Oasis Report Please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mach_1, this thread has received 1 replies and been viewed 525 times.
post #1 of 2 (permalink) Old 02-19-2009, 12:35 PM Thread Starter
Oasis Report Please
I would like an Oasis Report for my 06 F-350. The VIN is 1FTWW32P06EC14311 Thanks for the help.
Mach_1 is offline
post #2 of 2 (permalink) Old 02-19-2009, 02:44 PM
4play's Avatar
OASIS RESULT:
1FTWW32P06EC14311
02/19/2009
10:43:25
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/21/2006 BUILD DATE
11/29/2005 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
1FTWW32P06EC14311 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 29-NOV-2005 21-MAR-2006 152023 USA 9 2E03 030402 4C3Z 9E527 AA D03 42 51433
AWS Claim Key: 2442834 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD LINCOLN MERCURY Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2006 Doc #:539487A
Cust Comments: QCP D03 C S VEH RUNS ROUGH DIED HAD SLOW CRANK HAD TO WAIT AWHILE WOULDNT GO OVER 40 MPH
Tech Comments: 51433 INJECTORS WF VERIFIED CUSTOMER CONCERN. RAN DIESEL DIAG. FOUND INJECTOR CODE P0269 IN PCM DURING KOEO, KOER, ADN CMDTCS. POWER BALANCE FOUND INJECTORS NUMBER 1, 3, AND 6 DROPPING. REPLACED INJECTORS AFTER VERIFYING RELATIVE COMPRESSION WAS OK. ALL OTHER DIAG SHEET FINE AND WITHIN SPECS. TRUCK RUNS FINE AFTER REPAIRS CLEARED PCM.
1FTWW32P06EC14311 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 29-NOV-2005 21-MAR-2006 152023 USA 13 2H01 03XXXX 5C3Z 6K854 CA D13 42 64130
AWS Claim Key: 3218605 Trx Code: E72 Labor Hrs: 9.4
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD LINCOLN MERCURY Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2007 Doc #:548601C
Cust Comments: D13 C S VEH LOSES POWER WHILE DRIVING
Tech Comments: 64130 INJECTORS WF VERIFIED CUSTOMER CONCERN. RAN DIESEL DIAG. SHEET. FOUND P0263 AND P0281 DURING PCM TESTS. POWER BALANCE TESTS SHOWED INJECTORS 1,7,2, ADN 8 DROPPING. REPLACED NUMBERS 1 AND 7 ON PASSENG ER SIDE OF MOTOR AND NUMBERS 2 AND 8 ON DRIVER SIDE OF MOTOR. TEST DROVE TRUCK SEVERAL TIMES AFTER REPAIR. TRUCK RUNS FINE AT THIS TIME. AFTER REPAIRS TRUCK HAS AN EXHAUST LEAK NOW THA
1FTWW32P06EC14311 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 29-NOV-2005 21-MAR-2006 152023 USA 16 2E03 030402 4C3Z 9E527 AA D42 42 74097
AWS Claim Key: 3831624 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 06422 - * Name: BUTCH OUSTALET, INC. Ph: 228-8635525 St:MS Ctry Cd: USA Reg Cd: NA Repr Date:18-JUN-2007 Doc #:157701A
Cust Comments: CHECK FOR BAD LOSS OF POWER
Tech Comments: 74103 VERIFIED CONCERN, P0281 P0266, CHECKED FUEL PRESSURE 58PSI, RAN ELECTRICAL INJ TEST ELECRICAL PASS, POWERBALANCE SHOWED #7 #2 CYLINDERS LOW, KILLED INJECTORS IN POWER BALANCE MODE NO CHANGE FOR #7 #2, REPLACED #7 #2 INJECTORS, CLEARED CODES, TEST DROVE, REPERFORMED QT, PASSED NO NEW DTC NO MORE LACK FO POWER CONCERN
1FTWW32P06EC14311 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 29-NOV-2005 21-MAR-2006 152023 USA 17 6Y20 000001 * MISC * A99 82 85586
AWS Claim Key: 4392106 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD LINCOLN MERCURY Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-AUG-2007 Doc #:561173A
Cust Comments: E23 C S VEH RUNNING HOT AND COOLANT LEAKING UNDERNEATH
Tech Comments: 85586 CC 01 FAULTY RADIATOR VERIFIED CONCERN. PERF COOLING SYS PRESSURE TEST AND FOUND COOLANT LEAKING FROM RADIATOR. DRAINED COOLING SYS,R&R COOLING FAN SHROUD, RADIATOR AND INSTALLED NEW ONE AND REINSTALLED ALL AND REFILLED COOLING SYS AND TEST DROVE 9 MILES AND PERF PRESS TEST AGAIN AND LEAK SI GONE AND SYS NOW HOLD PRESSURE. NO MORE PROBLEMS AT THIS TIME
4play is offline
Mach_1 (02-20-2009)
OASIS Report Please jdecker88 Ford Oasis requests 1 12-03-2007 11:58 AM
oasis report please detailman Ford Oasis requests 2 12-13-2006 09:20 PM
OASIS Report Please jmj12396 Ford Oasis requests 2 12-13-2006 06:40 PM
OASIS Report CombatSent Ford Oasis requests 1 12-13-2006 11:51 AM
Oasis Report FIRSTFORDF250 Ford Oasis requests 5 11-10-2006 01:16 AM
