60170
AWS Claim Key: 13663426 Trx Code: 0736D Labor Hrs: 3.3
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770401
Cust Comments: CUSTOMER STATES CHECK CLUNKING NOISE IN FRONT END
Tech Comments: FOUND FRONT SWAY BAR BUSHINGS ARE RELAXED REPLACED BUSHINGS CHECK BOTH LOWER BALL JOINTS ARE LOOSE NEED TO REPLACE BALL JOINTS REPLACED ALL FOUR BALL JOINT GREASE SEALS AND PIN BEARINGS
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 33 2H01 030008 3C3Z 6K682 BARM D42 42 60170
AWS Claim Key: 13673302 Trx Code: E72 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770403
Cust Comments: CUSTOMER STATES CHECK HAVE TO FLOOR IT TO GET TURBO TO KICK IN HARD TO START WOULDNT START THIS TIME HAD TOWED IN
Tech Comments: CHECKED SVC CODES P0297 VEHICLE OVER SPEED PERFORMED PP TST KA1 THRU KA10 ROAD TESTED FOUND TURBO CHARGER VGT AT 85% AND EBP READING AT 15PSI AND BOOST AT 3PSI AT 3 4 THROTTLE AFTER A BRIEF ACCELERATION THEN CRUISE FOR APROX 1 2 MILE THEN ACCELL AGAIN WHEN THROTTLE REACHES NEAR WOT TRANS SHIFTS AND TURBO MAKES BOOST R&R AIR CLEANER ASSY OIL SEPERATOR COOLANT DEGAS BOTTLE CAC TUBES OIL FILLER NEC
AWS Claim Key: 13663424 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2006 Doc #:11770407
Cust Comments: CUSTOMER STATES CHECK RECALL 06E17 RECALIBRATION
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 37 5K01 040401 3C3Z 1007 FA B65 42 66494
AWS Claim Key: 14282111 Trx Code: 0736D Labor Hrs: 1
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2006 Doc #:12076101
Cust Comments: CHECK WHEELS CORRODED
Tech Comments: CK ALL FOUR RIMS ARE PEELING AND HAVE COROSION ON THEM REPLA CED RIMS AND BALANCED CK OK NOW
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 37 7W15 011902 3F2Z 15K859 BA A85 X2 66494
AWS Claim Key: 14300408 Trx Code: 0736D Labor Hrs: 1.6
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2006 Doc #:12076102
Cust Comments: CHECK BACK UP SENSORS INOP
Tech Comments: CK BACK UP SENSOR OPS TST FOR CODES C1704 RT OUTER SENSOR AN D HARNESS IS CORRODED NEEDS SENSOR AND HARNESS P P TST B1 B 7 REPALCED SENSOR AND HARNESS CLEARED CODES CK SYS PASS
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 38 3A02 0701XX 5C3Z 7B442 CA P67 42 69852
AWS Claim Key: 14488459 Trx Code: 0736D Labor Hrs: 14.1
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-SEP-2006 Doc #:12195201
Cust Comments: CHECK TRANS SLIPPING AND SHIFTING ERRATIC CK PCM AND TCM CODES P2552 U0105 FICM CIRCUIT SHOT OPEN LOSS
Tech Comments: OF COMMUNICTION BETWEEN PCM FICM P P TST A51 THRU A56 ALSO A T1 TRRU AT4 FICM MOUDLE PLUGGED IN BETWEEN FICM MGP SENOSR C LEARED CODES ROAD TST SLIPPS IN 4 GEAR HAS DELAY ENGAGEMENT IN REVERSE PREFORM SSM 17643 STILL SHIFTS THE SAME R I TRANS AND INSPECT FOUND CLUTCHES BURNT AND METAL IN PAN DIRECT AND OD CLUTCH BURNT CONTAMINATED SYS RESEAL TRANS REPLACED PISTO NS AND BURNT CLUTCHES FLUSH LINES
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 39 5C02 050100 F81Z 4800 EA K02 42 71043
AWS Claim Key: 14632194 Trx Code: 0736D Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2006 Doc #:12262301
Cust Comments: CHECK GROWLING NOISE WHEN DRIVING
Tech Comments: CHECKED GROWLING NOISE SOUNDS LIKE FROM FRONT END CHECKED FRONT WHEEL BEARINGS CHECKED END PLAY CHECKED WHEEL RUN OUT CHECKED FRONT DIFF SIDE AND PINION BEARINGS CHECKED REAR AXLE AND DIFF USED CHASSIS EARS TO PINPOINT NOISE TO DRIVESHAFT CARRIER BEARING REMOVED REAR DRIVESHAFTS REPLACED CARRIER BEARING ASSEMBLY
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 42 3A05 070100 * 7A103 * D21 69 74236
AWS Claim Key: 14778505 Trx Code: 0736D Labor Hrs: 11
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2006 Doc #:12406801
Cust Comments: CUSTOMER STATES CHECK VEHICLE DIED WHILE DRIVING WONT RESTART
Tech Comments: CHECKED SVC CODES P0720 OSS SENSOR P1744 TORQUE CONVERTER CL UTCH P2701 TRANS FICTION 3 P0730 CONTROL MALF P2700 FRICT A ELEMENT P2702 FRICTON C CHECKED LINE PRESSURE HAS 0 LINE PRE SSURE REMOVED AND DIASSEMBLED TRANSMISSION REMOVED TORQUE CONVERTER FRONT PUMP BUSHING WAS SEIZED ON TORQUE CONVERTER REMOVED FRONT PUMP PUMP GEARS BROKE AND SCARRED REMOVED REAR PLANET ASSY REAR OUTPUT INTERNAL GEAR
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 50 5A09 0502XX E8TZ 4676 B L88 D8 88535
AWS Claim Key: 15549487 Trx Code: 0736D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2007 Doc #:12981602
Cust Comments: CHECK REAR PINION SEAL IS LEAKING
Tech Comments: CK SEAL FOUND DRIPPING FLUID NEEDS REAR PINION SEAL R I DRIVE SHAFT AND INSTALLED NEW SEAL CK LEAKS GONE FLUID LEVEL GOOD
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 50 1D01 03XXXX 3C3Z 6710 BA L65 D8 88535
AWS Claim Key: 15553093 Trx Code: E72 Labor Hrs: 22.2
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2007 Doc #:12981601
Cust Comments: CUSTOMER STATES CHECK OIL LEAK IN ENGINE AREA
Tech Comments: CK OIL LEAK TSTED W DYE FOUND LFT SIDE OF BED PLATE SEAL LEA KING NEED TO R I ENGINE TO PREFORM RESEAL REMOVED ENGINE PUT ON STAND DISASSEMBLED ENGINE BED PLATE REPLACED LEAKING SEAL S MAIN BEARINGS OIL PAN SEALS HP SENSOR REASSEMBLED ENGINE AND REPLACED SEALS CAC HOSE HOT SIDE LEAKING REPLACED REFILL ED ALL FLUIDS REHCHARGED AC CLEANED TST DR CK LEAKS GONE
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 53 2E03 030402 3C3Z 9E527 EBRM D13 42 94568
AWS Claim Key: 15725390 Trx Code: E72 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2007 Doc #:13165305
Cust Comments: CHECK VEHICLE RUNS ROUGH
Tech Comments: CK RUNS ROUGH AFTER HEAD GASKET REPAIR CK EEC CODES P0269 P0 284 CYL 3 AND 8 MISS FIRE MONITORED PWR BALANCE MISSES ON 3 8 IMMEDITLY THRN TRANSFERS TO NEXT CYL P P TST P1 P15 P16 P1 7 CK FUEL PRESSURE 51 PSI AT WOT CK COMPRESSION TST ALL EQUA L R I BOTH VALVE COVERS AGAIN REPLACED ALL 8 INJECTORS CLEAR ED CODES RETSTED SYS PASS RUNS NORMAL NOW CK PWR BALANCE NOR MAL
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 53 1A02 030008 3C3Z 6051 CA L87 42 94568
AWS Claim Key: 15734068 Trx Code: E72 Labor Hrs: 20.3
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2007 Doc #:13165303
Cust Comments: CHECK WHEN VEHICLE IS UNDER A LOAD SEEMS TO BE BLOWING ANTI FREEZE OUT OF THE OVERFLOW JUG
Tech Comments: ROAD TST MONITORED ECT ADN EOT EOT READS 221 ECT READS 191 D EGREES CK TSB APPLIES EGR AND OIL COOLER INOP CAUSING HEAD B OLTS TO STRECH CAUSING HEAD GASKET LEAK PRESSURE TSTED COOLA NT SYS NO EXTERNAL LEAKS R I ENGINE AND REPLACED HEAD GASKET S REPLACED EGR AND OIL COOLER INSTALLED ENGINE NO LEAKS FOUN D TST DR AFTER REPAIR RUNS REALY ROUGH DIAG ON LINE # 5 COOL ANT NORMAL NOW
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 53 5V01 050306 1C3Z 3B396 CB P82 69 94568
AWS Claim Key: 15725391 Trx Code: 0736D Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2007 Doc #:13165301
Cust Comments: CHECK LOCK OUTS DONT TURN
Tech Comments: CK LOCK OUTS KNOBS ARE FROZE UP WONT TURN NEEDS NEW LOCK OUT S REPLACED THE LOCK OUTS WORKING NORMAL NOW
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 54 5G04 040105 2C3Z 5484 AA N50 33 96352
AWS Claim Key: 15769195 Trx Code: 0736D Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-JAN-2008 Doc #:13207302
Cust Comments: CHECK CLUNKING NOISE WHEN GOING OVER BUMPS
Tech Comments: CK NOISE IN FRT END PUT ON HOIST FOUND SWAY BAR LINKS AND SW AY BAR BUSHINGS LOOSE CAUSING NOISE REPLACED LINKS AND BUSHI NGS CK NOISE GONE
1FTSW31P03ED71039 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-JUN-2003 12-AUG-2003 148621 USA 54 5C04 050100 5C3Z 4A376 F P82 33 96745
AWS Claim Key: 15788382 Trx Code: 0736D Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06164 - * Name: NORTHERN MOTOR COMPANY Ph: 906-7861130 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2008 Doc #:13219301
Cust Comments: CHECK VIBRATION WHEN VEHICLE IS IN 4X4
Tech Comments: CK VIBRATION TST DR PUT ON HOIST FOUND DOUBLE CARDAN JOINT A ND YOKE PIVOT BALL IS WORE AND SLOPPY CAUSING VIBRATION REPL ACED DRIVESHAFT CK VIBRATIONS GONE NOW
4play is offline
early 99 with dp? brentos 1994-2003 7.3L Power Stroke 48 01-29-2008 02:44 AM
Early 99 vs 99.5 powerstroke2003 1994-2003 7.3L Power Stroke 9 08-15-2007 01:00 AM
Oasis on early 03 6.0:) Hybrid_4x4_Superduty Ford Oasis requests 4 04-19-2007 02:35 AM
Are new 6.0L any better than early 1's ? jmcholden 2003-2007 6.0L Power Stroke 23 10-07-2006 04:49 PM
5-0 to a Early 7.3 countryboy88 7.3L and 6.9 IDI (Pre 1994) 17 06-07-2006 12:31 AM
