OASIS please... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Zaairman, this thread has received 3 replies and been viewed 701 times.
post #1 of 4 (permalink) Old 02-15-2009, 11:14 PM Thread Starter
Mod Friendly Title
Zaairman's Avatar
OASIS please...
1ftnx21f3yeb15061
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #2 of 4 (permalink) Old 02-16-2009, 12:08 AM
4play's Avatar
OASIS RESULT:
1FTNX21F3YEB15061
02/15/2009
20:07:19
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
WARNING MESSAGES
ALL WARRANTIES EXCEEDED; ESP UNLIMITED MAY APPLY
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/02/2000 BUILD DATE
10/18/1999 SALE MILEAGE
00210
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 1 5H01 040201 * 5580 * N17 42 1072
AWS Claim Key: 513182 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2000 Doc #:208438A
Cust Comments: SQUEEK NOISE IN FRONT END WHEN BRAKING....SUSPENSION NOISE
Tech Comments: 1073 CC 42 ROAD TEST TO VERIFY NOISE CONCERN.INSPECT FRONT SUSPENSION.RAISE VEHICLE TO RELIEVE WEIGHT FROM FRONT LEAF SPRINGS.SEPERATE AND LUBRICATE FRONT AND REAR INSULATOR PADS BETWEEN UPPER AND LOWER SPRING LEAVES. REASSEMBLE AND ROAD TEST.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 1 5R15 110601 * SWHEEL * H25 42 2677
AWS Claim Key: 599276 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2000 Doc #:208795B
Cust Comments: PULLS LT DRIVING
Tech Comments: 2682 CC 42 ROAD TEST TO VERIFY CONCERN.ADJUST TIRE PRESSUR E.CHECK ALIGNMENT OK.CRISS CROSS FRONT TIRES. ROAD TEST OK NOW.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 3 6Y05 000001 * MAINT * A96 82 6121
AWS Claim Key: 1052516 Trx Code: 0713S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2000 Doc #:210951B
Cust Comments: 5000 MAINT.
Tech Comments: 6121 MAINT PERF DIESEL OIL CHANGE AND 8 LUG ROTATION.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 4 5H01 040100 F81Z 5586 AA N12 49 7202
AWS Claim Key: 1339465 Trx Code: 1 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2000 Doc #:211515A
Cust Comments: SQUEEK NOISES IN FRONT END OVER BUMPS
Tech Comments: 7206 CC 30 ROAD TEST TO VERIFY NOISE CONCERN.REPAIR AS PER TSB 99 16 3,INSTALL 4 NEW FRONT LEAF SPRING INSULATORS DUE TO WORN NOISY.ROAD TEST OK NOW.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 5 5G01 040101 * 5310 * N59 42 10467
AWS Claim Key: 1591199 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2000 Doc #:212776A
Cust Comments: SQUEAKING FRONT END WHILE ACCELERATING ANY SPEEDS
Tech Comments: 10470 CC 42 ROAD TEST.COULD NOT DUPLICATE SQUEAK NOISE ON ACCEL BUT DID HEAR NOISE ON BRAKING.INSPECT FRONT LEAF SPRINGS AND LUBE FRICTION PADS.ROAD TEST.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 5 7S02 180102 * 14401 * A85 X4 10467
AWS Claim Key: 1591200 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2000 Doc #:212776B
Cust Comments: ALL ENGAGEMENTS ON DASH BOARD ARE INOP
Tech Comments: 10467 14401 X4 WTY VERIFIED 4X4 INOP. USE NGS TO RETRIEVE DTCS, NONE IN MEMORY. USE NGS TO MONITOR PIDS,4X4 SWITCH,PID VALUSE DO NOT AGREE. NEC TO R&I I P BEZEL,AND CENTER DASH BEZEL TO INSPECT 4X4 SWITCH. FOUND WH LB,AND DB WIRES AT C246, PUSHED OUT OF TERMINALS,GROUNDED OUT ON DASH BRACE. NEC TO REPAIR C246 TERMINALS. ALSO NEC REPLACE FUSE #19. RETEST OK.
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 5 7V01 060604 * 13480 * A26 X2 10467
AWS Claim Key: 1675230 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2000 Doc #:212776C
Cust Comments: WHEN STARTING VEH WHEN PUTTING PRESSURE ON GAS PEDAL WILL NOT MOVE
Tech Comments: VERIFIED COLD START WHEN DEPRESSING ACCEL PEDAL NO RESPONSE INSPECT ACCEL PEDAL FOUND C2001 ON ACCEL PEDAL POSTION SENSOR NOT FULLY CONNECTED RECONNECT AND TEST OK
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 9 6Y05 000001 * MAINT * A96 82 19919
AWS Claim Key: 3818346 Trx Code: 0713S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2000 Doc #:217993A
Cust Comments: DIESEL OIL CHANGE
Tech Comments: 19919 CHANGE OIL AND FILTER,ROTATE TIRES,CHECK FLUIDS
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 11 2I04 NANANA F81Z 12B533 AC D03 42 22210
AWS Claim Key: 4769678 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-DEC-2000 Doc #:219537A
Cust Comments: THE VEHICLE WILL NOT START IN THE MORNING AFTER IT HAS BEEN SITTING IN THE COLD OVER NIGHT. THE CONCERN HAS HAPPEN EVERY MORNING THAT IT HAS BEEN COLD OUTSIDE. PLEASE LEAVE VEHICLE OUTSI
Tech Comments: 22210 12B533 CC42 RAN WDS KOEO KOER NO CODE CHECKED OIL LEVEL OK PERF INTAKE EXHAUST RESTRICTION TEST OK CHECKED FUEL QUALITY AND PSI OK MONITORED PIDS OK PERF GLOW PLUG SYSTEM TEST FAILED PERF PINPOINT TEST FOUND THE GLOW PLUG RELAY INOP REPL. THE RELAY RETEST CODE P1000
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 13 7N02 010505 YC3Z 14529 AAA G07 42 26347
AWS Claim Key: 6289622 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2001 Doc #:221492A
Cust Comments: RT POWER WINDOW WILL NOT OPEN INOP USING DRIVER SIDE CONTROLS INT.
Tech Comments: 26347 14529 42 PERFORM SW TEST FOUND LT WINDOW SW BAD NECC REPLACE LT WINDOW SW RETEST OK
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 14 6Y05 000001 * MAINT * A96 82 28785
AWS Claim Key: 6974096 Trx Code: 0713S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2001 Doc #:223099A
Cust Comments: 25,000 MAINT.
Tech Comments: 28785 OIL AND FILTER CHG TIRE ROTATION
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 15 1B02 03XXXX F4TZ 6731 A L65 D8 31002
AWS Claim Key: 7985463 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2001 Doc #:224547A
Cust Comments: L65 ENGINE OIL LEAK
Tech Comments: 31002 WARR 8 PERFORMED OIL DIE TEST TO PINPOINT LEAK FOUND FILTER NOT SEALING ON BASE PROPERLY REPLACED OI L FILTER AND TOPPED OFF OIL
1FTNX21F3YEB15061 T/F7 F T/BD T/BD T/E A1 T/DQ T/DS 18-OCT-1999 02-FEB-2000 148049 USA 19 6Y05 000001 * MAINT * A96 82 36898
AWS Claim Key: 10213081 Trx Code: 0713S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 03000 - * Name: ALAN FORD, INC. Ph: 248-3333000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2001 Doc #:228670A
Cust Comments: 35,000 MAINT.
Tech Comments: 36898 LOF AND ROTATED TIRES
4play is offline
Zaairman (02-16-2009)
post #3 of 4 (permalink) Old 02-16-2009, 06:14 PM Thread Starter
Mod Friendly Title
Zaairman's Avatar
Does OASIS cover warranty only work or out of warranty work also?
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #4 of 4 (permalink) Old 02-16-2009, 08:16 PM
4play's Avatar
it only has reports of warranty, or recalls, or anything else paid by ford. nothing else.
4play is offline
